Haier LE55F32800 Standby but now Andy Warhol video!
  • smartjohn
    • Feb 2013
    • 116
    Need help running this weird one down! Originally this TV was stuck in standby mode, with all power supply sources checking OK. Di the reasearch here and found out about the eprom issues on this and similar sets. So I replaced U18 on main board (MSAV3227-ZC01-01) with a part from shopjimmy. This looks to be the same board used in Haier LE39F32800. I was exited to set the set come back to life but now I have this.. Every thing looks like an Andy Warhol painting!!! Looks like a negative chroma image?? Also, I was able to get into the service menu but saw no setting that would appear to "flip" this issue... any thoughts!! Thanks in advance!!!
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: Haier LE55F32800 Standby but now Andy Warhol video!
    The third one, reminds me of Windows' 4 BPP (bits-per-pixel, a.k.a. 16-colors) fallback, when the video card driver failed, L O L
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • vinceroger69
      • Mar 2012
      • 6714
      can you get into the service menu i think it could possibly be a lvds setting (make a note of original settings first though)
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4539
        • Italy - Milan
        Do this: update software, go to service menu and do a full reset.
          That is GAMMA problem, so it is either the main board is not set to match the LCD panel, or failed GAMMA Voltage reference IC.
          BTW, How did you about matching the new board with the old board: go by PCB Assembly P/N which is usually printed on the barcode sticker or you go by the Blank PCB P/N which printed white silkscreen on the PCB?
          Blank PCB can be stuffed to make many PCBA for many TV models.
          • smartjohn
            • Feb 2013
            • 116
            Yeah I did not replace the board only the U18 eprom on the original board. So I am not sure the code in this eprom was correct for my panel. They did not have an eprom listed for my set. This is a 55 inch panel and most boards and parts are listed for the 39 inch version.
            • smartjohn
              • Feb 2013
              • 116
              Vinceroger69 - I do not see an lvds option in the service menu. Would it be listed as something else???
              • vinceroger69
                • Mar 2012
                • 6714
                take pictures of your service menu then maybe we can help more also try suggestion in post 4
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4539
                  • Italy - Milan
                  smartjhon listen to me.. an old beast in tv stuffs, nowadays..
                  eehm... one moment, i shrink the list of things, i forgot you have same board so don't even update, do only a SM reset...
                  • smartjohn
                    • Feb 2013
                    • 116
                    I have searched high and low for the eprom firmware for this board with no luck. I have been searching by model number but maybe should be using the board number?? I will screen shot the service menu options tonight and post here. Thanks to all so far!!!
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4539
                      • Italy - Milan
                      In Italy we use to say There's no worst deaf that who don't want to hear...
                      i'm giving you the simplest way and you don't catch it.
                        • 12330
                        • U.S.
                        Service menu: LVDS Bit mode:change it, display should clear up when you hit the right one. Make note of original setting, in case its not the problem. If its a service menu setting problem, you will be looking for "panel setting", "lvds map setting" "lvds bit mode" make note of original setting, in case you need to revert, might just need to get into panel settings and change to 55.
                        • smartjohn
                          • Feb 2013
                          • 116
                          OK.. here we go with the service menu options. I do see LVDS under the SSC menu....
                          • smartjohn
                            • Feb 2013
                            • 116
                            Also, while investigating the service menu, I got myself stuck in "aging mode" !! Green, Blue, Black, white, Red> repeat.. Tried all typical suggestions (manual power button, hold manual power 30 sec, down-up channel buttons) so any suggestions here would be good!!
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4539
                              • Italy - Milan
                              What i have said? Now you're in the s**t..
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                leave it on in aging test hopefully after a while it will come out of the test i have read some take 2 hours
                                  • 12330
                                  • U.S.
                                  If that don't work, try usb firmware update/reapply, oh I see you cant find the firmware.
                                    • 12330
                                    • U.S.
                                    Try holding the power button on tv for a whole minute.
                                      • 12330
                                      • U.S.
                                      You probably already tried the exit button on remote?
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        have you still got your old eeprom did you try freezing it first and seeing if the tv turned on? if it does you maybe able too freeze it and read data from it and rewrite it to a new eeprom.
