LG 37LE500 lcd blinking
  • alberich2k5
    • Jul 2018
    • 13
    • Spain
    Hi everyone
    I am trying to repair my former TV, an LG 37LE5500, mainly for learning purposes.
    The issue is: when I turn the TV on it starts blinking and rebooting, repeating this cycle for about 10-30secs. After that, it works correctly with no issues.
    I started by looking at the power supply (EAY60803001; attached front and back pictures provided by shopjimmy) measuring the following lines (bunch of cables going to main board):
    PIN *******StandBy PWR ON
    ERR-OUT 2.864 2.838
    P-DIM 0.252 1.202
    N.C. *******- -
    DRV-ON 0.061 1.932
    N.C. *******- -
    GND ***** - -
    3.5V *******3.49 3.455
    GND *******- -
    GND *** - -
    20V *******0 18.43
    20V *******0 18.43
    N.C. * -
    12V ******0 12.07
    12V ******0 12.07
    12V ******0 12.07
    GND ***** - -
    GND ***** - -
    GND ***** - -
    GND ***** - -
    20V *******0 18.43
    PWR-ON 0 3.323
    I found that 20V and 3.5V lines differ about 10% from what they should be reading when TV is on. Note when in stand by 3.5V *line are pretty accurate, 3.49.
    So I decided to trace the 20V back, checking for bad components; I reached *to the area from the attached picture (closer look, with numbers). Here, if I read in-circuit resistors values and obtaining completely different values then they should be for most of them.
    Values are:
    1. resistor code 203 **-> reading 18.35K
    2. resistor code 4701 -> reading 3.784K
    3. resistor code 203 *-> reading 4.80K
    4. resistor code 102 *-> reading 962 ohms
    5. resistor code 2203 *-> reading 22.63K
    6. resistor code 105 *-> reading 8.89K
    7. Cap not shorted (don't know if its good or not)
    8. resistor code 272 *-> reading 4.68K
    9. resistor code 153 *-> reading 15.06K
    I have other SMD resistors spread around the power supply board: for example 105 which are reading 0.85Mohms a couple more 202 reading 1.5K
    Is this way of reading smd resistors fine? If yes, does this mean I have all these resistors failing? aren't they so many?
    Thanks in advance
  • alberich2k5
    • Jul 2018
    • 13
    • Spain
    Re: LG 37LE500 lcd blinking
    Sorry to insist on this one, but I really want to learn the process of troubleshooting electronics (at least the basic level)
    Thanks once again
      When it is working correctl , are those Voltage readings still the SAME?
      • alberich2k5
        • Jul 2018
        • 13
        • Spain
        Thank you budm for replying
        Yes, they are the same.
        3.5v are slightly different: once it is working correctly readings are 3.465v
        How about the sms resistor I was asking about? Is it correct what I was doing?
        thanks
          You cannot get accurate resistance reading of the resistor when measured in the circuit.
          Rebooting cycling is more likely there is problem on the main board during startup.
          • alberich2k5
            • Jul 2018
            • 13
            • Spain
            So better I should start looking at main board?
            I have no clue were to start on any starting suggestions?
            About the 20V line on the power supply, should stop looking at it (is it ok the 18.4v)? or just postpone it?
            Thank you very much for your time and patience
            • moateez
              • Jun 2014
              • 119
              • algeria
              Try to rehot schemic capasitor on power splay and turn on your tv
              • alberich2k5
                • Jul 2018
                • 13
                • Spain
                which one is that? (I googled before asking you)
                • moateez
                  • Jun 2014
                  • 119
                  • algeria
                  Sir rehot all capasitor in secondary of power splay in rehot is better to youse hot gun
                  • alberich2k5
                    • Jul 2018
                    • 13
                    • Spain
                    I am really sorry but I couldn't understand what your mean
                    Where are the capacitors in secondary of power suply? Most power supply capacitors are DIP sized, you mean reflow all of them?
                    • angelos
                      • Dec 2012
                      • 567
                      • South Africa
                      No he says you should heat them up on the power supply using a paint stripper gun without melting everything. Get those caps to a cozy 50 degrees celsius and then plug in the tv and see if the rebooting occurs.
                      I would rather used the heat gun on the main board focusing on the caps there since i have had it in the past that some caps "dry out" and heating them makes them work a little better thus proving a point.
