[Macbook pro A1708] [Boot loop] [Trackpad ?]
  • No Lan
    • Apr 2025
    • 15
    • FRANCE
    Hey everyone,
    Usually, I'm not the type to ask for help, but this time, I'm calling on your wisdom and expertise I've seen what this community can do, so I'm pretty sure you guys can help me out.
    Here's the deal: I noticed my MacBook got stuck in a boot loop. After opening it up and doing some initial troubleshooting, I found that the boot loop stops only when the trackpad is unplugged.
    Now, just so you know, the trackpad actually works — I tested it with another motherboard and it's all good. Same for the cable, no issues there. The problem is only with this motherboard (820-00840).
    Another weird thing I noticed: when the trackpad is plugged in, the fan doesn't spin. But when it's unplugged, the fan runs just fine.
    I checked with L4800 and C4800, no shorts. Also got 5V on PP5V_S4_TPAD_CONN.
    Honestly, I'm a bit stuck on what to do next to find the root cause.
    Oh, and important to mention: I did something I probably shouldn't have, but I wanted to test it out — I waited for the Mac to boot without the trackpad, then plugged the trackpad in hot.
    It worked for about 20 seconds before it rebooted again.
    So yeah, that's the situation! Looking forward to your bright ideas! Thanks a ton
  • mon2
    • 16111
    Review the voltage to ground of the I2C lines on the trackpad connector. These are SCL / SDA.
    • No Lan
      • Apr 2025
      • 15
      • FRANCE
      Thanks you for your reply
      I found these 2 lines on the boardview for J4801 TRACKPAD
      SMBUS_SMC_3_S0_SCL --> 3.3V
      SMBUS_SMC_3_S0_SDA --> 3.3V
      Do i need to make furher test on it ?
      Click image for larger version  Name:	image.png Views:	0 Size:	127.8 KB ID:	3644891
      • mon2
        • 16111
        Also, pins 8 and 12.
        Post the voltage measurements to ground of each TPAD_*** signal.
        • No Lan
          • Apr 2025
          • 15
          • FRANCE
          Okey,
          just to be sure, i'm taking measurement without Keyboard and trackpad connect. Is that good ?
          KBD_I2C_SDA --> just after connect USB-C it slowly going from 0 to 1,50v-1,84v --> not stable
          KBD_I2C_SCL --> just after connect USB-C it slowly going from 0 to 1,50v-1,84v --> not stable
          TPAD_SPI_INT_L --> 3,29v
          TPAD_SPI_MOSI --> 0v
          TPAD_SPI_CS_CONN_L --> 3,33v
          TPAD_SPI_MISO --> 0v
          TPAD_SPI_IF_EN --> 3,33v
          TPAD_SPI_CLK --> 0v
          TPAD_VIBE_L --> 0v
          i also noticed something strange. On PP5V_S4 (L4800) i measured 8-9v and sometimes strictly 5v
          Sometimes the Mac boot with trackpad sometimes bootloop..
          • No Lan
            • Apr 2025
            • 15
            • FRANCE
            Just because I measure 9V on PP5V_S4 one times, should I be concerned that U7650 might be malfunctioning sometimes? Or is it not handling the voltage as expected?
            • mon2
              • 16111
              What is the current draw for this logic board? Are you at a stable 20v? If not stable 20v, review the article on the internet for the 'CD3215 and 20v'.
              • No Lan
                • Apr 2025
                • 15
                • FRANCE
                I'm fully stable 20v and between 0,4 and 0,8A without batterie connected.
                • mon2
                  • 16111
                  Do you ever see the Apple logo or hear the boot chime in any of these attempts?
                  What is the voltage to ground of PPBUS_G3H? ALL_SYS_PWRGD?
                  • No Lan
                    • Apr 2025
                    • 15
                    • FRANCE
                    Just to clarify
                    if trackpad is disconnected --> Mac boot with fan --> Logo Apple --> Screen for user authentication --> Stable
                    If trackpad is connected --> Mac boot without fan (fan work only for few second) --> Logo Apple --> Boot loop OR Mac boot without fan (fan work only for few second) --> Logo Apple --> Screen for user authentication crash and restart
                    for your question
                    PPBUS_G3H--> 13,2v
                    ALL_SYS_PWRGD --> 3,23v
                    • mon2
                      • 16111
                      What is the motherboard that works with this same trackpad with the same cable? Is it the 820-00840?
                      • No Lan
                        • Apr 2025
                        • 15
                        • FRANCE
                        Yes it is the exact same motherboard 820-00840
                        • mon2
                          • 16111
                          With the trackpad disconnected, you should have a high fan spin since the (trackpad) thermal sensors are not being detected. Is this correct? You can review the other working board for the expected high fan spin condition.
                          • No Lan
                            • Apr 2025
                            • 15
                            • FRANCE
                            I agree with you.
                            with the 2 motherboard (the one for this post and the other working well) i have a high fan speed when trackpad disconnected !
                            • mon2
                              • 16111
                              Boot into SAFEMODE with the trackpad connected.
                              To start an A1708 MacBook Pro in safe mode, you need to restart the computer and press and hold the Shift key until the login window appears. Once logged in, you can verify safe mode by checking the System Information app.
                              Does this trackpad with the same cable function with this (non-working) logic board?
