Philips 55pfs8159 android tv bootloop
  • Diah
    • Feb 2013
    • 6335
    Re: Philips 55pfs8159 android tv bootloop
    Originally posted by Alschepmist
    If is a corrupted firmware how can i programm it? Can i use ch341a as isp programmer?
    with URAT low level 3.3V. you need to know what kind of cpu if its MediaTek there are tools you can find it at xda developer forum
    • ducky29
      • Dec 2015
      • 370
      • Europe
      Make sure you tried the firmware update correctly. Different models have different instructions so make sure you follow them correctly.
      • Alschepmist
        • Jul 2018
        • 70
        So i think iv founded the problem a corrupted firmware i think or bootloader
        with uart mode (iv new uart programator ) i become this code
        FATAL ERROR! There is no bootable image on this machine!
        Code:
        I2C switch set as 1
        --------- I2C Initialization ----------
        I2C_INIT: I2C-2 bus
        I2C_INIT: I2C-1 bus
        I2C_INIT: I2C-0 bus
        DDR reg 0xF7CB0BAC value : 0x00021421
        DDR reg 0xF7CB0C00 value : 0x00004031
        leakage info 464.
        set Vcpu to 1300mV, default setting by hardware.
        set Vcore to 1150mV, default setting by hardware.
        flash_ts_init() success.
        RDKDMP BG2Q [Oct 27 2017 18:04:12]
        Pinmux configuration:
        GSM 0xf7fcd040 0x009c0261;
        0xf7ea0014: 00000072 00240611 00000253 1249008a
        0xf7ea0028: 01249492 00000048 1ca54009 0430e44d
        0xf7ea003c: 00000000 00000000 0000001f 63c06a52
        Clock configuration:
         VCO_B     frequency 1620
         AVPLLB[4]   frequency 300
         AVPLLB[5]   frequency 800
         AVPLLB[6]   frequency 1680
         AVPLLB[7]   frequency 610
         cpuPll     frequency 1200
         memPll     frequency 1500
         sysPll     frequency 800
         dClk      frequency 375
         cpuClk     frequency 1200
         sysClk     frequency 400
         drmClk     frequency 400
         cfgClk     frequency 100
         gfxClk     frequency 400
         zspClk     frequency 400
         perifClk    frequency 200
         pCubeClk    frequency 610
         vScopeClk   frequency 610
         nfcEccClk   frequency 100
         vppSysClk   frequency 400
         appClk     frequency 800
         gfx3DCoreClk  frequency 420
         gfx3DSysClk  frequency 400
         arcRefClk   frequency 400
         vipClk     frequency 400
         sdioXinClk   frequency 200
         sdio1XinClk  frequency 200
         gfx3DShClk   frequency 420
         avif0Clk    frequency 300
         avif1Clk    frequency 300
        [00,sd00] bootloader: part1(start=0, blks=1, version=201710271804), part2(start=
        0, blks=1, version=000000000000)
        [01,sd01] fts: part1(start=32, blks=32, version=201710271804), part2(start=32, b
        lks=32, version=000000000000)
        [02,sd02] recovery: part1(start=64, blks=120, version=201710271804), part2(start
        =64, blks=120, version=000000000000)
        [03,sd03] tzk_recovery: part1(start=184, blks=8, version=201710271804), part2(st
        art=184, blks=8, version=000000000000)
        [04,sd04] factory_setting: part1(start=192, blks=128, version=201710271804), par
        t2(start=192, blks=128, version=000000000000)
        [05,sd05] itm: part1(start=320, blks=128, version=201710271804), part2(start=320
        [06,sd06] boot: part1(start=448, blks=24, version=201710271804), part2(start=448
        , blks=24, version=000000000000)
        [07,sd07] tzk_normal: part1(start=472, blks=8, version=201710271804), part2(star
        t=472, blks=8, version=000000000000)
        [08,sd08] system: part1(start=480, blks=1600, version=201710271804), part2(start
        =480, blks=1600, version=000000000000)
        [09,sd09] user_setting: part1(start=2080, blks=960, version=201710271804), part2
        (start=2080, blks=960, version=000000000000)
        [10,sd10] cache: part1(start=3040, blks=896, version=201710271804), part2(start=
        3040, blks=896, version=000000000000)
        [11,sd11] firmware: part1(start=3936, blks=64, version=201710271804), part2(star
        t=3936, blks=64, version=000000000000)
        [12,sd12] factory_data: part1(start=4000, blks=32, version=201710271804), part2(
        start=4000, blks=32, version=000000000000)
        [13,sd13] userdata: part1(start=4032, blks=3328, version=201710271804), part2(st
        art=4032, blks=3328, version=000000000000)
        get macaddr from fts:
        cpu id:38bdc6b3 5359eb9c
        macaddr=00:B3:53:59:EB:9C
        tzk boot with normal mode
        start to kick off SM CPU: start 0x3ff0449c, size 63216
        SM CPU is kicked [ of f .
         L 1as]It(pSoMwe)r:m eondte eirs mnaoint
        St[a nd b y 6]W(SM): Entering adc_init.
        [   10]W(SM): Leaving adc_init.
