Hisense H49MEC3050 UHD strange issue with RC but funny
  • Diah
    • Feb 2013
    • 6435
    i became yesterday one eBay beat cheap this UHD TV very clean, but with it delivered RC no response at all,
    1- check batteries ok
    2- check IR signal with RC testing module ok 100%
    3- took my mobile galaxy IR Remote and the TV start to response, after this response i did double hard rests one via service menu and second via interface settings but still the TV response only on my mobile IR.
    here i am thinking on firmware issue... what do you think
  • attainteddragon
    • Apr 2013
    • 764
    • australia
    Re: Hisense H49MEC3050 UHD strange issue with RC but funny
    have you confirmed that it is the correct remote model for that tv?
    WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8320
      wrong remote? What is the part number from the remote? Should be a EN2C27.
      Just a side note. I don't think you became a TV. You got a TV. Bekommen (german) and became (english for "werden") are different things. ;-)
      • Diah
        • Feb 2013
        • 6435
        LOL in english.
        well the RC original, i did contact Hisense customer service and its known issue with most update firmware of 3000 -5000 series, i solved it with downgrade the firmware to the first Factory one.
        • ZixuTech
          Asus F1502Z BIOS issue? CPU gets hot but no other response. No blinking light
          by ZixuTech
          Hey guys, I got this model which stays black screen but CPU heats up. All voltages on board seems oK.
          Perhaps BIOS issue?
          Brand: Asus
          Model: F1502Z
          SN: R4N0CV11S622169
          Board: X1403ZA 2.2
          I have flashed this BIOS for test purposes and it lights up the ASUS but blank SN. https://www.badcaps.net/forum/troubl...21#post3593121
          Can you clean and enter SN for me please....
          03-31-2025, 05:04 PM
        • Coolgoodman
          Faulty Hisense 85Q6NAU TV
          by Coolgoodman
          85” Hisense TV
          Greetings,
          Request for Technical Assessment – Faulty Hisense 85Q6NAU TV
          Dear TV technicians of forum, I hope this message finds you well.
          I am writing to seek assistance regarding my 85-inch Hisense Smart TV, model 85Q6NAU, which is currently experiencing a fault. The unit is approximately two years old, and I am not sure if it has a warranty.
          I have attached a photo showing the issue for your reference. I would appreciate it if your experienced technician could kindly review the image and provide some insight...
          07-24-2025, 03:02 AM
        • rounin
          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
          by rounin
          Hi everyone,
          I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
          🛠 Original Issue
          The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
          Diagnosis showed PP1V5_UPC0_LDO_CORE shorted to ground.
          I replaced U3100 (UF400) using a donor board (A2179), and the machine powers on fine now.
          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
          04-19-2025, 01:18 AM
        • H1ghl4nd3r
          Synology DS415+ power button response issue
          by H1ghl4nd3r
          Had another issue with turning the machine on (1 in 5 it will turn on) so had to strip it down again thinking the power on button is damaged but it is in good condition, then had a look at the motherboard button and it looks like a part of it has snapped off see attached pics.
          Can anyone recommend a replacement for the motherboard, it has 8 pins and would prefer a blue led if possible.
          The closest I have found is part number: PB6156RSL-4-102 (Blue led) PB6156RSL-3-102 (green) but agin struggling to find that part in the uk...
          06-03-2023, 08:15 AM
        • ugamazing
          Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
          by ugamazing
          I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
          We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
          12-17-2024, 07:05 PM
