sony kdl-46w5100 no red light standby, on green off red light flash 14 times
    Re: sony kdl-46w5100 no red light standby, on green off red light flash 14 times
    INV-ERR is generated by the inverter circuit to tell the main board if there is problem in the inverter circuit or not. From my research, the normal Voltage of the INV-ERR should LOW if there is no problem with the inverter circuits.
    'Backlight' = bl-on is the command signal from the main board to turn on the inverter circuit. You should leave he meter on that pin then turn TV on to see if the Voltage jumps up for seconds or not.
    So did you replace that shorted out zener diode? Did you check the fusible resistor R6636? Did you check the Voltage by leaving the meter probe on the each pin of the connector CN660 when turn on the TV each time to see what you get, if look at the schematic I provided for the D1N board you can see that CN660 shows what Voltage you should have on the connector.
    BTW, so far I do not see the pictures of the whole backside of the TV showing all the boards as requested.
    D2N inverter board also has the same Zener diode on the VCC pin to clamp the Voltage on the VCC pin of the IC, you may want to check them out too.
    Your TV uses two inverter boards for driving the lamps in push-pull mode so if one inverter board is bad you will see the screen lights up for seconds on one half of the screen (I.E left half or right half of the screen) that has good inverter board, did you notice that when you first turn on the TV? you have to do that in darken room.
    • mydang
      • Aug 2018
      • 61
      • canada
      So did you replace that shorted out zener diode?=(I do not have 15v zener diode in my hand, temporary just replaced one took off from different board but I donot know value of volt)I alrady order ebay and waiting- Did you check the fusible resistor R6636? (I check R6636 good and has continuity)Did you check the Voltage by leaving the meter probe on the each pin of the connector CN660 when turn on the TV each time to see what you get, if look at the schematic I provided for the D1N board you can see that CN660 shows what Voltage you should have on the connector. (CHECKED cn660-pri-vcc- 12v tv on) will check pfc and let you know thx
      D2N inverter board also has the same Zener diode on the VCC pin to clamp the Voltage on the VCC pin of the IC, you may want to check them out too. I will check vcc ic pin connect to zener diode and let you know Thx
      I WILL FOLLOW YOUR INTRUCTION AND CATCH UP STEP BY STEP FROM YOUR HELP Thank Budm
      • mydang
        • Aug 2018
        • 61
        • canada
        ((TV On or Off checked BL-on no voltage,,usually how many volt go to this Bl-on pin ? and where is the voltage come from inverter or from power su board?
        Although tv on or off, THE PROLEM IS NO VOLT at BL-on
        Thx Budm
        • mydang
          • Aug 2018
          • 61
          • canada
          Hi! Budm so far i look at schematic D1N inverter when tv on i should have 12v volt at REG 12v of CN6702 i do not have volt at BL-on because it connect to REG 12v i will trace and test let you know
            But on that connector you suppose to have PFC Voltage around 390Vdc also for the inverter circuit.
            BL-ON is from the main board, <1V = off, >2V = ON.
            • mydang
              • Aug 2018
              • 61
              • canada
              #26
              Hi! Budm more understand when i look at D1N inverter board , may i have one power supply detail like D1N i google but i canot find if you have send me one please
              Thx
                Thx
                I do not understand, I already provide the schematic for the D1N board in post 10 and also the training manual in post 21.
                And D2N on this post.
                "may i have one power supply " what one power supply? what is the P/N as printed on the board?
                • mydang
                  • Aug 2018
                  • 61
                  • canada
                  #28
                  hi! Budm
                  TV turn on,at CN6702 no 12volt at REG 12v pin so what is wrong? and why i do not have volt at REG 12v pin ? Thx
                    CN6702 of which board?
                      I still need to see the pictures of the whole backside of the TV showing all the boards, and also board numbers.
                      • mydang
                        • Aug 2018
                        • 61
                        • canada
                        #31
                        D1N inverter board
                        Thx
                        • mydang
                          • Aug 2018
                          • 61
                          • canada
                          #32
                          although i can not repair but I start to learn from your experience
                          Thx
                            What do you mean you cannot repair?
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              #34
                              I was just going to ask that question and also why no pictures have been uploaded of his tv bit odd if someone genuine wants help that none have been uploaded
                                Right now it is pretty good that OP was able to find shorted out zener in D1N inverter board without guiding even though the blink code error (14-blink) has nothing to do with inverter board, so I hope he does not give up yet.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  #36
                                  did he remove and test the diode out of circuit? just in case a false reading
                                    I think he did because the reading on the VCC pin of the IC no longer show low resistance reading after the Zener is removed.
                                      hi! Budm
                                      What is the P/N of your G board? G7N?
                                      btw:
                                      checked t-con fuse is 12 volts
                                      Thank you
                                      Since that reg 12V is the same reg 12V (see training manual) that feeds the T-CON, then I cannot see why you do not have reg 12v on CN6702.
                                      Please read the training manual CTV59 page 19 I provide, it is important that you get the basic idea how the Voltages are routed through out the set.
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        • uk
                                        #39
                                        well once hes replaced that diode with the correct voltage replacement, lets hope we can help him find the problem with his set but like you say pictures do help just in case his boards dont match the schematics etc
                                        • mydang
                                          • Aug 2018
                                          • 61
                                          • canada
                                          #40
                                          Thank you Budm and vincer, Today i double check I already checked I have all vcc 12v and REG 12 and PFC-OUT 397V all the voltage on CN from D1N and power supply seem ok ,, I agree with Vincer about Zener diode i remove fron the board to replaced for one on D1N inverter not correct 15 voltage , i think the one i remove from board 3 or 5 volt
                                          may be it is not work right, so far Explain and send me schematic make me more understand ... i will learn from thall all gentlement here
                                          • MOSSEP
                                            Monitor Audio RSW12 - Green light, but no sound
                                            by MOSSEP
                                            Hi
                                            Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                            Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                                            The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                            I have already tried replacing all of the...
                                            01-26-2025, 08:33 AM
                                          • MOSSEP
                                            Monitor Audio RSW12 - Green light but no audio
                                            by MOSSEP
                                            Hi
                                            01-26-2025, 08:18 AM
                                          • lcdcaps1
                                            820-2610-A Sys onewire help, no green light. Please help from the gurus
                                            by lcdcaps1
                                            Hi
                                            I have an 820-2610-A motherboard that has no green light.
                                            I have noticed is when I do a SMC reset the light on the Magsafe blinks.
                                            From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
                                            The sys onewire circuit on this model and others is more involved
                                            I was hoping if anyone knows about this and how it works, can reply and let me know
                                            I know this is an old model but I am sure there are people who still works on these or knows about them
                                            I get 1.1v on the C7771 capacitor and will replace...
                                            11-06-2023, 01:28 PM
                                          • blazzelia
                                            MBP A1286 820-2915 green light only, no start
                                            by blazzelia
                                            Hi guys,
                                            I have this 2011 MBP - the company I was working for, bought it at the time for a project and gave it to me after that. Later on, I gave it to my daughter which used it for normal internet browsing and office apps. At some point the, now famous, AMD GPU issue hit this laptop as well. I disabled the use of the AMD GPU following some information I found at the time (the one that, at the end, one moved AMD kext drivers to a backup location). So the laptop was using the CPU graphics and it was ok for the said daily usage. I even replaced the drive with an SSD one and it was operating...
                                            09-30-2024, 07:20 AM
                                          • shahnld
                                            Sony kdl 65xg9505 green amber blinking
                                            by shahnld
                                            Good Day.
                                            I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                            i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                            green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                            01-03-2024, 03:05 PM
