Samsung UE40F6340 vertical green Lines
  • Shipmaker
    • Feb 2014
    • 36
    I got a problem with my tv a UE40F6340 there are green vertical lines on the whole screnn ever 2 inches
    In the samsung chat the mean that this maybe a problem of the T-con but otherwise I have look some videos in you Tube where some people work with Heatguns on the mainboard.
    So my question is, is this really a T-con problem or otherwise maybe the panel are gone?
  • Moreno83
    • Jun 2014
    • 2008
    • The Netherlands
    Re: Samsung UE40F6340 vertical green Lines
    T-con or mainboard problem.
    Could you please pictures of the back of the tv? ( Boards ).
    • Shipmaker
      • Feb 2014
      • 36
      Thank you for your answer but excactly this is the question, now i dissambley the tv an work with a Headgun on the mainboard but the vertikal lines appears again.
      But is it possible to work with a Headgun on the T-con?
      Here a picture of the backside
      • viktorkane
        • Jul 2018
        • 32
        • albania
        Hello
        this is defect display
        it is not a t-con defect
        t-con gives figure deformity or does not give a figure at all
        I had such a problem and I changed t-con and the same
        • Shipmaker
          • Feb 2014
          • 36
          Do you also got vertical green Lines every 2 inches ?
          and what modell from samsung you got?
          • budwich
            • Jul 2015
            • 3097
            its unlikely to be a panel / display problem. try disconnecting / reseating / cleaning the cables at the tcon to see if things change.
            • Diah
              • Feb 2013
              • 6366
              Non T-CON or Panel fault, its main board. packing your MB for 10 minute at 280-300 degree ( non air flow oven ) if you have hotair gun then do it only on the main processor.
              • Shipmaker
                • Feb 2014
                • 36
                Yeah I already do the hotair thing on the whole Board there is some Coller placed over the cpu that I didn t turn off, but I will try again after I cleaning the cables with probanol alcohol1
                • Moreno83
                  • Jun 2014
                  • 2008
                  • The Netherlands
                  You need to remove the cables etc from the mainboard. Remove the heatsink on the cpu.
                  Use a heatgun and flux and heat up the cpu. Watch out because the board will bend pretty quick. It is best to make some small balls with alluminium foil and reflow the cpu. Use youtube for example video's.
                  Btw , dont repair Samsung it is shit anyways.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4326
                    • Italy - Milan
                    To understand for sure between mainboard/tcon there is much probably an autotest in the service menu, if it plays well then it's mainboard.
                    • Shipmaker
                      • Feb 2014
                      • 36
                      Do you mean the selftest in the menue sektion, because I do the picture test the first two pictures felt but the thierd picture was ok, or did you mean autotest in the service menu where you also could do a cold factory reset?
                      • Shipmaker
                        • Feb 2014
                        • 36
                        I just do a autotest in service menue it calls Device test and the audio and so on was ok but T con it shows N/G
                        What this means?
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4326
                          • Italy - Milan
                          I mean service menu therefore hidden menu, i don't know where it is the option, it varies but if you want to show all the menus in many pictures...
                          • Shipmaker
                            • Feb 2014
                            • 36
                            But what do you mean when it plays then it is the mainboard, because the test plays!
                            I think you mean if the test didn t work or start sure?
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4326
                              • Italy - Milan
                              I mean if the test doesn't show the defect.
                              • Jandak
                                • Jun 2021
                                • 5
                                • CZ
                                I have a same problem.
                                In Menu/Support/Autodiagnostics/Image test is first picture (beach) with problem, second picture (stripes purple, red, blue, black) with problem, but third picture (stripes white, yellow... red, blue, black) is without problem.
                                Why third picture is without problem.
                                Joe
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4326
                                  • Italy - Milan
                                  You must do the tests in service mode, one at a time and report here which ones shows defect..
                                  • Jandak
                                    • Jun 2021
                                    • 5
                                    • CZ
                                    In service mode T-CON show NG. Is third picture from main board without effect T-CON?
                                    • Jandak
                                      • Jun 2021
                                      • 5
                                      • CZ
                                      https://www.samsung.com/ca/support/t...v-2014-models/
                                      This picture is without problem https://skp.samsungcsportal.com/uplo...mage_3_med.jpg
                                      • Jandak
                                        • Jun 2021
                                        • 5
                                        • CZ
                                        https://tvrepairdepot.com/samsung-20...ture-problems/ -> T-Con
                                        • 265chemic
                                          Samsung LA46A950 aka. LN46A950 - intermittent vertical green lines / distortions
                                          by 265chemic
                                          Hi All,
                                          I have a Samsung LA46A950 that intermittently was displaying issues with evenly spaced vertical green lines only on dark / black areas - this has progressed to more often and blue lines sometimes, as well as a little image distortion.
                                          My initial suspicion was the T-CON board, which I took out and cleaned but the issue persists. A heat gun on all of the control boards makes no noticeable change. Ive also reseated the T-CON to panel ribbons (4 of them) and moving them while the panel is on doesn't seem to change the issue.
                                          Below are some photos...
                                          03-23-2022, 04:53 PM
                                        • arctor
                                          samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
                                          by arctor
                                          hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
                                          04-26-2025, 05:22 AM
                                        • wkx
                                          Samsung P2770H vertical green lines
                                          by wkx
                                          I have a Samsung P2770H monitor, on which I replaced the main board because it has an issue that it would restart itself every X minutes, that resolved that issue.
                                          Now, a few months later I turn the pc on and find 3 1px vertical green lines on the monitor, the lines wont show up on a screenshot. Does the same with dvi or hdmi.
                                          I opened it up and made sure the panel connection to the board wasn't loose and the flat cable looks ok. Pressing the connectors while the monitor is on sometimes changes the line colors from green to blue or yellow, but the lines are always...
                                          04-10-2020, 11:54 AM
                                        • polaro
                                          Thin stable coloured vertical lines on Samsung UN65NU6900FXZC come and go
                                          by polaro
                                          Greetings,
                                          I've bought a used Samsung UN65NU6900FXZC LED TV. It worked fine for some time and then developed, at first, a single very thin (1 pixel) vertical stable blue line, from top to bottom, close to the left edge of the screen. Now it's 3 lines on the left. When I connect HDMI sources the number of the thin lines grow. After disconnecting and cold discharging I am back to 2 lines. The lines disappear at a rate of 15-20 minutes per line. So it does not look like a damaged LED panel. Any advice? Thanks...
                                          08-27-2022, 08:46 AM
                                          09-07-2024, 05:50 AM
