I have a samsung model #UN60EH6050FXZA which is coming on but has no picture showing or sound. Only a blue screen. I have replaced the main board. The power supply voltage checked out & the back lights are working. Any suggestions would be greatly appreciated..
Samsung UN60EH6050FXZA no picture or sound Only a blue screen
Tags: None
Re: Bad luck
Did you check T-CON voltage?
Pictures of the whole backside of the TV showing how the boards are connected together so we can see what we are dealing with?Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
Re: Bad luck
It has integrated T-CON into the LCD panel assembly.
Do you know the history of the TV?
This TV has T-CON/TAB bonding boards on the bottom edge of the screen whuch usually get damaged by the clean fluid when people spray the cleaning liquid on the screen and the excess liquid drips on to the T-CON/tab bonding board and causes the damages.Never stop learning
Re: Bad luck
Do you get a blue screen with every input? You already replaced the mainboard so there is not much left besides input or panelI only repair Panasonic plasma tv's! Currently owning a TX-P55VT50 and still searching for a ZT60!Comment
Re: Bad luck
I haven’t done anything to the tv since putting the mainboard in & checking the power supply board. Once it powers on nothing works. The remote will turn it on but the volume nor channel buttons doesn’t show on the screen. Nothing shows when I press the buttons on the tv either.Comment
Re: Bad luck
I disconnected and reconnected everything. Now I’m getting sound but still have a blue screen. I still have to test the t-con board but I’m not sure what I should be looking for during the testing phase?Comment
Re: Bad luck
Look to see if you do have 12VDC on both ends of the SMD fuse on the integrated T-CON board with ref to chassis GND.Never stop learning
Re: Bad luck
Pictures of the IC1901.
Too hot to hold your finger on it for more than 5 seconds?Never stop learning
Re: Bad luck
It’s in the last picture posted above. It says Samsung on the chip & the IC is 1901 (same chip)Comment
Re: Bad luck
Oh ok. Sorry about that. I didn’t see any marking on the chip. I have replaced the chip & the tv is still doing the same thing (blue screen).Comment
Re: Bad luck
There is waiting on the chip. SENK81, 1209-BB, KGT1F. The new chip is doing the same thing. Could this be a panel issue since the t-con & main board has been replaced?Comment
Re: Samsung UN60EH6050FXZA no picture or sound Only a blue screen
Replacing the t-con & mainboard did not fix the issue. The voltage on the replacement t-con board wasn’t right either. I’m sending the replacement board back & hopefully the next t-con board will be a working board.Comment
something fishy here... seems some are "talking" about two different things. One says the tcon/ tab is integrated into the panel (which I believe is correct based on the posted picture) BUT the poster then says he replaced the tcon with no better results. This can't be THE tcon as there is no way to do the tabs. Hence, someone isn't on the same page.... and thus checking for 12v at the tcon potentially isn't being done correctly.Comment
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
Have a Samsung UN50NU7400 which shows a boot screen and a screen saver if left on long enough but no picture ?
Would a moving screen saver confirm that the panel is ok or it could still be a panel issue ? -
by jchangHi all
I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
Symptom:
No picture no sound.
When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
No sound at all.
What I tried:
1. I tried unplugging the left or right ribbon... -
by marekkHi,
I got Samsung 55 inch QLED QE55Q67RAT where there is no sound at all and when using youtube for example picture is not clear and noisy.
I have swapped Burr-brown 88002A chip on the mainboard but didn't help, different set of speakers didn't help either
Mainboard is based on pcb BN41-02695A BN94-14007B
I will appreciate any help
Many thanks
Marek... - Loading...
