Panasonic TX-L32E6B goes off after a few seconds
  • STick220
    • Nov 2018
    • 4
    • United Kingdom
    Evening all,
    I have a Panasonic TX-L32E6B which has started switching off after a few seconds, I have made a video of the problem here: https://m.youtube.com/watch?v=bIpJmBxek4Y I just wondered if anyone has any ideas of where I can start diagnosing this? I have tried holding down the buttons on the back to do factory reset but it made no difference. Also tried the basics like disconnecting any connected accessories and leaving the TV unplugged for 24 hours. Any help would be much appreciated.
  • bobbyskillz
    • 76
    Re: Panasonic TX-L32E6B goes off after a few seconds
    I can't tell if that dark spot midway up the left side of the screen is actually present (bad LEDs?) or if the shadows and reflections are playing tricks. Can you confirm this dark area is present on the screen?
      It looks like some of the LED's are not on, more likely to have fail backlight sLED, this is edge-lit panel.
      • STick220
        • Nov 2018
        • 4
        • United Kingdom
        Thanks for your advice. I have rechecked the TV today and the dark spot is present for real, not just in the video. I looked at some videos on replacing the edge LED strips (not for the exact model though) and I think it might be beyond my capabilities - I'm ok at soldering work but this looks like a complete strip down.
        • steviewonder
          • Dec 2013
          • 183
          • england
          Usually the red power led blinks once, then pauses with a LED failure on these later models.
          • STick220
            • Nov 2018
            • 4
            • United Kingdom
            Just to close this one off, you were all correct in your suspicions of an LED failure. I ended up taking it to a local repair shop who completed the work for around £50. Thanks to everyone who contributed.
              • 12206
              • U.S.
              Good price, we need more repair shops like that in the U.S.
              • PanasTC
                Panasonic TC-60CX800U turns off after 2 seconds.
                by PanasTC
                Panasonic TC-60CX800U with Power board: TNPA6060 1P
                The TV starts, the LED lights blink for 2 seconds, and the TV turns off; I tested the voltages on the powerboard, and it looks ok.
                Also, I could see HDM in the top corner for a second.
                Is it possible that the issue is a bad LED light that forces the TV to turn off?​
                11-27-2023, 09:02 PM
              • APOPAP
                Panasonic National NV-M3 VHS Camera shuts down after some seconds
                by APOPAP
                Hello everybody,
                First post here. I have been reading posts here for some time now, but today I made my first account and post.
                The same question is also posted on another site, here it is:
                Just found an old Panasonic National NV-M3 VHS Camera without the original charger but with a special bag with a led, switch and fuse that is designed for a lead-acid 12v 6Ah battery. It has two cables coming off the bag that leads to the camera terminals (Only + and - ). Pretty sturdy design I think.
                I tried connecting it to a Computer PSU (12.7v) but I get battery error...
                Today, 10:12 AM
              • Andre Gilbert
                by Andre Gilbert
                Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                11-20-2024, 08:52 PM
              • zklgfs
                Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                by zklgfs
                I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                08-11-2025, 02:14 PM
              • twonk9098
                Lenovo Legion 5 high fan spin turns off after 34 seconds
                by twonk9098
                I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
                I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
                I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
                I have tried a few new bios but exactly...
                07-14-2024, 11:19 AM
