Vizio M602i-B3 No Backlights
  • landyboy
    • Apr 2013
    • 443
    Re: Vizio M602i-B3 No Backlights
    yes to the 15v and no change to screen if Tcon is disconnected.
    • landyboy
      • Apr 2013
      • 443
      Possible bad Main board?
        Can we see the pictures of the whole back side of the TV showing all the boards?
        You also need to find out if there is 12VDC at both ends of the SMD fuse on the T-CON board or not.
        • landyboy
          • Apr 2013
          • 443
          There is 12vdc at both ends of the SMD fuse on Tcon
          • landyboy
            • Apr 2013
            • 443
            Bad TCON?
            • budwich
              • Jul 2015
              • 3097
              which cable(s) are you disconnecting at the tcon? you need to do one at a time and also you need to hit the menu or have something feeding an input to hopefully find some thing on the screen otherwise it might go into "screen saver / no input mode".
              • landyboy
                • Apr 2013
                • 443
                The top hard connectors. Are they correct ones?
                • budwich
                  • Jul 2015
                  • 3097
                  not really... those provide the "inputs" to the tcon... if they are disconnected, then the tcon will be somewhat "mindless". The bottom connectors pass "processed" signals to the panel... disconnecting them one at a time may tell you more about whats happening from the tcon to the panel and beyond.
                  • landyboy
                    • Apr 2013
                    • 443
                    so when I disconnect the bottom ribbon cable one at a time. Ones side disconnected half of screen turns grey fuzzy, no response from pressing menu or any other key. Reconnect that side disconnect other same half of screen that was grey turned purple. Still no response from menu key.
                    • budwich
                      • Jul 2015
                      • 3097
                      hmmmm... somewhat unusual for a vizio... I would have expected the disconnected half to go white while the connected side maybe anything but white... depending on what the input is. Can you post a picture of the display during these two tests... note: all other cables are connected appropriately during this test... right?
                      • landyboy
                        • Apr 2013
                        • 443
                        Ok did it again. Not sure why I got the purple before. These are the two screens I got.
                          The cable you are doing are the flat pinkish color cables between T-CON board and the LCD panel, correct?
                          • landyboy
                            • Apr 2013
                            • 443
                            correct
                            • budwich
                              • Jul 2015
                              • 3097
                              that's more like it.... to me this indicates that the tcon to panel (and beyond) appear to be responding appropriately, so the question remains, why isn't the signal getting into the tcon to be displayed. Are you sure that you have something to display... either menu or some other input.
                              • landyboy
                                • Apr 2013
                                • 443
                                Yes I have tried menu key on remote and many other keys with nothing appearing on the screen.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  #36
                                  do you get sound if you try a dvd/games console?
                                  • landyboy
                                    • Apr 2013
                                    • 443
                                    no sound I introduced a video source and still nothing
                                    • landyboy
                                      • Apr 2013
                                      • 443
                                      I'm now thinking maybe a bad main?
                                      • landyboy
                                        • Apr 2013
                                        • 443
                                        Ok ordered and replaced the main board. Now it gets weirder. When first powered on the back lights get brighter than before but then get dimmer and lightly flash occasionally. I press the menu button and the screen appears to lighten in the area of where the menu is supposed to be but still no picture or menu. I disconnect the ribbons one at a time below the tcon and this time nothing really happens. No one side grey like before.
                                        • landyboy
                                          • Apr 2013
                                          • 443
                                          Changed power supply no change.
