LG 65lb5200 screen solarization
  • jchro
    • Sep 2018
    • 7
    I just replaced the main board after reading up on how to fix a “power on but no screen issue.” Now the tv and screen turn on but the screen is very solarized. From what I read since both the screen and the settings menu both solarize that points to the tcon board or the screen itself.
    Before I replace the tcon, is it possible the new problem is still with main board?
    I'm going to try the bake trick on my old main board and see if it work.
    Thanks!
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LG 65lb5200 screen solarization
    Is the Main Bd an exact replacement i.e. The same No. from the white label etc? Sometimes you can go into the OPTION BYTE menu and switch the screen options for the TV to show again. It may not necessarily mean a bad T-CON Bd.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4537
      • Italy - Milan
      The board could come from a different equipement tv, ie a different screen, it means probably a different size of screen then you have to upgrade the SW for the right model then enter service menu and do a reset. bye.
      • jchro
        • Sep 2018
        • 7
        Thanks! Any suggestions on how to enter the service menu on this model? All the LG instructions I am finding are not working.
        Thanks again,
        • ducky29
          • Dec 2015
          • 369
          • Europe
          You need a service remote control to access it. You can get it on ebay for like 15-20 $
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4537
            • Italy - Milan
            You can also do the reset usually by shorting pin 5,6 of the settings eeprom then putting the power cord and then release. The correct eeprom is the bigger one 8pin.
            • jchro
              • Sep 2018
              • 7
              Got the service remote for this tv. When I press instart. Nothing happens. I don’t think I’m skilled enough for shorting the pin instructions. Thanks! Frustrated but having fun!
              • ducky29
                • Dec 2015
                • 369
                • Europe
                Press the adj button and then change the model from there
                • jchro
                  • Sep 2018
                  • 7
                  Nope adj button doesn’t work either. Standard button work, just not the service remote buttons. I have a mkj39170828 factory sac remocon remote.
                  • ducky29
                    • Dec 2015
                    • 369
                    • Europe
                    Try in stop and then adj?
                    • jchro
                      • Sep 2018
                      • 7
                      In stop then adj also doesn’t work.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4537
                        • Italy - Milan
                        The instruction on how to use a service remote is on every service manual..
                        • jchro
                          • Sep 2018
                          • 7
                          Good advice on the service manual. Didn’t even need a service remote. Input 3195 gets you in the factory menu. Thanks!
                          • advant
                            by advant
                            02-03-2020, 12:25 AM
                          • m1ch43lzm
                            by m1ch43lzm
                            05-12-2025, 08:37 PM
                          • maxim2511
                            LG 55EC930V OLED - swich on swich of no screen
                            by maxim2511
                            My Oled Tv is 55inch tv, 3 days ago I notice that middle of the screen is getting warmer and on picture I have ghosting, missing red color. Color red was still displaying, but it was not so strong as corners of the screen and watching some movies makes me angry.
                            Then I get an idea to take it apart and clean boards from dust.
                            In side of Tv was not so bad, I take compressed air in can, and gently blow up.
                            Also I was thinking to styrofoam sponge to isolate power board from screen that the middle of the screen will not worm so much. Because Led on screen when gets higher...
                            05-14-2021, 02:21 AM
                          • ygorsan
                            by ygorsan
                            🧩 Problem Summary:
                            • I
                            07-28-2025, 08:34 AM
                          • howardc64
                            by howardc64
                            Problem
                            08-04-2024, 10:36 PM
