50LN5310 Burnt backlight
  • neilc6
    • Nov 2015
    • 1550
    This LED actually caught on fire burning the paper backing around it. The double side tape underneath it had become unstuck so the section of the strip was floating without any heatsinking. Luckily the paper reflector backing doesn't seem super flammable. There were about four other bad LEDs in this TV without visible damage. Once repaired, I checked the backlight setting and none of the inputs were at 100%. Though this is not a smart TV, I have found on the smart LN models, the media player and smart apps (Youtube, Netflix) may run the backlight at 100% by default.
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    Re: 50LN5310 Burnt backlight
    Some of these have the ability to apply backlight settings to all inputs. I had a 47LN5750 the same way, and in about the same location in the TV.
    They call me......."threadkiller"
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      With these LG TVs you need to reset the Backlight setting for each individual input.
      • neilc6
        • Nov 2015
        • 1550
        This is the worst I've seen so far 50LN5750. Burn marks on diffuser sheet as well which will need to be replaced if I come across one.
        • jjanssen7
          • Nov 2012
          • 252
          I may have some of those diffuser sheets depending where in BC you are.
          • neilc6
            • Nov 2015
            • 1550
            Got a cracked Samsung 50" but not sure if the diffuser from it will fit the LG. If anyone is repairing a LG 50LN or 50LA or 50LB and can give me the exact dimensions of the thicker plastic diffuser panel that is directly above the backlights, I would appreciate it.
            • jjanssen7
              • Nov 2012
              • 252
              I plan to have one apart tomorrow evening and can measure it. I also have a spare diffuser I've set aside for you... just haven't got out your way yet.
              • neilc6
                • Nov 2015
                • 1550
                I should have a 50 inch LG coming in today for a backlight repair so can compare the panels.
                • neilc6
                  • Nov 2015
                  • 1550
                  The Samsung diffuser panel dimension is an exact match for the LG one. 24 3/4" x 43 9/16"
                  • jjanssen7
                    • Nov 2012
                    • 252
                    This is the worst one I've seen... just pulled it apart yesterday.
                    • Unspun01
                      • Jun 2011
                      • 349
                      The 50LN5310 (non-smart) and 50LN5750 (smart) use the same panel.
                      I once used the backlights and LCD panel from a 5310 to repair a more valuable 5750.
                      Either way, that's some terrible damage you've pictured there... I've never seen an LED fail that catastrophically.
                        Not as bad as this one:
                        https://www.badcaps.net/forum/showth...ht=LG+47LN5790
                        Luckily the whole TV did not catch on fire.
                        This one is not too bad:
                        https://www.badcaps.net/forum/showth...ight=burnt+led
                        • triplefour
                          by triplefour
                          09-13-2023, 10:43 PM
                        • willis6732
                          Toshiba 55lf621c21 Dim Picture / Backlight afterbypassing a Burnt LED
                          by willis6732
                          This TV came in for a backlight Repair. I bypassed the Burnt LED as shown in Picture. I thought it was fixed and returned to customer. So I dont have the TV anymore, but customer says its not really watchable.
                          Now the TV Is much dimmer than before. It does a quick bright flash when it first turns on.
                          The Driver board looked pretty toasty in the LED Driver Area.
                          So I am wondering.. how can i Tell if this is a LED or Driver Board Issue?...
                          12-17-2024, 04:09 PM
                        • electomech-fixer
                          First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
                          by electomech-fixer
                          I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
                          I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
                          09-15-2025, 01:42 AM
                        • DanPoka
                          Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
                          by DanPoka
                          I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
                          Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
                          This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
                          02-15-2025, 05:05 AM
                        • Comp_Pro
                          No Backlight Macbook A1990 820-01041
                          by Comp_Pro
                          Hello all,
                          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                          Tests performed:
                          There is no backlight even with a good screen.
                          Backlight IC is receiving the correct support voltages.
                          Fuse F8400 ok
                          Current sense resistor R8400 ok
                          Backlight IC is receiving 3.3V on enable pin.
                          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                          Backlight IC receiving 5V from PP5V_G3S
                          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                          05-06-2024, 10:23 PM
