Need help running this weird one down! Originally this TV was stuck in standby mode, with all power supply sources checking OK. Di the reasearch here and found out about the eprom issues on this and similar sets. So I replaced U18 on main board (MSAV3227-ZC01-01) with a part from shopjimmy. This looks to be the same board used in Haier LE39F32800. I was exited to set the set come back to life but now I have this.. Every thing looks like an Andy Warhol painting!!! Looks like a negative chroma image?? Also, I was able to get into the service menu but saw no setting that would appear to "flip" this issue... any thoughts!! Thanks in advance!!!
Haier LE55F32800 Standby but now Andy Warhol video!
Re: Haier LE55F32800 Standby but now Andy Warhol video!
The third one, reminds me of Windows' 4 BPP (bits-per-pixel, a.k.a. 16-colors) fallback, when the video card driver failed, L O LLast edited by RJARRRPCGP; 12-21-2018, 12:10 PM.ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
"did I see a chair fly? I think I did! Time for popcorn!" -ratdude747 -
can you get into the service menu i think it could possibly be a lvds setting (make a note of original settings first though)Comment
That is GAMMA problem, so it is either the main board is not set to match the LCD panel, or failed GAMMA Voltage reference IC.
BTW, How did you about matching the new board with the old board: go by PCB Assembly P/N which is usually printed on the barcode sticker or you go by the Blank PCB P/N which printed white silkscreen on the PCB?
Blank PCB can be stuffed to make many PCBA for many TV models.Last edited by budm; 12-21-2018, 02:30 PM.Never stop learning
Yeah I did not replace the board only the U18 eprom on the original board. So I am not sure the code in this eprom was correct for my panel. They did not have an eprom listed for my set. This is a 55 inch panel and most boards and parts are listed for the 39 inch version.Comment
take pictures of your service menu then maybe we can help more also try suggestion in post 4Last edited by vinceroger69; 12-21-2018, 03:24 PM.Comment
I have searched high and low for the eprom firmware for this board with no luck. I have been searching by model number but maybe should be using the board number?? I will screen shot the service menu options tonight and post here. Thanks to all so far!!!Comment
Service menu: LVDS Bit mode:change it, display should clear up when you hit the right one. Make note of original setting, in case its not the problem. If its a service menu setting problem, you will be looking for "panel setting", "lvds map setting" "lvds bit mode" make note of original setting, in case you need to revert, might just need to get into panel settings and change to 55.Last edited by nomoresonys; 12-21-2018, 09:08 PM.Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
Also, while investigating the service menu, I got myself stuck in "aging mode" !! Green, Blue, Black, white, Red> repeat.. Tried all typical suggestions (manual power button, hold manual power 30 sec, down-up channel buttons) so any suggestions here would be good!!Comment
leave it on in aging test hopefully after a while it will come out of the test i have read some take 2 hoursComment
If that don't work, try usb firmware update/reapply, oh I see you cant find the firmware.Last edited by nomoresonys; 12-22-2018, 12:36 PM.Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
Try holding the power button on tv for a whole minute.Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
You probably already tried the exit button on remote?Quit because THIS SITE LETS A ROGUE MEMBER TYPE ANY GARBAGE HE PLEASES AND THE POWERS THAT BE NEVER DO ANYTHING ABOUT IT SO HE NEVER QUITS. THEN YOU GET A PENALTY FOR RESPONDING TO HIS ATTACKS. BEEN GOING ON FOR WAY TOO LONG. DONE SUPPORTING A SITE THAT ALLOWS THIS BS.Comment
have you still got your old eeprom did you try freezing it first and seeing if the tv turned on? if it does you maybe able too freeze it and read data from it and rewrite it to a new eeprom.Comment
This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...09-12-2024, 02:00 PM
by sam_sam_samThis is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it... -
This specification for the HP EliteBook 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and 1040 G4 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...09-06-2024, 06:20 AM
This specification for the HP ProBook 430 G5 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G5 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and 430 G5 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...09-06-2024, 06:20 AM
This specification for the HP EliteBook x360 1030 G2 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G2 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and 1030 G2 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users...09-06-2024, 06:20 AM
- Loading...
