Samsung UE46B6000VW
  • StephenU
    • Dec 2013
    • 230
    • United Kingdom
    Re: Samsung UE46B6000VW
    Originally posted by Davi.p
    Not all well, i told to test point 2 again in VOLT...
    For the test on the DP1 anode to the GND it seems OK, maybe there is not a a signal to the near TPS65161 that enables AVDD. In the image under i have squared two test zones, one you can test if C_RP41 is connected to C_CP11 near it, then if you can test in volt RP21 and RP41 respect to GND.
    RP41 connected to CP11 - connection Good
    TP2 Voltage - with left ribbon unplugged - 12.59
    TP2 Voltage - with right ribbon unplugged - 12.59
    RP21 in Volts - -5.48v
    RP41 in Vola - 0.019
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4318
      • Italy - Milan
      Theese last test tells me more that AVDD booster is not switched on, for some reason, but not for a panel fault.
      Check the voltage on PIN 9 and 26 of the UP1. IF PIN 9 is low like zero and same for pin 26 then check the capacitor on the pin 26.
      • StephenU
        • Dec 2013
        • 230
        • United Kingdom
        Thanks you Davi.p I will do this tomorrow and let you know my results. Much appreciate you help/guidance on this.
        S.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4318
          • Italy - Milan
          The capacitor must be checked with a capacity meter or simply changed with one took from a board of same era and near same or little bigger volume.
          • StephenU
            • Dec 2013
            • 230
            • United Kingdom
            I have an LCR meter so will carefully remove and test at some point. Thanks
            • StephenU
              • Dec 2013
              • 230
              • United Kingdom
              #26
              Pin 9 - 0.019v
              Pin 26 - 0.019v
              I have a like for like known good tcon but I don't want to swap it incase this isn't the problem and it kills the good tcon.
              S.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4318
                • Italy - Milan
                #27
                I repeat: "IF PIN 9 is low like zero and same for pin 26 then check the capacitor on the pin 26", that is, desolder it and check its capacity. If it seems good change it anyway with one took from a unuseful board, same era, same or little bigger volume.
                • StephenU
                  • Dec 2013
                  • 230
                  • United Kingdom
                  #28
                  CALM DOWN - HAVE A SNICKERS 😉 👍🏼
                  Thanks Davi
                  S.
                    Originally posted by StephenU
                    Pin 9 - 0.019v
                    Pin 26 - 0.019v
                    I have a like for like known good tcon but I don’t want to swap it incase this isn’t the problem and it kills the good tcon.
                    S.
                    Check the resistance between circuit GND and those two pins, no power to the board of course.
                    • StephenU
                      • Dec 2013
                      • 230
                      • United Kingdom
                      #30
                      Will do Budm, will update results shortly.
                      Thanks.
                      S.
                      • StephenU
                        • Dec 2013
                        • 230
                        • United Kingdom
                        #31
                        Budm would the cct GND be the one i've Put a green circle round or GND on the Tcon? Sorry for the stupid questions, thanks for your time.
                        S.
                        • StephenU
                          • Dec 2013
                          • 230
                          • United Kingdom
                          #32
                          Current Findings.
                          GND on tcon board (BP) - (RP) to pin 9 = O/C
                          GND on tcon board (RP) - (BP) to pin 9 = 589 ohms
                          GND on tcon board (BP) - (RP) to pin 26 = O/C
                          GND on tcon board (RP) - (BP) to pin 26 = 744 ohms
                          (BP) - Black Probe DMM
                          (RP) - Red Probe DMM
                          TIA All
                          S.
                          • StephenU
                            • Dec 2013
                            • 230
                            • United Kingdom
                            #33
                            deleted
                            • StephenU
                              • Dec 2013
                              • 230
                              • United Kingdom
                              #34
                              S.
                              Current Findings.
                              TIA All
                              S.
                              Hi Budm any these readings help or shall i just remove cap on pin 26 and measure as previously instructed by Davi.p and replace.
                              Thanks for your time.
                              S.
                              • StephenU
                                • Dec 2013
                                • 230
                                • United Kingdom
                                #35
                                Hi, test theese points in Volt.
                                It lacks of the Avdd signal, Check in diode mode across C_DP1 and its anode to ground. Check this point two again after disconnecting one at a time of the tcon output cables.
                                Thank you Davi.p and others for their input, TV now repaired and up and running Tcon was the issue here.
                                S.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  #36
                                  Thanks for the update glad a replacement tcon fixed the issue.
                                  • triplefour
                                    Samsung UN55ES7003 has blown fuse on TCON and short to ground.
                                    by triplefour
                                    Samsung UN55ES7003
                                    made house call.
                                    red power led comes on, blinks twice, no display, no backlight, relay clicks, repeat.
                                    psu has self test feature.
                                    disconnected from mainboard.
                                    determined PSU ok BL ok.
                                    suspect mainboard.
                                    disconnecting tcon has no change on operation.
                                    markings on mainboard:
                                    BN97-06531P 0151
                                    BN94-06123R
                                    found and ordered replacement on ebay https://www.ebay.com/itm/394077328633
                                    for 54$
                                    second house call:
                                    with replacement mainboard, tv turns on, has sound,...
                                    07-13-2022, 03:53 PM
                                    09-07-2024, 05:50 AM
                                  • Chrissygizmo
                                    Samsung ue55hu8500t tcon board fuse blowing
                                    by Chrissygizmo
                                    Hi , I've got a Samsung UE55HU8500T that has sound but no picture, I've had it open and done a quick check of voltages etc, I found that the F2 fuse on the tcon board had blown (T-CON BOARD VD_STV5565EU22BC6LV0.3 -) so I replaced it with a similar value fuse but still nothing, ten I noticed the replacement fuse had blown too . I would appreciate any help with this. Thank you in advance...
                                    04-28-2021, 11:15 PM
                                    09-06-2024, 11:40 PM
