P&F (Philips) 55PFL6900/F7 Turns on 3seconds then Off
  • Keshenatech1
    • Apr 2018
    • 149
    Re: P&F (Philips) 55PFL6900/F7 Turns on 3seconds then Off
    Yes it was the LED strips, several shorted LED's on each one. If you have one of those testers you can measure the voltage of each section 3v drop per LED and I remember some as low as 12V total with several shorted.
    • pick1e
      • Oct 2018
      Mine was LEDs too. I opened it up and found the bottom row not lighting up at power on. I plugged the top row into the PS connector for the bottom row and they came on fine for the 3 second boot up, so I figured PS was good just the two bottom strips were bad. So I ordered a new set. They came in quickly, replaced them tonight, and good as new. Thanks
      • Tbone101
        • Oct 2019
        Where did you order the backlights from for this model,
        Thanks!
        • Tbone101
          • Oct 2019
          Where did you order the backlights from?
          Thanks!
          • nomoresonys
            • 12323
            • U.S.
            Need a tuner for this mainboard, anyone know who sells them?
            • alpersen
              Philips 40 PUK6809/12 Backlight turns off after 10-20 seconds
              by alpersen
              Hello
              Mother called and said TV turns off after switching on. So after turning on Philips logo shows and probably 10-20 seconds image disappears, sat receiver is connected and sound is heard from source. So I turned on my phones light and I can see the image it seems backlight was off after some time. I dis assembled the cover hoping to see a distinc cap blown or leakage. Here are photos I took (I was after 22:00 pm and maybe some of them are dark). Should I order and change caps on the power circuit or what would you recommend? Thanks...
              07-25-2024, 12:50 AM
            • ressof
              Philips 47PFL4606H/12 turns off after 10 minutes
              by ressof
              Hi
              I have a Philips LCD 47PFL4606H/12 that turns off after around 10 minutes and then i cant turn i back on again without removing the power cord and attach it again. Then it turns itself off again after some minutes. When this happens the red led that usually indicates standby mode is off.
              Can it be the same problem as in this thread?
              https://www.badcaps.net/forum/showth...ght=47pfl4606h
              01-23-2023, 12:52 AM
            • Stephen
              MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
              by Stephen
              MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
              03-15-2024, 09:37 AM
            • www
              LG L192WS-BN backlight turns off after 1 second
              by www
              I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
              I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
              03-24-2024, 05:26 PM
            • Tyrmas
              Philips 58PUS6809/12 doesn't turn on - LED turns on for a second and TV clicks
              by Tyrmas
              Hi all!
              A few days ago my TV suddenly turned off while watching Netflix from my media PC. Only connected cables were HDMI and TOSLINK. It immediately started doing this loop where the power led turns on for a second and then turns off. You can also hear a click inside the TV every time.
              I tried the easy stuff first like disconnecting everything including the power cord but that didn't fix the issue.
              Now I opened the TV to check if there are any bad capacitors but as far as I can tell, they look okay.
              I've attached a few pictures and...
              08-24-2021, 04:33 AM