                              Review the mating connectors for possible dry solder or lifted pin on the SMD joints.
                              • No Lan
                                • Apr 2025
                                • 15
                                • FRANCE
                                I cannot connect as the system keep restarting before or during login windows :/
                                even when starting in safe mode
                                • mon2
                                  • 16111
                                  Remove all power. Meter in resistance mode. Mate the trackpad to this board.
                                  Measure the resistance to ground of:
                                  PP5V_S0_FAN
                                  FAN_LT_PWM
                                  FAN_LT_TACH
                                  • No Lan
                                    • Apr 2025
                                    • 15
                                    • FRANCE
                                    Here the result
                                    PP5V_S0_FAN --> 1,8
                                    FAN_LT_PWM --> OL
                                    FAN_LT_TACH -->OL
                                    • mon2
                                      • 16111
                                      What are the units of measurement?
                                      PP5V_S0_FAN --> 1,8
                                      1R8 ohms to ground?
                                      • No Lan
                                        • Apr 2025
                                        • 15
                                        • FRANCE
                                        Sorry i was in diode mode.
                                        Multimeter on 2000K ohms and i observe between 220 and 240 on PP5V_S0_FAN. took on C4870
                                        FAN_LT_PWM --> OL
                                        FAN_LT_TACH -->OL
                                        • AverageChipmunk
                                          Trying to use a MacBook Air A1370 (2010) trackpad with a Raspberry Pi 5 over SPI
                                          by AverageChipmunk
                                          Hi all, I'm working on an art installation and want to use a salvaged MacBook Air trackpad as an input device for my Raspberry Pi 5. I've made *some* progress but I'm stuck on what I believe is an incorrect or unverified pinout. I'm quite new to this, so please bear with me! Would love input from anyone who has done something similar.
                                          The Hardware:
                                          - Raspberry Pi 5
                                          - MacBook Air 11" A1370 Late 2010 trackpad (part number 821-1110-A)
                                          - 14-pin FFC connector on the trackpad
                                          - 14-pin FFC breakout board
                                          - 5V → 3.3V buck converter powering...
                                          04-11-2026, 09:17 PM
                                        • master_haze86
                                          no boot: macbook A1708 EMC3164 820-00840-A
                                          by master_haze86
                                          Good day everyone.
                                          I got a macbook a1708 emc 3164 in the shop with an 820-00840-A logic board that won't turn on, with nor without the battery and would greatly appreciate help in finding the fault.
                                          Checking voltages in boot-sequence:
                                          1) [p:F3000] 5V VBUS PRESENT @ 5V
                                          2) [n:UPC_XA_GATE2] and [n:UPC_XA_GATE1] 7~10V GATE 1: 10V GATE 2: 7V
                                          3) [n:PPDCIN_G3H] 5V PRESENT @5V
                                          4) [p:R7075:1] (VDDA) to [p:R7075:2] (VDDP) and ensure R7075 is 4R7 CORRECT @ ~4.7 OHM
                                          5) [n:PM_EN_P3V3_G3H] signal from [p:U7000] to [p:U6990:10] PRESENT @ 5V
                                          02-24-2026, 09:28 PM
                                        • swoopy
                                          Macbook Air M2 (A2681) - Water - Keyboard + Trackpad Haptics + Speaker
                                          by swoopy
                                          to begin with: i'm a complete newbie.
                                          I have a Macbook Air M2 A2681 with water damage. Cleaned with alcohol and removed one USB Connector as there was a short (1). System works, except for: keyboard is not working, haptics of trackpad are not working + right Speaker not working. The Lid Angle Sensor was corroded, but seems to work fine (put's the system to sleep, display will turn off and backlight will also go off when the screen get's closed)
                                          I swapped keyboard, trackpad (+cable), speaker didn't change anything, so should be a board issue Questions:
                                          1....
                                          04-24-2026, 10:34 AM
                                        • Bradonis
                                          MacBook Air M3 15" 130C.FFFF Trackpad issue?
                                          by Bradonis
                                          Hi there, I have replaced the NANDs if my MBA M3 "successfully" to 2TB.
                                          I have the Problem, that when I try to restore the Macbook, it goes beyond the "update NAND" process, but fails when updating the sim chip from the Trackpad/ keyboard. so the whole DFU restore process is failing with the Code: 130C.FFFF.
                                          When checking the log created by the finder there is this "Main"? Problem:
                                          I tried it with a 100% working trackpad from another M3 MBA 15" so when there would be a problem with the trackpad itself, this should have solved my...
                                          03-30-2026, 02:08 PM
                                        • cyber47
                                          Macbook Pro A1706 (820-00923) no boot if display or Trackpad connected
                                          by cyber47
                                          i have used the search function but i doesnt found my problem.
                                          I am reparing a MacBook Pro A1706 with the Boardnumber 820-00923-A.
                                          If i have the display and/or the trackpad installed the Macbook does not boot, i have 20V and 0.03 Amps at the charger (without the battery connected), i can post a video of the Amperemeter if this helps.
                                          The board has PPBUS_G3H and it seems it is in the S5 state (i have the voltage on the S5 rails but not on the S4 rails).
                                          If i connect the charger without die display and the trackpad installed...
                                          12-20-2022, 02:57 PM