        [   13]W(SM): PWM Initialized
        [   16]I(SM): begin to run tasks
        [   509]W(SM): Joystick connected
        [3.019337] TZ CPU0 ERROR[tz_sw_verify_image:75] verify image fail, src=0x19c0000
        0, len=0x004c0c00, dst=0x19c00000GIH magic num is not correct (0x482a4d49 != 0xe
        ea8f2bc)!!!
        tbdzz---- Img_Ld_And_Start error! Spinning now!
        œëYS³Æ½8[   0] sys_init start. boot_strap=0x00000514 (source=eMMC), boot_state
        =0x0
        [  278] image verified, start at 0x00920000...
        tz kernel starting... MV88DE3114(BG2Q)-A1 total 4 cpus, v2.0.0.21, Aug 5 2014 1
        4:39:52
        0321[  333] start_bootloader
        UªULAUNCH_ITM is set to zero
        board_number = 6
        uiBoot = 0
        I2C switch set as 0
        • Alschepmist
          • Jul 2018
          • 70
          how can install new firmware with out recovery?
          • Alschepmist
            • Jul 2018
            • 70
            So now with extra tool i can acces emmc with my pc as any one a dump or recovery.img file?
            • samtron123
              • Dec 2012
              • 77
              • germany
              #26
              hello I have the same problems
              what hardware and software do you have ??
              can you please give a link
              Thank you
              • samtron123
                • Dec 2012
                • 77
                • germany
                #27
                nobody can help me ??
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  #28
                  I'd guess it's a RT809H programmer.
                  • Diah
                    • Feb 2013
                    • 6335
                    you need to tell us which chassis your Fillips ?
                    can you inter recovery mode?
                    how to inter recovery.. plug the TV out from the wall socket first
                    Hold and keep holding the joystick on the bottom of the TV in the "Down" position. then plug the TV in wall socket recovery mode should show on screen
                    here i posted mega link down load the file of wipe date as yours chassis and apply it with recovery as update from external storage.. then flash new firmware.
                    • samtron123
                      • Dec 2012
                      • 77
                      • germany
                      #30
                      Hello how many thanks firstly
                      unfortunately I do not get that far, I tried everything,
                      I come to nothing in recovery mode no screen is displayed
                      • samtron123
                        • Dec 2012
                        • 77
                        • germany
                        #31
                        Hello
                        What do you mean ?
                        • samtron123
                          • Dec 2012
                          • 77
                          • germany
                          #32
                          QV14.1E Chasis Modell 8159 2014
                          • Diah
                            • Feb 2013
                            • 6335
                            i think you are doing some things wrong to inter the recovery mode. you need keep press the arrow down at least for 10 seconds or little more then recovery mode will show on screen..
                            after that extract this zip and put it on usb to wipe data
                            watch this video how to do it
                            • samtron123
                              • Dec 2012
                              • 77
                              • germany
                              #34
                              277/5000
                              Hello, thank you
                              I have 3 minutes synonymous tried but no function or picture
                              is a dump file for the fact that I can flicker the TV manuel ??
                              I got an update after that does not start anymore and no picture just the background light is on Sound I still have :-)
                              if I come in menu then I can use the wipedatatool without menu is that too ??
                              • samtron123
                                • Dec 2012
                                • 77
                                • germany
                                #35
                                one more question what does he have as an additional tool for emmc where can i download these files ??
                                a dump and recovery.img ???
                                • samtron123
                                  • Dec 2012
                                  • 77
                                  • germany
                                  #36
                                  Hello everybody
                                  I have two folders on my USB stick. What kind of files are they?
                                  • Diah
                                    • Feb 2013
                                    • 6335
                                    Hello everybody
                                    1-this normal backup android system when it conected to any external storage device such USB or SDCARD. delete them both
                                    2- you are doing wrong with upgrade file.. format your USB as FAT not FAT32.
                                    3- make new folder on the root of the USB with name " upgrades " with out " "
                                    then put your file upgrade inside this folder.
                                    take your set out from AC then insert the USB in the set then plug it in AC
                                    • samtron123
                                      • Dec 2012
                                      • 77
                                      • germany
                                      #38
                                      Hello
                                      which file upgrade should I take ??
                                      I have no files?
                                      • Diah
                                        • Feb 2013
                                        • 6335
                                        Hello
                                        I have no files?
                                        i told you you are doing wrong....yours photo of the USB you have wrong file with .pkg
                                        android TV file format "autorun.upg"
                                        read this in German. and download yours chassis and model firmware
                                        this is your firmware
                                        after you download it.. extract it and rename it to autorun.upg put it on root of usb with out folder updrades i mentioned before... tv should be out from AC at least 1 minute then plug the usb in and turn on
                                        • samtron123
                                          • Dec 2012
                                          • 77
                                          • germany
                                          #40
                                          so far I have the data on USB stick but I do not see, because television does not have a picture or menu, just stay on the light, how can you start the update ??
                                          with this version I got the problem, can you take an older version ??
                                          FUS_AND1E_10.170_prod autorun_AND1E_000.010.170.000.upg
                                          many thanks