                      So, heat up the power supply and start TV and observe power cycling.
                      Secondly do the same to the main board and see results.
                      • moateez
                        • Jun 2014
                        • 119
                        • algeria
                        +1 this is what i mean soryy for my english
                        • alberich2k5
                          • Jul 2018
                          • 13
                          • Spain
                          @moateez no worries at all, and thank you so much for your time
                          I did the heating experiment:
                          Power supply board - still blinking, but no reboot
                          Main board - still blinking, but no reboots
                          However, once the main board cooled down rebooting issues came back.
                          I re-heat it again, et voila, reboot issues gone (but still blinking)
                          And after few seconds TV was turned on, blinking was gone.
                          So I guess they are two separete issues?
                          • moateez
                            • Jun 2014
                            • 119
                            • algeria
                            but fisrt you shlou heat just power suplly not motherboard to find easly the probleme
                            *** if after heating power th not worck you go to heat motherboard
                            now try to change all capasitor like this Red Points
                            • alberich2k5
                              • Jul 2018
                              • 13
                              • Spain
                              Sorry, I miss explained myself
                              First I heated the powersupply and turned on the TV, the rebooting was gone but not the blinking.
                              Later I did the same with the main board, with the same results.
                              However, once mainboard cooled down, the rebooting issues came back. So i re-heated the main board and they were gone.
                              Before starting this post I replaced the 6 caps you marked me since the readings for 12V lines were about 11.5V. (That solved that issue for 12V lines but it didn't for 20V and 3.5V lines)
                              • angelos
                                • Dec 2012
                                • 567
                                • South Africa
                                You should replace all the caps on the main board if you don't have a ESR meter since this TV is quite a few years old and the capacitors have reached their end of life cycle. The internal resistance of the capacitors has gone up due to the drying of the electrolyte within them. So even if the capacitance measure within 10% of its rated value you might measure the ESR value to be elevated considerably. Caps are cheap, Just replace with care since you have to apply a lot of heat on the ,main board in order to melt the solder. Don't damage any tracks by lifting the cap prematurely.
                                • alberich2k5
                                  • Jul 2018
                                  • 13
                                  • Spain
                                  Will do that angelos, and let you know guys. I need to order the caps, and it is going to take a while. I will let you know as soon as I replace them all.
                                  Meanwhile I'm thinking about buying an ESR meter. Any decent - affordable one you can recommend me?
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    These esr meters are good value for the money and can update the firmware too
                                    https://www.aliexpress.com/item/2016...08.0.56.J7yA7x
                                    when you have the tv working after heating the mainboard does the led stop blinking on the front of the tv some lgs do take a while too stop blinking ive noticed
                                    • alberich2k5
                                      • Jul 2018
                                      • 13
                                      • Spain
                                      vinceroger69, ordered thank you very much
                                      Front led works as usual, I haven't notived any thing different.
                                      I also ordered the caps for the main board, will see if I can get it to work; it is quite exciting hehehe
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        can you post a picture of the mainboard used in this set thanks
                                        This forum has all the firmware and mods for that tester its a long read but worth it
                                        https://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/
                                        • flat-earther
                                          Hoover FM216LI cordless vacuum refuses to charge
                                          by flat-earther
                                          I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
                                          I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
                                          5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
                                          So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
                                          06-06-2025, 03:14 AM
                                          MSI Gaming GE75 9SF-1207 Raider Notebook GE Specification for Upgrade or Repair
                                          This specification for the MSI Gaming GE75 9SF-1207 Raider Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GE75 9SF-1207 Raider boardview and GE75 9SF-1207 Raider schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 12:10 PM
                                        • TinkerTron
                                          Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                          by TinkerTron
                                          Hey everyone,
                                          I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                          Instead, here's what's been bugging me so far:
                                          The schematic...
                                          03-06-2025, 02:03 PM
                                        • ttmi100x
                                          HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                                          by ttmi100x
                                          Greetings everyone,
                                          I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                                          The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                                          Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                                          Upon closer inspection...
                                          07-31-2024, 06:36 PM
                                        • artvandalai
                                          What resistor ohm will work better to repair this waterpik?
                                          by artvandalai
                                          The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                                          01-05-2025, 04:10 PM
