LG 42LE4500 - No 20V rail
  • DarkNeo
    • Oct 2018
    • 9
    • United Kingdom
    I'm trying to fix an LG 42LE4500-ZA TV for a friend, and I was hoping someone might be able to help. At first glance it looked like the backlight had gone, but on further investigation it turns out the 20V power output from the PSU isn't working.
    The PSU has the Model: YP42LPBA, Part Number: EAY60803202
    The 3.5V output is working, so the MICOM on the main board powers up and will attempt to power on the TV when the power button is pressed. Power On will go high, the front panel LEDs will do their power on dance and the relay will click on, but there's 0V on the 20V lines.
    I've attached several images including an annotated one which I'll refer to.
    I've narrowed down the issue to the top section of the board, as there's a fused 50V input to this section which shows no ripple on the oscilloscope (green point - EL142).
    I've tested the purple points, the 20V output pins on P201 and the inputs and output of rectifier D232, these show 0V with no noticable noise/ripple above the noise from my cheap oscilloscope.
    The highlighted packages are:
    Blue: STF13NM60N MOSFET https://cdn.badcaps-static.com/pdfs/...ba5c2ba3ce.pdf
    Red: MBRF20100CTG Rectifier https://cdn.badcaps-static.com/pdfs/...e518a26d5c.pdf
    Yellow: ST L6599 Resonant Controller https://cdn.badcaps-static.com/pdfs/...7cd0b455f4.pdf
    So this is an LLC resonant bridge converter apparently, which I've done some research on and concluded that I have no idea how an LLC resonant bridge converter works or how to debug one!
    I did try probing the inputs to the lower transformer and got the attached results (one in standby and the other 'on'). It doesn't look right to me, but I wouldn't know what does look right either.
    I can replace the PSU as a last resort, but if it's a component I'd rather just replace that (unless it's one of the transformers, I can't find sources for them anywhere).
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LG 42LE4500 - No 20V rail
    The 20Vdc would be on the COLD side of the PSU. Are you getting the 20Vac out from the transformer?
    • DarkNeo
      • Oct 2018
      • 9
      • United Kingdom
      I'm checking for 20Vdc on the output of the rectifier on the cold side (getting 0Vdc), and I'm looking for 20Vac on the inputs of the rectifier which are connected directly to the output of the transformer (getting 0Vac), but I've also measured from the pins of the transformer directly to be sure.
      I'm wondering if I'm not doing the measurement correctly because I'm so used to DC. I'm connecting the reference wire of my probe to the chassis ground - which I've checked is connected to the GND pins on P201. But that's DC, do I need a different 0V reference for the AC?
      Also I completely forgot to check the 12V rail, this is also showing 0Vdc on the output.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Are Q102 and Q103 getting power at the S pins? IC 101 could be malfunctioning, too.
        • DarkNeo
          • Oct 2018
          • 9
          • United Kingdom
          I attached the probes to both Q102 and Q103 S pins and the result looks very similar to the input to the transformer (see attached). Voltage doesn't go much above 0, but goes as low as -50V.
          From what I gathered from IC101s datasheet Q102 and Q103 should be alternating, but they're in perfect step.
            1) It looks like you use chassis GND for your scope, the negative leg of the main filter cap is the GND ref for meter and scope, you better make sure that the TV is plugged into the isolation transformer when using the scope on the hot side otherwise you will see nice smoke and spark if the scope GND is tied to the scope incoming AC SAFETY GND.
            2) "I've narrowed down the issue to the top section of the board, as there's a fused 50V input to this section which shows no ripple on the oscilloscope (green point - EL142)."
            it shows 50V because you use the wrong GND as explained above, it should have about 390VDC with ref to the negative legs of the main filter caps (those lytics caps with 450V rating on them).
            3) We also need the Voltage readings of all the pins of the connector P201.
            • DarkNeo
              • Oct 2018
              • 9
              • United Kingdom
              Thanks, I clearly need to learn more on this so I'll do some research before trying anything with the scope. I take it if I'm using a battery powered multimeter I can take primary side readings between the point I'm checking and the negative main filter cap leg without any issues?
              All these readings are taken when the set is 'on':
              #1 Power On: 3.41V
              #2/3/4 20V: 0.02V
              #5/6/7/8 GND: 0V
              #9/10/11/12 3.5V: 3.51V
              #13/14/15 GND: 0V
              #16 V-sync: 0V
              #17/19/21 12V: 0.1V
              #18 DRV On: 0.01V
              #20 SCLK: 0.03V
              #22 PWM DIM: 0V
              #23 SIN: 0.04V
              #24 Error Out: 0V
                At this point do not worrying about using the scope yet, yes you can use battery operate on the hot side but you have to remember that the scope GND will now be at HOT potential so do not touch any the metal parts, scope probe with your hands or body.
