MSI A520M-A Pro with "U-Key" power-on lock removal
  • brock-s
    • 48
    I've searched the forums, including review of the "BIOS Guides, Methods, Resources and Tools" section but could not find anything regarding this problem. Additionally, I could not find a thread related to a U-Key lock on an MSI motherboard (or any other brand board for that matter).
    I'm working on an MSI A520M-A Pro (aka MS-7C96 ver1.1) motherboard that displays "Warning!!! Please insert USB key press any key to check." upon power-on. This appears to be caused by a setting in the BIOS for "U-Key" being enabled. The owner states they didn't enter the BIOS and didn't intentionally set any "U-Key" lock. This locks the motherboard power-on process so that it will not continue without the key. Resetting the BIOS did not remove this lock. Ultimately, the motherboard was replaced with a new one. However, within a week, the same problem occurred on the new motherboard. Once again, the owner states they were not in the BIOS and did not set any power-on locks.
    I'm hoping I can get some help from someone who could possibly look at the locked BIOS and the clean copy from MSI's latest bios update and remove this lock. There are two EEPROM's on the motherboard: a Winbond 25Q256JWEQ, and an MXIC 25V2033F (this was read using an xgecu T56 programmer - using the settings for a 25V2035F since it doesn't have the 25V2033F in it's library).
  • m1ch43lzm
    • Mar 2019
    • 602
    • Peru
    Try, I used 7C96v1I as base, copy from 1021000h-10219FFh and 1029000h-10299FFh from your original BIOS to the new one downloaded from MSI website
    NVRAM area should be clean now
    Flash the W25Q256JW only
    UkeyData NVRAM variable is populated in the original dump
    Code:
    22 03 31 00 31 00 37 00 32 00 30 00 39 00 31 00 30 00 30 00 30 00 34 00 39 00 36 00 30 00 36 00 35 00
    • brock-s
      • 48
      Thank you so much! I was away today, but should be able to give it a try tomorrow. Will followup with how it goes.
      • brock-s
        • 48
        I can confirm that worked!!! Thank you so much!
        This help by itself saved me (by not having to buy a new motherboard) almost as much as a yearly subscription to this excellent site!
        • glovecaps
          Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
          by glovecaps
          I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
          My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
          The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
          11-25-2024, 04:23 PM
        • lucaszmn
          by lucaszmn
          Problem:
          Initial Findings:
          • I concluded that the
          08-12-2025, 03:01 PM
        • nike486dx
          Chinese windows tablet bios lock removal
          by nike486dx
          Long story short: bought a 8” generic windows tablet (based on Atom x5-z8350, bios chip model is Gigadevice 25LQ64CVIG, uefi vendor is AMI Aptio) for some experiments, and it came with bios lock! I dont have any decent 1.8v programmers at hand nor do i have knowledge in modding uefi firmware, so decided to play safe: dumped the bios with AFU utility, which i attach here. I am hoping to get it unlocked. Also included hwinfo screenshots with general information, the board itself looks generic without any markings.
          05-18-2024, 04:27 PM
        • ArtMov
          [HELP] Asus g732lv ami bios overclocking lock reseting after reboot
          by ArtMov
          Hi guys, i have a problem , my bios resets disabled overclocking lock setting to enable after reboot, please tell me which function can be responsible for restoring the stock config for this option, loading parameters from nvram and so on, like bios ,protection, from asus. My bios made me angry) Set default parameter to disable in amibcp 5 , doesn't help(
          1. I made overclocking lock disabled the default in amibcp
          2. I changed the varoffset to the wrong one, but it led to the programmer, it was very tedious and nervous, I really regretted it, my chip is on the back of the...
          03-31-2023, 01:30 PM
        • oragano
          ASUS ex-b250-V7 motherboard bios corrupted - by me
          by oragano
          hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
          So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
          i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
          10-17-2024, 02:53 AM
