Samsung UN60EH6050FXZA no picture or sound Only a blue screen
  • GAStuntman
    • Dec 2017
    • 65
    I have a samsung model #UN60EH6050FXZA which is coming on but has no picture showing or sound. Only a blue screen. I have replaced the main board. The power supply voltage checked out & the back lights are working. Any suggestions would be greatly appreciated..
    Re: Bad luck
    Did you check T-CON voltage?
    Pictures of the whole backside of the TV showing how the boards are connected together so we can see what we are dealing with?
    • GAStuntman
      • Dec 2017
      • 65
      Re: Bad luck
      Here is the picture. I will test the t-con board in a few minutes. Sorry about the picture being sideways. This is my first time uploading a picture.
        Re: Bad luck
        It has integrated T-CON into the LCD panel assembly.
        Do you know the history of the TV?
        This TV has T-CON/TAB bonding boards on the bottom edge of the screen whuch usually get damaged by the clean fluid when people spray the cleaning liquid on the screen and the excess liquid drips on to the T-CON/tab bonding board and causes the damages.
        • GAStuntman
          • Dec 2017
          • 65
          Re: Bad luck
          Lightening strike & it hasn’t shown anything since.
          • Moreno83
            • Jun 2014
            • 2008
            • The Netherlands
            Re: Bad luck
            Do you get a blue screen with every input? You already replaced the mainboard so there is not much left besides input or panel
            • GAStuntman
              • Dec 2017
              • 65
              Re: Bad luck
              I haven’t done anything to the tv since putting the mainboard in & checking the power supply board. Once it powers on nothing works. The remote will turn it on but the volume nor channel buttons doesn’t show on the screen. Nothing shows when I press the buttons on the tv either.
              • GAStuntman
                • Dec 2017
                • 65
                Re: Bad luck
                I disconnected and reconnected everything. Now I’m getting sound but still have a blue screen. I still have to test the t-con board but I’m not sure what I should be looking for during the testing phase?
                  Re: Bad luck
                  Look to see if you do have 12VDC on both ends of the SMD fuse on the integrated T-CON board with ref to chassis GND.
                  • GAStuntman
                    • Dec 2017
                    • 65
                    Re: Bad luck
                    Yes, I got 12.6 on both ends of the fuse.
                    • GAStuntman
                      • Dec 2017
                      • 65
                      Re: Bad luck
                      IC1901 on the t-con board is getting very hot. Is this normal?
                        Re: Bad luck
                        Pictures of the IC1901.
                        Too hot to hold your finger on it for more than 5 seconds?
                        • GAStuntman
                          • Dec 2017
                          • 65
                          Re: Bad luck
                          Yes that's correct
                          • mmartell
                            • Oct 2013
                            • 3189
                            Re: Bad luck
                            Try to capture the markings on the chip.
                            • GAStuntman
                              • Dec 2017
                              • 65
                              Re: Bad luck
                              It’s in the last picture posted above. It says Samsung on the chip & the IC is 1901 (same chip)
                              • mmartell
                                • Oct 2013
                                • 3189
                                Re: Bad luck
                                By "markings" I mean the writing on the chip other than the word Samsung.
                                • GAStuntman
                                  • Dec 2017
                                  • 65
                                  Re: Bad luck
                                  Oh ok. Sorry about that. I didn’t see any marking on the chip. I have replaced the chip & the tv is still doing the same thing (blue screen).
                                  • GAStuntman
                                    • Dec 2017
                                    • 65
                                    Re: Bad luck
                                    There is waiting on the chip. SENK81, 1209-BB, KGT1F. The new chip is doing the same thing. Could this be a panel issue since the t-con & main board has been replaced?
                                    • GAStuntman
                                      • Dec 2017
                                      • 65
                                      Re: Samsung UN60EH6050FXZA no picture or sound Only a blue screen
                                      Replacing the t-con & mainboard did not fix the issue. The voltage on the replacement t-con board wasn’t right either. I’m sending the replacement board back & hopefully the next t-con board will be a working board.
                                      • budwich
                                        • Jul 2015
                                        • 3097
                                        something fishy here... seems some are "talking" about two different things. One says the tcon/ tab is integrated into the panel (which I believe is correct based on the posted picture) BUT the poster then says he replaced the tcon with no better results. This can't be THE tcon as there is no way to do the tabs. Hence, someone isn't on the same page.... and thus checking for 12v at the tcon potentially isn't being done correctly.
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • arbitarytwist
                                          Samsung UN50NU7400 - No Picture (but boot screen and screensaver)
                                          by arbitarytwist
                                          Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
                                          Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ?
                                          03-01-2025, 01:16 PM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
                                        • marekk
                                          Samsung QE55Q67RAT no sound and bad picture when streaming
                                          by marekk
                                          I got Samsung 55 inch QLED QE55Q67RAT where there is no sound at all and when using youtube for example picture is not clear and noisy.
                                          I have swapped Burr-brown 88002A chip on the mainboard but didn't help, different set of speakers didn't help either
                                          Mainboard is based on pcb BN41-02695A BN94-14007B
                                          I will appreciate any help
                                          Many thanks
                                          Marek...
                                          05-29-2025, 02:23 AM