                I would verify that you do have 390VDC through that fuse to run the 12V/20V/ LED driver power supply or not first.
                It also looks like some of the control signals are missing from the main board:
                #18 DRV On (BL-ON): 0.01V
                #22 PWM DIM: 0V
                #20 SCLK: 0.03V don't know if it is used or not
                #23 SIN: 0.04V, don't know what that is.
                #24 Error Out: 0V, don't know if 0 = Normal or = Bad
                Need to see if we can find service manual for it.
                • DarkNeo
                  • Oct 2018
                  • 9
                  • United Kingdom
                  Ok I'm reading 393VDC on that fuse.
                  I have the service manual for the 42LE4500 with schematics for the main board - unfortunately not the PSU.
                  #18 DRV On - goes to the INV_CTL pin on the MICOM
                  #22 PWM DIM - goes to the LVDS and PWM2 on the MStar CPU
                  #20 SCLK & #23 SIN - according to the schematic and option resistors on the board these pins are N/C
                  #24 Error Out - I'm not sure on this either, all I know is that it's an output from the LED driver daughterboard on the PSU
                  The only thing that I can see from the control signals that's not immediately explained by the lack of 12/20V rails to power the CPU is the DRV/BL On signal, but the MICOM may not activate that until told to do so by the CPU.
                    Once the PS-ON is present the 12V and the 20V should be present, so we need to get the P/N of IC101 to get the spec sheet and find out if the switched VCC is present for the IC to run or not.
                    • DarkNeo
                      • Oct 2018
                      • 9
                      • United Kingdom
                      IC101 is an ST L6599 Resonant Controller, datasheet here: https://cdn.badcaps-static.com/pdfs/...7cd0b455f4.pdf
                        Look to see if you Voltage on the VCC pin against GND pin when PS-ON is present.
                        • DarkNeo
                          • Oct 2018
                          • 9
                          • United Kingdom
                          Between the VCC pin (#12) and GND (#10) on IC101 I'm reading 13Vdc.
                            Per spec sheet on page 8/36, the TurnOn threshold Voltage is 10.7V (typ.), so the IC may be bad or something is locking it out from running such as the Brownout protection such as pin 7, pin 8 on page 5/36. You need to test those Voltages as indicated on that page.
                            • DarkNeo
                              • Oct 2018
                              • 9
                              • United Kingdom
                              Pin 7 is 1.87-1.9V and pin 8 is 0V. So it looks like the inputs to IC101 are good.
                              I also desoldered one of the transformers to check the coil arrangements and make sure there weren't any shorts/breaks. It all checked out and the bottom two pins on the secondary side are a single coil, so not seeing anything on the scope on these pins would indicate no/bad input to the primary coil.
                              So do you think it would be best to swap out IC101 and possibly the MOSFETs on the primary side?
                                KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                                by momaka
                                For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                                http://www.rmac.kingwin.com/products.../abt_650MM.asp
                                I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
                                What mostly drew me into buying it is its 2x PCI-E power connectors...
                                03-29-2022, 11:34 PM
                              • Nagy Daniel
                                Lowest possible resistance on laptop motherboard rail - Guide Table request
                                by Nagy Daniel
                                Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                                I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                                I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                                So, I generated a table with AI so I can...
                                03-04-2025, 08:24 AM
                              • FrancescoV
                                Onkyo HT-R390 no sound output, video output ok
                                by FrancescoV
                                Good morning everyone,
                                I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                                The firmware reported is the following:
                                M:1.00/11107BLP
                                D:?.??/????????
                                O:1.00/11107AL
                                The DSP firmware given the question marks seems corrupt.
                                On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                                05-11-2025, 02:59 AM
                              • прямо
                                Corsair HX 750W - DC Leakage at 12V Output Rail in Standby Mode
                                by прямо
                                Just received it today from a friend.
                                Auto shutdown by the supervisor IC because of an under voltage condition with 12V output rail (dropped to 10.5V)
                                The same rail also does this when the PSU is in standby mode.
                                https://ibb.co/5TBkg66
                                The leakage keeps climbing at a steady rate but slowing down when it reaches over 800mV or so. I didn't measure exactly at what value it stopped or if it's even stopped at all.
                                What could have caused that?
                                First time I have seen such behavior.
                                3.3V and 5V rails don't have the same...
                                02-19-2024, 09:52 PM
                              • bauto601
                                KDM 480W PSU upgrade succes! (opinions?)
                                by bauto601
                                Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                A "nice" YoungYear unit? - Badcaps
                                The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                12-26-2023, 03:05 PM
