Identifying backlight LED
  • schmo
    • Jan 2014
    • 11
    • DE
    Hi
    i got a Blaupunkt 40/233I tv with a broken backlight.
    I disassembled the tv and looked for bad caps but they are ok. The backlight connector delivers ~30V under load
    So I disassembled the panel and found 2 broken leds on the led stripes.
    Can you help me to find the correct package and correct values?
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Identifying backlight LED
    You need to measure the length and width of the LED to identify the package and determine if they are 3V or 6V.
    https://www.ebay.co.uk/itm/BUSH-40-2...-/332097789746
    • schmo
      • Jan 2014
      • 11
      • DE
      Hi
      Thanks for your message
      The led is 4mm x 3mm
      There are 20 leds in series. So 30V / 20 = 1,5v?
      Thanks for the link. There they are really expensive. I would like to buy them from my local electronics dealer.
      Greetings
        If the 20 White LED (3V LED) in series so the total Vf = 20 x 3V = 60V.
        The 30V looks to be the feeding Voltage to boost converter circuit to drive the 20 series- connected LED.
        • unimatrix93
          Identifying backlight resistors, power supply is a BN44-00852
          by unimatrix93
          Dear forum, I would like to ask some help identifying the backlight circuits resistors to limit the ampere to the backlight leds.
          The power supply is a BN44-00852 and I want to decrease the backlight to increase the lifetime of the LEDs.
          The TV is pretty much always on, used for CCTV cameras.
          I suspecting R9838 -> R9841 resistors but I'm not sure. Thanks in advance!
          04-29-2024, 04:49 AM
        • Comp_Pro
          No Backlight Macbook A1990 820-01041
          by Comp_Pro
          Hello all,
          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
          Tests performed:
          There is no backlight even with a good screen.
          Backlight IC is receiving the correct support voltages.
          Fuse F8400 ok
          Current sense resistor R8400 ok
          Backlight IC is receiving 3.3V on enable pin.
          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
          Backlight IC receiving 5V from PP5V_G3S
          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
          05-06-2024, 10:23 PM
        • 1234567v14ada
          identifying backlight fuse in v14 ada type 82C6
          by 1234567v14ada
          I need help identifying and replacing a blown backlight fuse in lenovo v14 ada type 82C6. Any help would be appreciated.....
          10-06-2023, 10:56 AM
        • cheebster
          iPad Pro 12.9 5th Gen Backlight Issue
          by cheebster
          Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
          Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
          Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
          The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
          Anyone...
          05-20-2025, 09:17 AM
        • kjchatman
          identifying sot23 on backlight cirucuit of 17" razer rz09-0423
          by kjchatman
          this laptop was damaged by a roof leak at the repair shop that it was at while waiting for a replacement cpu fan. It was given to me to try to save the motherboard which wouldn't power up anymore. The only issue now is that an sot23 marked R1 is missing one of it's three legs. I cannot find schematics for this model but I found a mosfet that has the same label but i'm not sure if it's an actual match. CJ3401 is the one that I found but I have no clue about the true identity of the damaged one.
          07-28-2025, 11:47 AM
