Sony KDL-55EX620, no stand-by volts from one bad resistor?
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    #101
    Re: Sony KDL-55EX620, no stand-by volts from one bad resistor?
    Voltage comes up to 4.44V with CN6101 detached from PSU
    4.44V on the 444th post. You have to be kidding me!
    They call me......."threadkiller"
    • R_J
      • Jun 2012
      • 9535
      Well something on the main is killing the ac_off_det line unless thats normal operation but it does'nt seem likely
      That line connects to ic9000 via RB9031 (100Ω)
      • DXseekerMO
        • Feb 2018
        • 1119
        • US
        #103
        That makes sense. So there's really nothing to short out on that circuit on the main board but the X-REALITY processor?
        EDIT: Just saw your addition to last post, will check schematic
        • DXseekerMO
          • Feb 2018
          • 1119
          • US
          #104
          While tracing down circuits near that resistor array I checked all 4 of them, I believe the reading in diode mode was .120
          So I guess that confirms a short in the X-REALITY processor, IC9000?
          • R_J
            • Jun 2012
            • 9535
            When checking resistors use ohm setting, not diode test, in this case the resistors are each 100Ω. If you check from ground to the one that is connected to the ac_off_det line it is likely close to 0Ω to ground
            If that line is LOW the ic believes there is a problem with the power supply so it won't allow it to be turned on
            • DXseekerMO
              • Feb 2018
              • 1119
              • US
              #106
              At what ground point should I measure, and on what side of the resistor?
              • R_J
                • Jun 2012
                • 9535
                You would use chassis ground or pin 1 of cn6002, You can find out which resistor it is by puting a probe on CN6002 pin 9 and check to each of the 4 resistors of RB9031. the point that is 0Ω is pin8, now check the other side (pin7) of the resistor to ground, that will check the input point (AE5) of the ic9000
                  STBY power supply is only 3.3V so I cannot see how you can have 4.44V at the collector of the Transistor which has resistor R6403 (8K2) between STBY3.3V supply and the Collector.. you better recheck your test.
                  AC_OFF_DET also feed connector CN6102 pin 7, anything connected to CN6102?
                  What did you use for GND ref. for the meter?
                  • DXseekerMO
                    • Feb 2018
                    • 1119
                    • US
                    #109
                    Sorry about the lengthly delay is replying. I wanted to check and re-check before posting more bad info.
                    Well R_J, it appears you are correct about one of those resistors being shorted to ground, Please see the attached picture, annotated with the ground point I used and findings at the resistors.
                    Can you tell me if I was grounded in the right spot? If I was I think the results are conclusive.
                    • DXseekerMO
                      • Feb 2018
                      • 1119
                      • US
                      #110
                      I will check and report back.
                      That is the AC_OFF_DET pin voltage at pin 7, CN6101 after unhooking the connector from the PSU
                        That is correct, just think about it, you have 3.3V power supply Voltage to run tha detection circuit and some how you are getting 4.44V (Collector) on the Transistors, how can that be?
                        • DXseekerMO
                          • Feb 2018
                          • 1119
                          • US
                          #112
                          No load from the mainboard?
                          Transistor shorted?
                          • DXseekerMO
                            • Feb 2018
                            • 1119
                            • US
                            #113
                            When testing at CN6101 pin 7? Chassis
                              Transistor shorted?
                              Well, look that circuit:
                              1) Where would 4.44V be coming from?
                              2) If Q6402 is shorted between E and C then how can you have 4.44V at the Collector with ref. to GND?
                              3) What Voltage do you get if you measure between C and E pin of that Q6402?
                              4) What Voltage do you get between CN6101 GND pin 9 and STBY3.3V pin 10? 4.44V? if it is then that is why you are getting that 4.44V reading.
                              5) The STBY3.3V is generated by IC6251 (NJM2884), the feeding Voltage is 4.67V Typ. as shown in the schematic, so with light load the STBY3.3V can be higher than 3.3V depend on how that IC6251 functions.
                                So if you connect the main board back in place and then check the resistance between Pin 7 (AC_OFF_DET) of CN6101 and the GND pin 9, what resistance do you get? This test will tell you what the load is being put on the AC_OFF_DET line.
                                • DXseekerMO
                                  • Feb 2018
                                  • 1119
                                  • US
                                  #116
                                  So if 3.3VSB comes from IC6251 and the feed voltage is 4.67typical then it seems to me IC6251 must have a short, passing all the input voltage instead of reducing it and sending it on?
                                  Infinity
                                    Infinity with main board connected back in place?
                                    If AE5 pin of IC9000 is shorted to GND then it should show about 100 Ohms.
                                    • DXseekerMO
                                      • Feb 2018
                                      • 1119
                                      • US
                                      #118
                                      Yes
                                        Infinity is not going to load that AC_OFF_DET line to be <1V.
                                        See picture on post 117.
                                        • DXseekerMO
                                          • Feb 2018
                                          • 1119
                                          • US
                                          #120
                                          So then IC6251 is short?
                                          • corrize
                                            Replacing resistor fuse in Sony DV charger
                                            by corrize
                                            Hello, I have 2 old chargers for Sony DV, and I found the same resistor fuse dead. Fuse is a crossing component : 0,47 Ohms (0,125W deduced because the lenght is 3mm). But I can’t find the same for buy.
                                            So, I want to replace by another like 0 Ohms, 1 Ohms 0,125W,
                                            It is the same please ? I guess it’s the same, the only change should be the time to burn ? Thanks...
                                            06-30-2025, 06:59 PM
                                          • x_orange90_x
                                            Sony Bravia KD-50X690E blown resistor
                                            by x_orange90_x
                                            I just picked up this tv yesterday and the previous owner said while watching tv he heard a loud a pop and then the screen went dark. I removed the back cover and found the source rather quickly; resistor R8601. A chunk of the ceramic had blown off exposing the inner wire. Due to the damage I cannot make out the colors of a couple bands. I likewise cannot find a datasheet for the power supply. I tried pulling up pictures of the same board online but the resistors have different colored bands which I half expected as I've had this happen before.
                                            The power supply is 715G8413-P01-001-0H2S...
                                            07-16-2024, 06:53 AM
                                          • rabbituk
                                            Sony HCD BX7700dbi CMT flashing standby
                                            by rabbituk
                                            I have got a Sony HCD-BX7700dbi that isn't worth a lot but I'm keen to learn how to repair and would appreciate some help with my train of thought. The protection circuit is kicking in and the standby light is blinking. It goes into protection mode within a second of powering it on.
                                            So far the relay on the power board that enables the main transformer clicks on and then off when powering on the unit. Looking at the schematics, the permanently enabled power rail called 'unreg sub' provides about 13.5VDC. Where the power comes into the main board on connector CN303, there is a diode...
                                            02-11-2025, 05:05 PM
                                          • jinu_j
                                            by jinu_j
                                            Hi
                                            05-03-2025, 10:51 PM
                                          • androripara
                                            Sony Bravia 55HX820 - 4 times blinking red standby led
                                            by androripara
                                            i am trying to repair a Sony KDL-55HX820 led TV which is throwing error code 4 (standby led flashing four times).
                                            I followed the troubleshooting flowchart at page 69, and between pin1 and pin7 of CN6002 i am reading 1.91V so i guess i can rule out the B Board as the culprit.
                                            Before ordering new G* Boards (by the way, should i change both? it is not specified in the manual) i wanted to try and do more advanced troubleshooting since i've read in other threads people resolving their problems on the 46/55 HX 820/823/825 models by replacing the Samsung led...
                                            10-19-2023, 05:16 AM
