Samsung UN58MU6100FXZA - Screen flickers and then black
  • robrpb
    • Nov 2018
    • 10
    I am new to this forum and I am looking for some help and guidence. My neighbor gave me a Samsung UN58MU6100FXZA tv, saying if I can fix it I have a tv. I have searched on the internet and I am unable to find a service/repair manual for it or any schematics for it.
    When I received it the tv did not turn on, nor did it have a standby light. I purchased a used, supposedly good board that was removed from a tv with a cracked screen off ebay. (The seller had a 100% feedback score, but I know thast is not a guarantee.) I installed the board and now I get a standby light and the tv turns on. The screen flickered shortly after powering on and then went black. I then did a factory reset and I updated the software. After a few minutes the screen starts to flicker and then goes black. It takes a couple minutes longer before it starts to flicker after the reset and software update. There is still sound when the screen goes black.
    If I put a flashlight next to the screen in a room with the lights off I can see images on the screen and hear sound. If I remove the cable from the power board to the main board the led backlights stay on with no flickering. I am thinking the main board is bad too, but before I replace it I am looking for your help and guidence in case I should be doing something else first. Thanks.
    Re: Samsung UN58MU6100FXZA - Screen flickers and then black
    "If I remove the cable from the power board to the main board the led backlights stay on with no flickering."
    If that is true then the power supply and backlights are OK.
    Can we see the pictures of the whole backside of the TV showing all the boards?
    • robrpb
      • Nov 2018
      • 10
      I will get a photo. There are two boards, the power board and the main board. There is no separate T-Con board.
      • robrpb
        • Nov 2018
        • 10
        Photo - back of tv
          • 12306
          • U.S.
          Mainboard there https://www.shopjimmy.com/samsung-bn...rsion-da01.htm
          • robrpb
            • Nov 2018
            • 10
            Thanks nomoresopnys. I'll order one.
              • 12306
              • U.S.
              No problem, hope it solves the issue, let us know how it turns out.
              • robrpb
                • Nov 2018
                • 10
                Just to let you know, I replaced the main board and the tv is working. Thanks for all your help.
                  • 12306
                  • U.S.
                  Nice, thanks for followup.
                  • ajshoe
                    ajshoe
                    • Dec 2012
                    • 477
                    • usa
                    have a very similar set UN58MU6070F. This set acts also the same way. completely dead unless I pull the pwr bd cable to main bd. then backlights come on and stay on. I have 9.8 V at standby - pressing power button does nothing. Is there anything else to check before ordering another main bd ?
                    Ordered one from TVpartstoday and it does the exact same symptoms as my original main bd.
                    • lotas
                      • Jan 2016
                      • 4789
                      • Russia
                      Flew the firmware "Standbay". (ic1604 - 25Q40)
                      • ajshoe
                        ajshoe
                        • Dec 2012
                        • 477
                        • usa
                        ?? don't inderstand
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4505
                          • Italy - Milan
                          bad thing hijack other threads.. also different symptoms
                          • ajshoe
                            ajshoe
                            • Dec 2012
                            • 477
                            • usa
                            back to the hi-jacked thread. My set is UN58MU6070F which uses a "near identical" Main bd. only difference is audio in and out with another HDMI port on the BN94-12410A.
                            UN58MU6100F uses BN94-12410A main bd and
                            UN58MU6070F uses BN94-12484X main bd.
                            either board will work in both sets.
                            does anybody have a fix for these main boards ? I have 5 of these bds with one of them turning on the tv but the pic is solarized with off coloring. The other 4 don't turn on the set (DEAD).
                            • HTR-Informatique
                              by HTR-Informatique
                              02-09-2025, 06:51 AM
                            • Mgiffune
                              by Mgiffune
                              06-09-2024, 10:28 AM
                            • howardc64
                              by howardc64
                              Problem
                              08-04-2024, 10:36 PM
                            • totof
                              Samsung UE50KU6070 black screen
                              by totof
                              I have my TV model UE50KU6070 which I am trying to repair.
                              BN41-02528A / BN94-10800C motherboard.
                              If I disconnect the motherboard from the power board, the backlight works. When the motherboard is connected the backlight works but the screen remains black.
                              When I plug the TV into the electrical outlet, the standby LED lights up but no reaction to an attempt to start it with the remote control for about 1 minute. During this minute the TV consumes about 20W.
                              After one minute the consumption drops to 0W and the TV can turn on with the remote control but...
                              09-26-2022, 02:34 PM
                            • VcemPzd
                              Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
                              by VcemPzd
                              Hello everyone !
                              My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
                              04-28-2025, 10:14 AM
