Toshiba 40rl958 power issues
  • Jvel
    • Nov 2017
    • 24
    • Wales
    Hi all hopine someone can help me I have this tv and screen lights up but no but is blank no response from tv buttons or remote and have a solid orange standby light. Can anyone advise on what to do or try next please and thank you.
  • nomoresonys
    • 12268
    • U.S.
    Re: Toshiba 40rl958 power issues
    First thing I would try is a firmware update/reapply.
    • nomoresonys
      • 12268
      • U.S.
      Could try to reset, one thing to try, unplug tv for 5 minutes then plug back in. another thing to try, hold down power button for 10 seconds then release. 3: with tv powered on unplug from outlet, if condition stays the same, go with a firmware update if possible.
      • Jvel
        • Nov 2017
        • 24
        • Wales
        Thank you will have to go with a firmware update. Would you happen to know where I can get the firmware from had a quick Google to nothing I can see at the moment.
        • nomoresonys
          • 12268
          • U.S.
          A lot of times its hard to find, I'm pretty sure the manufacturers take them down off their sites pretty fast, I think their "stupid logic" is if you can't fix your tv you will turn around and buy another from them, when sometimes thats all it needs. A good thing to do for every tv owned, that is if the firmware is still on their site, would be download it and keep it in a safe place, where you can always access it.
          • nomoresonys
            • 12268
            • U.S.
            Guess you could contact toshiba, tell them you are not able to get the update over the internet, maybe they will email it or something?
            • nomoresonys
              • 12268
              • U.S.
              Try this, I think the last letter in your model is B right? so you would use B. http://www.dl.toshiba.com/tsb-dtv/NA.../40RL958B.html
              • nomoresonys
                • 12268
                • U.S.
                Heres the previous page too. http://www.dl.toshiba.com/DLY/index....ion=GB&lang=EN
                • nomoresonys
                  • 12268
                  • U.S.
                  And the google search. https://www.google.com/search?q=http...nt=firefox-b-1
                  • Jvel
                    • Nov 2017
                    • 24
                    • Wales
                    Thank you. I'm going to give it a go when I'm home from work will let you know how it goes
                    • Jvel
                      • Nov 2017
                      • 24
                      • Wales
                      Well I tried and tried the firmware update and still no response.
                      • nomoresonys
                        • 12268
                        • U.S.
                        If you followed the update procedure just like directed and no luck, I'm thinking it's a faulty mainboard.
                        • nomoresonys
                          • 12268
                          • U.S.
                          Check if you have 12 volts on each side of the fuse on the tcon board, fuse will have a label next to it Fxxx, negative probe on a ground.
                            I t may help if you upload good clear pictures of the whole back side of the TV showing all the board and then good clear straight shot of the whole top side of the main board.
                            What kind of Voltage testing have you done on the power supply board and the main board? Results?
                            • Tynan Dill
                              by Tynan Dill
                              Assuming...
                              11-22-2024, 01:46 PM
                            • PantherDave
                              by PantherDave
                              Hi all!
                              05-29-2024, 02:01 PM
                            • GLISIT
                              by GLISIT
                              01-16-2025, 02:29 PM
                            • cheeky2
                              Toshiba 49U7763DB (Mainboard: Vestel 17MB120) firmware issues after sporadic power cu
                              by cheeky2
                              I have this Toshiba 49U7763DB Tv which was suffering issues after various electrical power cuts, which happened in quick succession
                              Originally the TV was powering on and then very shortly powering off. I managed to get into the menu structure before powering off and carry out a first time installation of the TV. Which didn't make much difference. I have managed to factory reset (that didn't make any difference either).
                              The firmware inside the 17MB120 is corrupted and is causing some strange issues so my question is does anyone have any suitable firmware for this model?
                              Details:...
                              08-17-2023, 04:34 AM
                            • zlr8r
                              Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
                              by zlr8r
                              hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
                              Ill try and give as much info as I can.
                              Dell Inspiron 17 (7786) Laptop
                              Service Tag: 5J0NHT2
                              Bios: 1.9.0
                              When I received this , it would only flicker on the KB backlight for a second, then off and on.
                              Then it started getting weirder!
                              Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
                              12-12-2023, 09:31 PM
