Sony SMPS No backlight
  • ljintexas
    LJinTexas
    • Jan 2015
    • 669
    I am gettiing signal from main. I am getting audio but no backlight. Both Q302 and D307 were shorted. I have a parts board that drives backlight but has an issue running more than an hour or two. Replaced Q302 and D307. Still no backlight. Transformer winding resistance is very similar, nothing way out of whack. I can buy a board but this is a learning opportunity.
    Suggestions on next steps?
    LJ
  • R_J
    • 9623
    Re: Sony SMPS No backlight
    Have you checked R317, R314 & R316? Q301 could also be damaged.
      Model of the TV will help.
      • ljintexas
        LJinTexas
        • Jan 2015
        • 669
        I am sorry Bud. It is a KDL40S4100 Sony Set.
        • ljintexas
          LJinTexas
          • Jan 2015
          • 669
          Half of the zener diodes in that section do not give me a tone and read over .7 volts forward. Is that normal? It's the same on both boards.
          • ljintexas
            LJinTexas
            • Jan 2015
            • 669
            All of those show resistance values and Q301 tests good with a meter..also, all fuses in this area test good.
              • 12328
              • U.S.
              Have one of these working in the basement, with the back off, if you need any voltage tests for comparison let me know.
                I asksed Dannyx to see if he can provide the info.
                https://www.badcaps.net/forum/showthread.php?t=73237
                  Are you 100% sure that fusible resistor R317 is good and it shows really low Ohm?
                  Q302 for the inverter circuit tested a shorted, was it shorted between Gate and Drain?
                  • R_J
                    • 9623
                    This should help
                    • Dannyx
                      CertifiedAxhole
                      • Aug 2016
                      • 3912
                      • Romania
                      I'll provide the original service documentation but it's for the 4000 model so take it with a grain of salt - Sony doesn't seem to provide any resources for the 4100 model specifically.
                      I once had an issue with a similar setup (except it was a Samsung I believe) where that "balancer" board on the left (left according to the manual at least) was powered by some transformers which looked like ordinary HV transformers...but they were located on the power board and there were HV leads running between the two board, so I thought "that's a freak setup...which one is the damn inverter ?!" Thanks to some of the wonderful people here I was straightened out and the whole principle of a "balancer" was explained to me better. I believe Budm was kind enough to provide some documentation on this.
                      The problem wasn't there however, instead: bad capacitor on the power supply - the big 450v one, as those HV transformers feeding the balancer are powered straight off the 400v PFC bus. True, it was a lot easier in my case since nothing was blown, the TV was having obvious trouble starting up and the cap was ever so slightly bulged, but here it's completely different...still, if you have a different board, try a swap on that cap just for the sake of it (and an ESR/capacitance test also for the sake of it). Good luck....CFLs need to die, I hate'em !
                      Wattevah...
                        I think OP needs to provide the pictures of the whole backside of the TV showing all the boards.
                        • ljintexas
                          LJinTexas
                          • Jan 2015
                          • 669
                          I will verify this evening Bud as well as put up a pic of all boards at once.
                          Q302 fail = all three legs shorted to each other
                          LJ
                            LJ
                            You need to verify that the parts connected between Gate of the MOSFET's and the Isolated Gate drive transformer (T302) are not damaged.
                            BTW, at this you do not even see the backlights flash on for seconds even though the BL-ON is present and you do have PFC Boosted Voltage of around 380 ~ 400VDC between the two legs of the main filter cap, correct?
                            • ljintexas
                              LJinTexas
                              • Jan 2015
                              • 669
                              R317 reads 3 meg ohms and change in circuit.
                                Well, R317 (white body) is bad then, in post 6 you indicated that it is tested good.
                                • ljintexas
                                  LJinTexas
                                  • Jan 2015
                                  • 669
                                  Nary a flash Bud. Yes BL-ON is present and I have 384 volts PFC voltage across main filter caps.
                                  I have now replaced R317 which reads .2 ohms. Tested all resistors and diodes in the area between gate of MOSFETs and T302. Q301 and Q302 test good with meter.
                                  I will give it a shot this evening and reinstall board.
                                  Thank You very much for your help!
                                  LJ
                                  • Dannyx
                                    CertifiedAxhole
                                    • Aug 2016
                                    • 3912
                                    • Romania
                                    At the end of the day it could be a bad lamp, though I believe it should at least flash or something.....
                                    Wattevah...
                                      LJ
                                      So the inverter circuit did not even try to fire up the lamps so you need to do more in-depth troubleshooting in the inverter section. You do have PFC Boosted Voltage, correct?
                                        • 12328
                                        • U.S.
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • DanPoka
                                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                                          by DanPoka
                                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                                          02-15-2025, 05:05 AM
                                        • Comp_Pro
                                          No Backlight Macbook A1990 820-01041
                                          by Comp_Pro
                                          Hello all,
                                          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                          Tests performed:
                                          There is no backlight even with a good screen.
                                          Backlight IC is receiving the correct support voltages.
                                          Fuse F8400 ok
                                          Current sense resistor R8400 ok
                                          Backlight IC is receiving 3.3V on enable pin.
                                          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                          Backlight IC receiving 5V from PP5V_G3S
                                          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                          05-06-2024, 10:23 PM
                                        • DKWS89
                                          Sony XBR 49x900E - Sound and backlight on but no picture
                                          by DKWS89
                                          Hey Guys,
                                          So a few months ago my Sony XBR 49x900e TV screen stopped displaying the picture but the backlight comes on and I still get sound when I use the remote and navigate to certain apps. I haven't checked anything with the meter yet but started with ordering some replacement boards. I've tried replacing the BMKS board (used from ebay) and also completed the firmware upgrade based on Nicks TV repairs youtube video. I've also replaced the TCON (twice) and PIB.
                                          All of these changes have resulted in the same issue with no picture. I've also tried disconnecting the ribbons...
                                          12-14-2023, 04:30 PM
                                        • Audeze
                                          Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                                          by Audeze
                                          I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                                          Does...
                                          10-06-2024, 08:54 PM
