Technika tv stuck in standby
  • _ASH_
    • Dec 2011
    • 14
    Hi guy's, i have a technika 22e21b tv which is stuck in standby, from previous repairs Ive just ordered a power board & swapped it (which I've done with this), but with no joy.
    Had anyone got any further suggestions to what the fault could be?
    Many thanks in advance
    ASH
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Technika tv stuck in standby
    Hello Ash, Do you have any photo's of your circuit boards and what voltage readings do you have of the power supply to mainboard connector?
    • _ASH_
      • Dec 2011
      • 14
      Not done any power readings yet as I'm a bit unsure where to measure the voltage & got no photos yet as when I put the new power board in, i thought that would fix it. so I'm going to strip it down again later & look at it.
      Thanks in advance for any help.
      ASH
      • CapLeaker
        Leaking Member
        • 8342
        its probably a main board problem. Look if the main board sends PSon to the PSU.
        • _ASH_
          • Dec 2011
          • 14
          Ive stripped it down again & tried unplugging different plugs from the main board to see if it powers up but with no sucess
          Now the main board part number is: T.MSD309.B51 which a quick search shows that the eprom goes faulty, so I'm thinking to order the main board Unless someone can help me to get the eprom??
          • CapLeaker
            Leaking Member
            • 8342
            can we see pictures from your PSU and main board? Also make a picture where the plug from the main connects to the PSU. Hopefully there are pin out names there?
            • lepak06
              TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
              by lepak06
              Hello
              I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
              The TV is faulty with stuck in Standby RED LED. Can't power the TV.
              Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
              All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
              But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
              01-12-2023, 01:43 AM
            • toty79
              Hisense LTDN50K220WSEU stuck in standby
              by toty79
              Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
              As per Hisense tv title LTDN50K220WSEU stuck in standby
              PSU rsag.820.5687 HLL 4855WF
              Main rsag 7.820.5842
              I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
              05-01-2022, 04:39 PM
            • lego1234567
              LG 32LB1R - stuck in standby mode
              by lego1234567
              Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
              What could be the problem ? Thanks...
              01-21-2024, 03:39 AM
            • Stunt
              Hp Laptop Stuck on Hp protected by hp sure start screen
              by Stunt
              Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
              I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
              I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
              Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
              screen that's it and stuck there. I left it until the following day and i still...
              09-02-2025, 01:51 PM
            • Ukdigger
              Samsung UE46f5000AK Stuck on Standby
              by Ukdigger
              When the Main board is disconnected, the back lights are off but tapping on the chassis makes them light up and all voltages are then good. Connecting the main board up makes the TV work normally until moved. LED INERFACE STRIP BN41-01971A has a short on the first 2 pins on the left of the picture, the cable tests good. All the other pins and all LED strips test good. Is there an easy way to fix the short or do I need a new interface. Any help would welcome.
              PSU number bn44-00610A L46SF_dpn
              1 B13v 12.4
              3 B13v 12.4
              5 Vamp 12.4
              7 Vamp 12.4
              9 GND...
              08-08-2024, 09:17 AM
