Lg43UJ620V horizontal line
  • labello
    • Mar 2018
    • 252
    • italia
    Hi guys I have this tv and in one side of the pannel it shows some line i also cleaned the camble notting, although I found an smd capacitor on the pcb (there's no tcon on this model) but I can't find the same model thanks
  • Ihandyrepair
    Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
    by Ihandyrepair
    Hi guys
    I just started fixing 4k TV few months ago. so I am still learning a lot
    I got this tv from friend complaint is ghosting or horizontal lines on image.
    never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
    then it started to show the ghosting white image.
    I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
    it has 3 thin small boards at the bottom of the...
    12-05-2022, 04:18 PM
  • cubytus
    Samsung UN50TU8000FXZC shows thin horizontal green line when warm
    by cubytus
    Hi to all,
    I was given this TV, an entry-level 4K 50" set. Some have criticized its lack of contrast and relatively poor colour rendering, but for my needs, it's very decent.
    I reset everything to factory settings, but this line keeps on fading in and out when watching a streaming channel from the Tizen firmware. Interestingly, it only happens when TV is warm, after about 1h45 of it being turned on.
    Watching a movie from an external source doesn't trigger the line as easily (needs 2 hours), and from a normal viewing distance, is hardly noticeable. It...
    01-10-2024, 01:26 AM
  • labello
    by labello
    02-20-2025, 02:52 AM
  • dikei
    China Make TV with LG Display horizontal line at top and video freezes 1-3 secs
    by dikei
    Hi guys!
    I'm new to TV repair and just started looking into troubleshooting guides and other online info.
    Right now I have a Chinese make with LG display that is faulty. If I am not wrong I see two different problems here below.
    1. There is a line(white/multicolored) at the very top of the display that shows thinner sometimes and slightly thicker in some occasions.
    2. For any video the play freezes 1-3 secs and at the same time brightness goes low and returns to high when video continue to play.
    From my initial research...
    07-06-2023, 11:53 AM
  • mikey5791
    Help diagnose AOC e2350sd monitor horizontal line
    by mikey5791
    Hi forum friends,
    A friend bought this working AOC lcd monitor and used it without problem for less than 6 months. Yesterday he brought to me and said it has a horizontal line now and will auto shut off in less than 2 minutes. Btw he had decided to dump it if not repairable. As a friend, i tried my best to help and after opening the case i don' t see anything burned or parts having cold solder joint.
    Fyi, most of the electrolytic caps are tested within 5% range on esr reading except that i changed cap at c918(680uf reads 654.3uf) to a 1000uf cap. Also i added a 680uf...
    05-15-2021, 07:46 PM
