HiSense 50K360G Button Lock
  • Michale32086
    • Nov 2011
    • 1453
    Had a HiSense come in.. Powers up great, goes to screen. Everything is displayed OK..
    But the buttons don't work on the button board.. Only the ON/OFF works...
    Same with a remote.. Only the ON/OFF works, nothing else..
    The display says NO DEVICE ATTACHED and stays on, even when I hook up a DVD player or something..
    Everything looks good, it's just "locked"...
    Any idea???
    I am thinking a firmware update if possible...
  • R_J
    • 9588
    Re: HiSense 50K360G Button Lock
    Have you tried holding the MENU button while turning on the tv? This is suposed to fix it if it is stuck in USB mode
    • Michale32086
      • Nov 2011
      • 1453
      Yea, no luck..
      And there doesn't seem to be any firmware available...
      • Michale32086
        • Nov 2011
        • 1453
        Just for sheets and greens, I booted it up with a thumb drive in the USB Port.. It booted up and showed the contents of the thumb drive, but still none of the buttons worked...
        • Michale32086
          • Nov 2011
          • 1453
          After an hour long chat with HiSense I learn that no firmware is available..
          Seems if I want this one fixed, I am gonna have to replace the board.
          • ducky29
            • Dec 2015
            • 369
            • Europe
            I can try and find the firmware for 10$ if thats ok for you.
            • Michale32086
              • Nov 2011
              • 1453
              That would be awesome.. I can paypal you immediately...
              Thanx
              • Michale32086
                • Nov 2011
                • 1453
                Rcvd
                • Diah
                  • Feb 2013
                  • 6435
                  it sound to me the TV now at HOTEL MODE
                  • Michale32086
                    • Nov 2011
                    • 1453
                    Possibly... I researched it and it seems that it's "bricked".. Likely TV lost power during a firmware update... Which doesn't make much sense since HiSense.. (sense?? since?? HiSense?? I crack myself up.. ) says that there never was a firmware released for it..
                    Since the TV does read a USB at bootup, I am hoping redoing the firmware will help..
                    • Diah
                      • Feb 2013
                      • 6435
                      i had faced issue with Hisense RC here
                      try with the way i did.. with mobile IR remote apk
                      • Michale32086
                        • Nov 2011
                        • 1453
                        I missed this comment.. I'll give it a shot..
                        Thanx
                        • Michale32086
                          • Nov 2011
                          • 1453
                          Didn't seem to address my issue..
                          But I did get a new BIOS chip from EBAY...
                          But I am not sure where the BIOS chip is...
                          Attached is a pic and the chip I think it is, says EM24C32F, is marked in red..
                          • Michale32086
                            • Nov 2011
                            • 1453
                            Actually the markings on the chip is
                            FM24C32F
                            1230J5R
                            • Michale32086
                              • Nov 2011
                              • 1453
                              Found it.. It's underneath the metal shield..
                              • Michale32086
                                • Nov 2011
                                • 1453
                                Just an update.. A new firmware chip did NOT fix the problem
                                • Michale32086
                                  • Nov 2011
                                  • 1453
                                  OK Update on the update...
                                  Just for sheets and greens, I grabbed a HiSense remote that I had flying around...
                                  Had the TV on and pushed INPUT on the remote.. SOME BEACH!!! It went to input!!! Used volume and stuff and it all worked!!!
                                  Then I shut it off and turned it back on and ALL the buttons on the button board worked!!!
                                  When I tried a "remote" before I just used a UNIVERSAL programmed for HiSense...
                                  Maybe I needed an actual HiSense remote to kick it in gear..
                                  Go figger....
                                  • themosttogain
                                    HP Envy 13-BA1565na with intermittent power button
                                    by themosttogain
                                    Hope someone can give me some suggestions on this because i'm at my wits end with it...
                                    I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
                                    Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
                                    07-12-2024, 03:03 AM
                                  • envym
                                    MacBook Pro 2018 with Activation Lock
                                    by envym
                                    Hi everyone!
                                    I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                                    I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                                    06-27-2025, 08:54 AM
                                  • reessi
                                    Macbook Air - 2018 - A1932 - 820-01521-02 - Bootlooping if Power Button Connected
                                    by reessi
                                    With the power button connected it either boot loops with the apple logo or no display but the charging meter shows it looping on charging every few seconds.
                                    No corrosion any where!
                                    Tried a replacement power button off ebay and the same.
                                    Very occasionally it will work with the power button connected!
                                    Same results with or without the battery.
                                    Can it be a fault with the Audio board or the mainboard?
                                    The touch Id assembly connects through the Audio board first then to the Mainboard.
                                    Flex...
                                    06-26-2024, 03:31 PM
                                  • Zippo978
                                    PS4 Fat, power button not working
                                    by Zippo978
                                    I have a first-model PS4 Fat with a touch power button. Now the button isn't working, and I don't know why. How can I fix it? And if it can't be fixed, is there a way to bypass this button and install a "normal" button?
                                    Today, 04:42 AM
                                  • brock-s
                                    MSI A520M-A Pro with "U-Key" power-on lock removal
                                    by brock-s
                                    I've searched the forums, including review of the "BIOS Guides, Methods, Resources and Tools" section but could not find anything regarding this problem. Additionally, I could not find a thread related to a U-Key lock on an MSI motherboard (or any other brand board for that matter).
                                    I'm working on an MSI A520M-A Pro (aka MS-7C96 ver1.1) motherboard that displays "Warning!!! Please insert USB key press any key to check." upon power-on. This appears to be caused by a setting in the BIOS for "U-Key" being enabled. The owner states they didn't enter the...
                                    09-01-2025, 12:35 PM
