LG 26LE5300 Boot Loop after power surge hit
  • Chaks
    • Sep 2015
    • 115
    • India
    I have a LG 26le5300 that gets stuck at boot logo after automatically rebooting for 4 or 5 times when switched on.
    I suspect some blown components (see image in red and yellow markings on the pcb image and also on the pcb schematic image) in this area, the P channel MOSFET A03407 (Q7501). The voltage reading Vgs should be 10.8 for a 24 volt input bu I get +24.03 volts between Gate and Source. And -24.0 Volts between Gate and Drain. Measured with multi meter's Red lead on Gate and black lead on source and drain respectively.
    Please help:
  • Chaks
    • Sep 2015
    • 115
    • India
    Re: LG 26LE5300 Boot Loop after power surge hit
    Can anyone please help me with the main board PCB of lg TV 26le5300. I want to compare my PCB with an actual working PCB to see if any components are missing on the PCB. Is there any complete service manual for the TV . please help.
    Image of both sides of working PCB is what I need at least.
      • 12085
      • U.S.
      Try heating sections of the mainboard with a hairdryer, see if it stays on if no results try heating some capacitors on powerboard.
      • Chaks
        • Sep 2015
        • 115
        • India
        Q7502 2sc3052 npn transistor has the following readings.
        Base +lead to emitter -lead = 0.6v
        Base +lead to collector -lead =0.6v
        Emitter +lead to base -lead =over limit
        Collector +lead to base -lead = over limit
        Collector +lead to emitter -lead = 0.98 volts
        Emitter +lead to collector -lead = 0.68 volts
        POWER DET circuit:
        IC 7509 ( ncp 803 sn293)
        Pin 3 vcc to ground of PCB is 3.5 volts
        Resistance between pin vcc and reset pin 2 is 100k ohms
        The TV resets when pin 1 gnd or pin 2 reset is touched by multimeter leads pos or neg.
        IC 7510 (ncp 803 sn293)
        Pin vcc to ground of PCB is 0.9 volts
        Pin 3 vcc to gnd pin 1 is 1.9 volts
        Resistance between vcc and reset pin is 355k ohms
        Pin 1 gnd and pin 2 reset pin (+lead) is 3.6 volts
        Reset pin to ground of PCB is 1.2 volts
        Is there anything faulty here? Power-det circuit is on page 35 of the service manual.
          https://www.badcaps.net/forum/attach...6&d=1544886413
          For Q7501 (P-ch) the GATE Voltage has to be about 3 ~4 V < Source Voltage, you need to use circuit GND to verify the Voltages.
          What Voltage do you have on that POWER_ON pin?
          Q7500 has to be turned on by POWER_ON control Voltage for Q7501 to be on.
          We also need pictures that show how all the boards are connected together.
          • Chaks
            • Sep 2015
            • 115
            • India
            I get the Vgs 10.8 volts on the a03407A G-S but only for a couple of seconds. The +15 Volts control chart in the service manual page 35.
            I checked all the voltages as per the service manual charts on page 35. There are two areas Power-Det and 24-volt->15 volt chart where the readings does not match.
            in power detect IC7510 vcc pin is not reading +3.5_ST but the IC7509 vcc pin measures +3.5_ST.
            The other issue is that in 24-volt->15 volt control chart. the R7540 reads 32k Ohms only. the other resistors are ok and as per smd code/markings.The Capacitor 7522 has turned darkbrown seems over heated or about to die but but measures ok.Or it may be already dead. these 2 components along with Q7502 in the first chart in page 35 are abnormal. I will post an image of the pcb along with test voltages below.
            • Chaks
              • Sep 2015
              • 115
              • India
              Additional PCB Images
                So what is the answer for this one: What Voltage do you have on that POWER_ON pin?
                • Chaks
                  • Sep 2015
                  • 115
                  • India
                  Here are the readings of the Q7500, Q7501 , Q7502, orientation as they appear in on the PCB. Thanks a lot for your time sir
                    So you do have 24V with reference to GND Source and also at Drain pin of Q7501, so what is wrong with that? That is what it should have when it is turned on.
