LG 55LD650 Display Good Won't Load Past LG Boot Screen.. Firmware??
  • Michale32086
    • Nov 2011
    • 1453
    Another firmware question....
    Got a really nice LG 55"... Powers up, backlights good.. Freezes at the LG Boot Up logo....
    I am thinking firmware issue..
    I have another identical board that has a display issue.. Thinking (hoping) that the firmware is good..
    Now to identify the firmware chip...
    Inspecting all the chips, an IC # caught my eye..
    24C02RP
    Turns out it's an 16Kbit, 8Kbit, 4Kbit, 2Kbit and 1Kbit Serial I²C bus EEPROM
    Would that be my firmware chip???
    • 12145
    • U.S.
    Re: LG 55LD650 Display Good Won't Load Past LG Boot Screen.. Firmware??
    Wonder if this model could have same problems as this e55? something to check maybe. https://www.badcaps.net/forum/showthread.php?t=53880
    • Michale32086
      • Nov 2011
      • 1453
      Don't think that's it.. I have had those B2 problems as well... But with mine, it was completely dead.. This LG comes up and works fine.. Just can't get past the bootup logo...
      Thanx for the reply...
      • syaoran123
        • Jun 2014
        • 178
        Common problem with the XXLD560 and XXLD650 series.
        Reflow that square chip in the middle under the heatsink using a heat gun. If youre not sure how, im sure theres tons of other threads with the same problem.
        • Michale32086
          • Nov 2011
          • 1453
          I would not have thought a reflow would be a possibility..
          I am a BIG fan of reflows.
          I'll give it a shot and report back..
          • Michale32086
            • Nov 2011
            • 1453
            Well, I'll be deep'ed in sheet!! It worked!!
            Never would have thunked that...
            Many thanks...
            I gotta say.. Working on a TV outdoors in this adds a whole new exciting Degree Of Difficulty..
              • 12145
              • U.S.
              How long did you cook it?
              • Michale32086
                • Nov 2011
                • 1453
                Got it up to around 230c for 90 seconds with an infrared pre heater..
                • syaoran123
                  • Jun 2014
                  • 178
                  Glad to know you have the tools and ability to reflow.
                  However it's known that the problem often re-occurs. The initial cause is cracked solder joints under the BGA chip due to heat stress and a reflow is only a temporary fix.
                  LG used a small heatsink poorly contacted with tape adhesive for the cooling mechanism. You might want to use a liquid thermal adhesive instead to make good contact with the heatsink. And even better, swap the original heatsink for a larger one. Bear in mind that a larger heatsink might interfere with placing the rear panel back on.
                  • Michale32086
                    • Nov 2011
                    • 1453
                    Thanx for the info.. Yea, as I mentioned, I am a BIG fan of reflows..
                    Got my rig back when the XBOX RROD was the big thing.. Was tickled pink when I realized it could be used for laptop MBs with BGA issues and TV Main Boards..
                    I think I put about $400 into that rig 10 years ago and it has paid for itself a hundred times over..
                    Thanx again for the advice..
                      • 12145
                      • U.S.
                      Thanks, that bigger better thermal pad sounds like a good course to take, thinking about doing that with my 42 lg before it even starts to act up. Hard to beat the picture on LGs, I think its even a little better than my sony and samsung.
                      • Michale32086
                        • Nov 2011
                        • 1453
                        Yea... As a repair tech, I LOVE LGs.. That one series that always has the LED strips going out... That's a big chunk of my business..
                        Yea, but LGs do have a great picture..
                        • throwaway327
                          by throwaway327
                          Model No: RC72LA
                          Serial No: SBNVKD001014459
                          06-18-2025, 05:52 PM
                        • privato89
                          Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                          by privato89
                          I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                          Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                          Let's begin:
                          Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                          03-26-2024, 06:37 AM
                        • Logix_UK
                          A2159 will not boot past Apple Logo
                          by Logix_UK
                          Hi Everyone. I have a Mac for a topcase replacement. I have completed the job however the Mac will boot and I get the startup chimes but not pass the Apple Logo, not even a progress bar. After a few seconds the fan spins fast. The board is 820-01598-A. I have disconnected everything except the USB ports and display and the issue persists. I am drawing 20.42v and .461A with just the screen connected so it looks like it is booting. I have looked over the board with a scope and I do not see anything that appears wrong. I can not get into diagnostics, NVRAM reset or DFU. The only issue is the topcase...
                          10-17-2024, 03:32 AM
                        • TheUser
                          Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                          by TheUser
                          Hello to everyone ,
                          This is my first post here, and i would like to share with you a small story in case you can help me.
                          Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                          All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                          I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                          02-10-2024, 02:07 PM
                        • Luke Anders
                          Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                          by Luke Anders
                          A few details about the laptop itself:
                          Name: Lenovo Legion 5
                          Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                          BIOS Version: GKCN60WW
                          EC Version: GKEC65WW
                          Serial Number: PF39AQ7Z
                          Board Model: NM-D562 Rev 3.0
                          RAM: 16GB Installed, DDR4 (brand new)
                          NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                          I bought this laptop recently from eBay as a faulty device....
                          10-12-2024, 05:13 AM
