LG 50LA6205 Bad Backlight and Bad Panel
  • neilc6
    • Nov 2015
    • 1550
    This TV had a logo flash on plug in which is symptoms of a bad LED backlights. Replaced 4 shorted LEDs and now getting horizontal lines. Tcon ribbons connected one at a time show both vertical and horizontal lines with one side. Confirm this is a bad panel before I scrap this tv?
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LG 50LA6205 Bad Backlight and Bad Panel
    Yes...I see a bad panel.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4538
      • Italy - Milan
      With some work it may be salvaged.. many methods on the field to try.. the easiest one to remove the side tab where the problem starts... also masking with tape on tcon can be tried..
      • neilc6
        • Nov 2015
        • 1550
        No side tabs. Pushed down the tab bonds on the bad side with no change. Scrapped the TV already. Thanks for the input.
        • alas3376
          • Nov 2011
          • 382
          • BENIN
          Bad panel
          • neilc6
            • Nov 2015
            • 1550
            Thanks Davi.p! Was ready to take the TV to recycling and decided one last attempt with the tape method on the tcon ribbon after reassembling the TV. Luckily none of the parts sold yet on ebay. On the side that showed lines (right), I blocked off around 20 pins on the leftmost side and it worked!!
              Good works! Lets see how long it will last, at least it is working for now.
              Can I get good clear pictures of the T-CON board so may be I can see what those pins are for.
              • neilc6
                • Nov 2015
                • 1550
                Sorry, not the best focussed since it was for the ebay listing. Don't want to take the tv apart again since it has been reassembled about 5 times and I've already busted some plastic tabs.
                  Thanks for the pictures, at least I can read the PCB and PCBA numbers so now I can go to shopjimmy to get good clear pictures.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4538
                    • Italy - Milan
                    OK, where do you have found instructions on how to block signals? I have tried with my 50 inch Hisense w/AUO panel but the result is not perfect, the line still persist due to some gate drv outputs maybe shorted that keep the opposite output low or high, the bigger part of defect is disappeared.. the outer part of the flat is usually reserved for clock signals to the gate drivers.. In mine i have blocked only one signal that disables all the faulty side gate drv, but i will try block others.. maybe it's necessary also to block VGON/VGOFF
                    • neilc6
                      • Nov 2015
                      • 1550
                      Saw two youtube videos before about putting tape on the tcon ribbons. One wasn't really clear what he was doing. Tape is actually used to block the pins and not to apply more pressure to the contacts. Another one I recall was to vary the pins blocked and location. Mainly trial and error with the location and width of the tape. I'll see if I can find them since it was awhile ago.
                      I fixed a Samsung before blocking just a few pins.
                      https://www.badcaps.net/forum/showthread.php?t=50646
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4538
                        • Italy - Milan
                        Yes i saw a shopjimmy picture, them are all the gate driver related signals,except Vcom, Vcomr_FB that maybe better to leave connected, i will check..
                        • neilc6
                          • Nov 2015
                          • 1550
                          Here is one video
                          https://youtu.be/j7vl7-vZEL8
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4538
                            • Italy - Milan
                            yeah i knew that video..
                            • neilc6
                              • Nov 2015
                              • 1550
                              2 lines intermittently came back along with a pattern across the whole screen. I replaced the scotch tap with electrical tape and will run for a few days to see if it comes back.
                              • Gdog215
                                • Mar 2018
                                • 29
                                • Usa
                                Is your tv still working today?
                                You live and you learn right?
                                • neilc6
                                  • Nov 2015
                                  • 1550
                                  Tv came back recently. Another backlight failed even though all inputs were set at 60/100. Repaired and back up and no lines. I would exoect it to last as long as the side tab removal fix.
                                  • RJARRRPCGP
                                    • Jul 2004
                                    • 6304
                                    What? Another re-badged Sharp panel?
                                    ASRock B550 PG Velocita
                                    Ryzen 9 "Vermeer" 5900X
                                    Arc A770 16 GB
                                    eVGA Supernova G3 750W
                                    Alienware AW3423DWF OLED
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4538
                                      • Italy - Milan
                                      Hi neil, i suspect your customer has mains power line disturbances, next time i suggest you to protect all the screen (backlight and tcon/panel matrix) with TVS diodes or varistors and check the backlight driver's power semicon for cracks in solders and esr of the output el.caps. The suppressors must blow a fuse so your work will be easy and cheap in replacing it.. Bye.
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        What is theory on this type of repair ? I mean, how are these parts of the panel still displaying an image when the signal containing the image information is being blocked with tape ?
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • maneatingmonkey
                                          Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
                                          by maneatingmonkey
                                          I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
                                          There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
                                          03-27-2024, 07:17 AM
                                        • Sharx112
                                          ASUS VA27EHE randomly unstable
                                          by Sharx112
                                          Hello community. I've got an ASUS VA27EHE with a Panda LC270lf1l01 panel that started to behave strangely. A bit of intro:
                                          If you power on the monitor without any inputs it turns on, displays the ASUS logo, shows no signal and goes into standby normally. When you plug it via HDMI sometimes and more recently, most of the times, it distorts the bios logo with horizontal lines, then when loading into windows 50-50 the windows emblem also is in horizontal lines. And after the system loads it almost always works properly, lol. On some rare occasions a part in the top of the monitor is being distorted...
                                          03-26-2025, 03:42 AM
                                        • pni
                                          Backlight panel diffuser melt by backlight leds broken
                                          by pni
                                          Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
                                          10-12-2025, 12:08 AM
                                        • learnmore
                                          Samsung UE70TU7020K Which lines to tape on a bad panel
                                          by learnmore
                                          Hello Community,
                                          I'm working on a Samsung UE70TU7020K.
                                          It looks like a bad panel. There is only 1 FPC cable from the Tcon (built into mainboard) to the panel.
                                          I'm using a piece of tap a few mils (covers about 8-10 pins), at different locations and have had varying results but nothing that is remotely watchable (multiple lines across all the screen, half screen and total black out on screen). The buffer board is divided into 3 boards. I've disconnected the end board one at a time but each time the screen was totally black. I presume it's because the potential...
                                          03-15-2024, 03:01 PM