                    BTW, you do know how to read schematic, correct? And you do understand how Transistor and MOSFET work, correct?
                    I still do not understand why you have to make other measurement that are not reference to GND, no need to do that right now.
                    • Chaks
                      • Sep 2015
                      • 115
                      • India
                      Should I not worry about this
                      https://www.badcaps.net/forum/attach...0&d=1545156295
                      Is this normal?
                      • Biruslapio
                        • Nov 2013
                        • 552
                        • Brasil
                        Resistors are almost always in parallel with a lot of things in the circuit,especially main boards,it's not a problem if they read less than their rated resistance,but more,for example this 120k reading 200k,that would mean it is defective.
                        These capacitors if not reading 0 OHM are probably good,sometimes they are in parallel with some processor silicon which measures kinda low resistance(5 OHMs or more generally).
                        • Chaks
                          • Sep 2015
                          • 115
                          • India
                          When the TV is connected to the ac using adapter the standb red led is ON and the optical output on the back of the tv usually glows red but in my case the optical output on my TV is off. The optical lack J1103's vcc pin does not have power. That's why I suspect that some part of the PCB is not getting power which is supposed to be there even when the TV in on standby mode. There is power in the USB ports of the TV.. In most of the TV's I have seen the standby led and the optical jack are red.In the present case it is not. That's what I am trying to first get the optical jack power up.
                          • Chaks
                            • Sep 2015
                            • 115
                            • India
                            Can I use test points (TP) / JP to trouble shoot further. Can someone help me.
                            • Chaks
                              • Sep 2015
                              • 115
                              • India
                              LG LOGO is displayed before or after the microprocessor lg engine lge101d is active .? Anyone has information on this.
                              • Chaks
                                • Sep 2015
                                • 115
                                • India
                                Referring to the connector P7501
                                ... the Pin 14 is at 3.3 volts when the TV is switched on (blue std_by light) this pin is Error_Out (output) to IC LGE 101D Error_Out (input at gpio 41).
                                This Pin 14 is at 3.3 volts even when the P7501 connector is not connected to the LCD_PANEL.
                                Pin 14 is at 0.9 volts when the tv is in std_by red light mode.
                                Pin 13 is at 1.03 volts when the tv is in std_by red light mode.
                                When the tv is completely off the Pin 14 to pcb Gnd measures 5.0Mega Ohms.
                                Is this also normal. I have attached the pcb as well as schema for reference.
                                • NolesFan
                                  Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                                  by NolesFan
                                  Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                                  10-24-2024, 06:36 PM
                                • Takeatry
                                  Yet another Samsung QLED Boot Loop
                                  by Takeatry
                                  Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                  10-04-2024, 02:57 PM
                                • blaster_
                                  Samsung UE49MU6105K - boot loop, horizontal lines
                                  by blaster_
                                  Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
                                  Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
                                  06-22-2022, 05:19 PM
                                • torchzack
                                  Samsung 55" TV - Boot loop but sometimes works fine - UE55MU6470U
                                  by torchzack
                                  Hi Team - just joined to see if anyone can offer some expertise in diagnosing an issue with a TV.
                                  I've done a few hours googling and youtubing but just seeing if anyone has any insight here. I got a 55" Samsung UE55MU6470U which seems to boot loop and then after 10 mins will boot, work for a few minutes, then turn off and repeat.
                                  Whilst it's on into the normal Samsung menu/boot screen it looks perfect - so I can't see there being any screen issues. I've seen lots of videos with taping across clock lines to diagnose which particular one may be an issue but i don't...
                                  08-28-2023, 07:42 AM
                                • No Lan
                                  [Macbook pro A1708] [Boot loop] [Trackpad ?]
                                  by No Lan
                                  Hey everyone,
                                  Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
                                  Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
                                  Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only...
                                  05-24-2025, 03:09 PM
