Philips 40PFT4009/12 bootloop (TPN149E)
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    Started after unplugging power cable when TV was turned on. (remote control was lost and user didn't know where power button is located)
    So my first thought is firmware corruption.
    Tried autorun.upg and upgrade_loader.pkg on 16GB FAT32 MBR formatted USB stick but neither did anything. Maybe I just don't understand how to start them.
    When USB inserted and TV plugged in, it just starts up and continues bootlooping. When USB plugged in and I hold down power button when plugging TV in, it just doesn't do anything.
    Attached boot dump (at the end it just restarts and start over)
    Any tips on how to get USB upgrade to work or any other idea what's wrong?
  • lotas
    • Jan 2016
    • 4863
    • Russia
    What you need here is the service firmware and a USB flash drive no larger than 4 Gb.
    • RethoricalCheese
      • Mar 2013
      • 1519
      • Estonia
      I assume upgrade_loader.pkg is the service firmware, right?
      https://toengel.net/philipsblog/firmware-archiv/#2014 Which I got from here.
      • lotas
        • Jan 2016
        • 4863
        • Russia
        Yes, there should be a service name "upgrade.pkg". And whatever matches your chassis.
        • lotas
          • Jan 2016
          • 4863
          • Russia
          If the update does not pick up, then hold down the “OK” button on the remote control and insert the plug into the socket. Yes, on this chassis you can simply rename the update file from the official website to “upgrade.pkg”
          And a lot depends on the USB flash drive, you need an old one with 2-4 Gb.
          • RethoricalCheese
            • Mar 2013
            • 1519
            • Estonia
            Switched to 4GB. I see from logs that it does seem to see and mount it but still not upgrading. Got to find the remote then
            • lotas
              • Jan 2016
              • 4863
              • Russia
              Yes, you need a remote control.
              • RethoricalCheese
                • Mar 2013
                • 1519
                • Estonia
                Okay, I will get it tomorrow morning. Will update when it is tested.
                • RethoricalCheese
                  • Mar 2013
                  • 1519
                  • Estonia
                  Still no luck when pressing OK on remote while plugging TV in.
                  [APP_SHL_SWUpdate_VerifyUpdateFile(): 1399]SHL_SWUPDATE#no correct file exist!!!
                  I guess incorrect file?
                  Edit: Nevermind that, had another file on stick and forgot to plug in receiver cable Will continue soon.
                  • lotas
                    • Jan 2016
                    • 4863
                    • Russia
                    Chassis TPN14.1E LA?
                    • RethoricalCheese
                      • Mar 2013
                      • 1519
                      • Estonia
                      Yes.
                      But I found a strange way to fix this TV.
                      By holding down OK, at one point I could press other buttons and the TV would stay on. Half of the menus were missing/faulty but software update part was working. So I just used autorun.upg to rewrite software and that seems to have fixed it.
                      • Diah
                        • Feb 2013
                        • 6572
                        we wrote many time over here.... Philips with upgrade_loader.pkg will response for it noly if the USB stick formatted in MBR mode FAT32 !!
                        • RethoricalCheese
                          • Mar 2013
                          • 1519
                          • Estonia
                          Yes, you did not read my first post? It did not work. USB stick was detected, that was not the issue.
                          • nomoresonys
                            • 12330
                            • U.S.
                            Originally posted by RethoricalCheese
                            Yes.
                            You're saying you held ok and chose auto update from the tv menu?
                            • RethoricalCheese
                              • Mar 2013
                              • 1519
                              • Estonia
                              No. By pressing OK, it stopped bootlooping and I could see update menu seemed to work. So I replugged usb with correct update file and it detected the update file automatically.
                              • nomoresonys
                                • 12330
                                • U.S.
                                ok.
                                • zklgfs
                                  Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                                  by zklgfs
                                  I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                                  08-11-2025, 02:14 PM
                                • TheUser
                                  Thinkpad Docker G2 Type-C 40AS - Firmware Unknown
                                  by TheUser
                                  Hello to everyone ,
                                  This is my first post here, and i would like to share with you a small story in case you can help me.
                                  Docker Type-C Gen 2 - Model 40AS. Was given to me by a friend for free ,but with the problem that you cannot use the video output ports.
                                  All ports work , USB , Ethernet, Type C ... but HDMI + Display Port don't work
                                  I searched on reddit and google for problem similar to that, and a LOT of people had fixed this problem by updating the firmware. So i tried , i searched and found 1.1.13 utility and 1.1.20 utility that can help...
                                  02-10-2024, 02:07 PM
                                • gurj1979
                                  Ubiquiti firmware help. US-8-150W POE
                                  by gurj1979
                                  Hi guys.
                                  I've got a Ubiquiti US-8-150W POE switch which has issues with updating the firmware.
                                  Turned out to be a bad EEPROM chip. It would read the firmware and work as normal, but failed to write new firmware to it.
                                  So I took off the chip and read on EEPROM and saved it. Wrote to old chip and failed to write
                                  Got New chip and writes good.
                                  THE PROBLEM...
                                  It fails to fully load the firmware, POE lights fail to work during g firmware test during load. I'm suspecting bad EEPROM Read.
                                  Does anyone have a Good Firmware I can have?...
                                  07-22-2024, 05:13 PM
                                • ahmedtou
                                  HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                                  by ahmedtou
                                  help me please
                                  I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                                  When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                                  I will share all the details with you, including the disc information.
                                  Code:
                                  HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                                  Current Profile: BD-R
                                  Disc Information:
                                  Status: Empty
                                  State of Last Session: Empty
                                  Erasable: No
                                  Free Sectors: 12,219,392
                                  Free Space: 25,025,314,816 bytes
                                  Free Time: 2715:27:17 (MM:SS:FF)
                                  Next
                                  08-27-2025, 08:49 AM
                                • Slapito
                                  Request for EC firmware for MSI Vector GP66 12UHSO (MS-15441 ver 1.0)
                                  by Slapito
                                  I'm currently repairing an MSI Vector GP66 12UHSO laptop with a motherboard reference MS-15441 ver 1.0. The EC chip (ENE KB9548QF2) on the board appears to be damaged and needs to be reprogrammed.
                                  Can someone please send me the firmware (EC/Embedded Controller) or indicate where I can download the correct EC firmware version corresponding to this motherboard model?
                                  I already have access to the BIOS downloads on the MSI support page, but need specifically the EC binary or its equivalent firmware image.
                                  I already downloaded the BIOS update file from msi official...
                                  10-09-2025, 02:00 AM
