LG 42LF561V No Video after backlight repair
  • zomi
    • Nov 2011
    • 509
    Re: LG 42LF561V No Video after backlight repair
    Take a torch and shine around the edge of the lcd panel and check for any hairline cracks.
    Do you have sound coming through ?
    • london-freddie
      • May 2015
      • 472
      No Scope in fact would not know where to start if I had one
      • london-freddie
        • May 2015
        • 472
        Can not see any screen damage and no sound
          Are you sure you get 0V at the Vin test point? Vin test point should be connected to the output side of the fuse (right terminal of the Fuse).
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            budm a question, in fault finding no picture issues is it possible too test if lvds signal/voltage is going from the mainboard to the tcon if so can this be measured with a multi meter or will only a scope show the signal/voltage thanks.
            • london-freddie
              • May 2015
              • 472
              Sorry budm missed that testpoint but I can see it on my picture, can not check now as away from home till monday (working), but will check it as soon as I am back home.
              Have got 13.3v at both ends of the fuse F1
              I did notice big chip U11 seemed to be very very very hot when powered on, barely touchable
              definately no voltages on any testpoints near the two ribbon connectors to panel
              I have ordered a replacement tcon board (used) which should also arrive for monday
                The LVDS will be very high and in mV range so DMM is not going to show anything much.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  #28
                  thanks budm will have a read
                    That may be a good way to try.
                    When you install a new T-CON, check the Voltages at those test points to see if they are present or not.
                    • london-freddie
                      • May 2015
                      • 472
                      Yes only a couple of pounds for the used tcon, so worth a try, will test voltages as soon as I fit it
                      Is it normal for that U11 chip to get so hot
                      • bman4
                        • Jul 2015
                        • 210
                        • canada
                        #31
                        Usually When a chip is to hot to touch its shorted .Ive read that shorted leds can take out a t-con . i thought that is what happened when i tried subing leds and they blew but not in my case. Possibly static discharge ect.
                        I would say try with the pannel disconected but think its irellavent.
                        • london-freddie
                          • May 2015
                          • 472
                          OK Good news just got home from work and Mr Postman had delivered me a used tcon, just fitted it and picture has come back to life. So tcon had failed, maybe as bman4 stated the shorted leds had taken out the tcon, but tv did have a picture before I replaced the leds
                          • Dan81
                            SNES-powered
                            • Oct 2013
                            • 1866
                            #33
                            I know it's a old thread but just wanted to share the same warning - if you have bad LED strips, take the connector out. The Heesung/AUO T-Cons are horribly sensible to bad LEDs.
                            As such, after replacing the T-Con, from a functioning TV sans backlight I have gone back to square one:
                            - new T-Con will NOT output any image regardless whether I take out one flex or another
                            - old T-Con also won't output image unless I take out the flex cable that goes to the left half of the screen
                            I suspect the old one might be salvageable, whereas the new one is as good as trash, likely. Would love some short insight from y'all before opening a thread. Same model btw, 42LF561V.
                            Main rig:
                            Gigabyte B75M-D3H
                            Core i5-3470 3.60GHz
                            16GB DDR3-1600
                            Samsung SH-224AB DVD-RW
                            Delux MG760 case
                            • triplefour
                              by triplefour
                              09-13-2023, 10:43 PM
                            • gl4709
                              Samsung un55cu7000d with backlight and sound No Video / Picture
                              by gl4709
                              I am working on a Samsung un55cu7000d which has backlights and audio. There is no picture. This model does NOT have a separate TCON board. Before I order a main board I would like to try and confirm that the issue is not in the display. The ribbon cable from the main board goes directly to the display and I can then disconnect the left from the right. When I disconnect the right side the display lights up on one side but has no video being displayed. Can you all give me some guidance on how to confirm the main board is the issue.
                              01-23-2025, 06:21 PM
                            • TR103
                              by TR103
                              - it keeps rebooting
                              01-22-2025, 04:12 PM
                            • Mgiffune
                              by Mgiffune
                              06-09-2024, 10:28 AM
                            • JaquesPratt
                              Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                              by JaquesPratt
                              I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                              This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                              07-16-2024, 01:04 AM
