sony kdl-46w5100 no red light standby, on green off red light flash 14 times
Re: sony kdl-46w5100 no red light standby, on green off red light flash 14 times
tv-on or off at BL-on pin no volt alraedy checked
if i jump pin 12v or stand by pin to BL-on I see back light is flash and bright on tv screen not event hafl secondComment
no no i will try my best ,, i donot give up soon ThxComment
All you have to do is to measure the Voltage between the two legs of that diode you put in, that Zener is for protection, the circuit will function without it, you do not need to have that zener in place to test the D1N to see if it will work or not.
The VCC feeding that IC is 12V, the zener is rated at 15V just in case the 12V lost its regulation so it will be clamped down to 15V.Never stop learning
For the backlights circuit to function, some inverter will need BL-ON and DIM control signal, it will depend on the design.
You can also solder two AA batteries in series and 100 Ohms resistor in series to provide 3V source to simulate control signal.Never stop learning
Never jump the control pin directly to the Voltage source, especially with 12V, you can damage the receiving circuit, and if you accidentally jump to the wrong pin it will even worst which you can either damage the power supply or the circuit on the wrong pin you connected to. If you want to simulate the control signal, you MUST remove the cable or the wire to that control pin first, if you don't you will back feed the Voltage (especially when try using 12V as Voltage Source) back to the main board and damage the main board. You can use resistor (470 ~ 1K Ohm) between the control pin and the Standby power supply output pin.
You can also solder two AA batteries in series and 100 Ohms resistor in series to provide 3V source to simulate control signal.Comment
The VCC feeding that IC is 12V, the zener is rated at 15V just in case the 12V lost its regulation so it will be clamped down to 15V.Comment
I upload the t-con boad i suspect 2 resitor on the top and the bottom the same position from it
R16 and R315
tested with ohm metre 4k,40k,400k,40M,4000M and continuity but no sound no reading any number just OL
you think the resistor on t-con board shorted?Comment
BTW, can I see good clear straight shot pictures of the T-CON board?
I still think you have problem with T-CON board after searching about 14-blank code.
I.E. https://www.badcaps.net/forum/showth...4+blink&page=5
https://www.badcaps.net/forum/showth...ink#post667463Last edited by budm; 08-17-2018, 11:59 PM.Never stop learning
BTW: https://www.badcaps.net/forum/showpo...49&postcount=7
You never give me the result of this request.Never stop learning
Those two parts have white body, correct? They are capacitors not resistor.Never stop learning
If you look at the T-CON board both sides you will see many Voltage test points, I.E
http://assets.shopjimmy.com/media/ca...69h-bottom.jpg
VCC, SW3.3V, VS, AVDD, core_1v, etc.
http://www.shopjimmy.com/samsung-lj9...con-board.htm#
Samsung LJ94-02669H (46NU_MB4C6LV0.7) T-Con Board
Pictures provided by shopjimmy.Never stop learning
I still think you have a problem with T-CON board after searching about 14-blank code.
give me idea Budm, i will take more time to test then will make a decision
one more thing is how to check volt at HV from D1N board?
ThxComment
interesting to learn more thing ,,, now i spend time to learn how to test t-con
you have any good idea start to test my t-con ?Comment
See my post #53, you need to locate and test bunch of Voltage test points per some example that I can see from the pictures, there are many more on that T-CON board.Never stop learning
Today i do test two led of zener diode i make accident touch the other test lead to somewhere i don't it sparked then i check around the D1N is shorted oh my god finally i found out it shorted the diode D6612 I removed it out but the circuit still shorted then checked the IC6601 too many pins with continuity then removed out then everything no more shorted so i order on ebay and waiting ,, during this time to check t-con for experiment i will be back and report here soon Thank BudmLast edited by mydang; 08-18-2018, 11:27 PM.Comment
When you indicated the component is shorted, what is the RESISTANCE reading in both direction?
What was the resistance of the that shorted 15V Zener that you first found in the beginning.Never stop learning
by MOSSEPHi
Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
I have already tried replacing all of the...-
by MOSSEPHi
I have already tried replacing all of the... -
by lcdcaps1Hi
I have an 820-2610-A motherboard that has no green light.
I have noticed is when I do a SMC reset the light on the Magsafe blinks.
From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
The sys onewire circuit on this model and others is more involved
I was hoping if anyone knows about this and how it works, can reply and let me know
I know this is an old model but I am sure there are people who still works on these or knows about them
I get 1.1v on the C7771 capacitor and will replace... -
by blazzeliaHi guys,
I have this 2011 MBP - the company I was working for, bought it at the time for a project and gave it to me after that. Later on, I gave it to my daughter which used it for normal internet browsing and office apps. At some point the, now famous, AMD GPU issue hit this laptop as well. I disabled the use of the AMD GPU following some information I found at the time (the one that, at the end, one moved AMD kext drivers to a backup location). So the laptop was using the CPU graphics and it was ok for the said daily usage. I even replaced the drive with an SSD one and it was operating... -
by shahnldGood Day.
I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite... - Loading...
