Samsung UE40F6340 vertical green Lines
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4539
    • Italy - Milan
    Re: Samsung UE40F6340 vertical green Lines
    i don't understand you, must be more precise
    • Jandak
      • Jun 2021
      • 5
      • CZ
      OK thaks for your time...
      Problem is on this picture
      In Menu/Support/Autodiagnostics/Image test is first picture (beach) with problem
      second picture (stripes purple, red, blue, black) with problem
      but third picture (stripes white, yellow... red, blue, black) is without problem
      On this page https://tvrepairdepot.com/samsung-20...ture-problems/ is results problem on T-Con board
      In Service menu/SVC/Self Diagnosis/T-CON FRC show T-CON FRC "NG"
      It looks like, if second picture is generate on input T-Con board, that problem is realy T-Con board.
      Is really second picture generated on input T-Con board?
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4539
        • Italy - Milan
        FRC is a supplementary circuit placed prior tcon or the rest of tcon, if frc is separated it is to be replaced, if not replace tcon.. or freeze read and reprogram flash.
        • Falki
          Colorful LCD Vertical Lines on Samsung ue55es8090
          by Falki
          Hello there, ive recently found an older 55inch Samsung SmartTV.
          Sadly it has vertical lines at the left and one line in the middle-right.
          I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
          I have factory resetted the TV as well but also with no luck.
          I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
          A similar issue has been posted as well but also with no actual response ...
          08-12-2025, 04:19 AM
        • 265chemic
          Samsung LA46A950 aka. LN46A950 - intermittent vertical green lines / distortions
          by 265chemic
          Hi All,
          I have a Samsung LA46A950 that intermittently was displaying issues with evenly spaced vertical green lines only on dark / black areas - this has progressed to more often and blue lines sometimes, as well as a little image distortion.
          My initial suspicion was the T-CON board, which I took out and cleaned but the issue persists. A heat gun on all of the control boards makes no noticeable change. Ive also reseated the T-CON to panel ribbons (4 of them) and moving them while the panel is on doesn't seem to change the issue.
          Below are some photos...
          03-23-2022, 04:53 PM
        • arctor
          samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
          by arctor
          hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
          04-26-2025, 05:22 AM
        • wkx
          Samsung P2770H vertical green lines
          by wkx
          I have a Samsung P2770H monitor, on which I replaced the main board because it has an issue that it would restart itself every X minutes, that resolved that issue.
          Now, a few months later I turn the pc on and find 3 1px vertical green lines on the monitor, the lines wont show up on a screenshot. Does the same with dvi or hdmi.
          I opened it up and made sure the panel connection to the board wasn't loose and the flat cable looks ok. Pressing the connectors while the monitor is on sometimes changes the line colors from green to blue or yellow, but the lines are always...
          04-10-2020, 11:54 AM
        • pni
          LG 49uf695v vertical coloured lines
          by pni
          Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
          11-14-2025, 03:15 AM
