PS4 Fat, power button not working
  • Zippo978
    • 48
    • Italia
    I have a first-model PS4 Fat with a touch power button. Now the button isn't working, and I don't know why. How can I fix it? And if it can't be fixed, is there a way to bypass this button and install a "normal" button?
  • themosttogain
    HP Envy 13-BA1565na with intermittent power button
    by themosttogain
    Hope someone can give me some suggestions on this because i'm at my wits end with it...
    I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
    Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
    07-12-2024, 03:03 AM
  • myth77
    Asus Gl753, gl553, fx553 keyboard power button not working
    by myth77
    I have i think 4 dead keyboards from laptops in the title...they are very similar...almost the same...and all of them have not working power buttons. All other keys are working...but when you press power button it doesnt short 3.3v to gnd...so you can only do it manually on the keyboard conector with tweezers or similar. I inspected in every detail ribbon cable that is going to the motherboard connector and removed power key button from keyboard to see anything wrong there, but all seems perfect.
    Has anyone with more expirience figured where is that power button line getting broken? because...
    07-13-2023, 12:30 PM
  • myth77
    asus g752vy power button partially not working
    by myth77
    So, this laptop was broken..i tested it..find short...replaced ite chip and 3/5 voltage regulator and everything is working fine...i tested it and all ok...but...later when i tried to put it together every time i connected touchpad button the red light on the power button was missing (the laptop is working, touchpad is working) just missing that red power button light). And when i unplug touchpad it was there... So whats going on...?
    I measure power led on both side and it is 5,06 V on one side...but when touchpad is connected there is a difference on other side "PWR_LED_CON#_1"...
    09-05-2020, 05:57 AM
  • reessi
    Macbook Air - 2018 - A1932 - 820-01521-02 - Bootlooping if Power Button Connected
    by reessi
    With the power button connected it either boot loops with the apple logo or no display but the charging meter shows it looping on charging every few seconds.
    No corrosion any where!
    Tried a replacement power button off ebay and the same.
    Very occasionally it will work with the power button connected!
    Same results with or without the battery.
    Can it be a fault with the Audio board or the mainboard?
    The touch Id assembly connects through the Audio board first then to the Mainboard.
    Flex...
    06-26-2024, 03:31 PM
  • hoarderteks_kyriakos
    Dell Latitude E5570 - No display, turns off after a minute of pressing the power button.
    by hoarderteks_kyriakos
    Hello.
    Yesterday my mother encountered a problem with her laptop, which led to it not turning on and expressing the behaviour mentioned in the title (you press the power button and then it turns off after a minute)
    Here is what happened:
    At one point i was fixing a setting on the laptop to make the laptop properly recognize the NVMe drive i put in months ago. All worked until all of a sudden the computer blue screened. The screen said it would reboot, but it never did. So she held down the power button, powering it off. Pressing it again, the screen briefly turned...
    10-08-2025, 07:33 AM
