Sharp LC-60EQ10U Dark Screen
  • JessJ
    • Jul 2018
    • 17
    Hello everyone. Glad to be a new member and looking forward to learning more.
    I have this Sharp 60" TV. It powers on and the screen is dark. You can see the images moving so is the backlight the issue? Where do I start?
    Jess
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    Re: Sharp LC-60EQ10U Dark Screen
    Sounds like the backlights are not coming on. Have you removed the back yet?
    They call me......."threadkiller"
    • JessJ
      • Jul 2018
      • 17
      Yea I have the back cover off.
      • DXseekerMO
        • Feb 2018
        • 1119
        • US
        The people on the board here need pictures of the back of the TV with all boards installed so we can see the layout and pictures of each individual board in case we have to help trace circuits. Please be sure they are clear and well-focused.
        • DXseekerMO
          • Feb 2018
          • 1119
          • US
          After posting the pictures I also recommend:
          At the top of the "Troubleshooting TV's and Video Sources" page are items marked "Sticky". Please take the time to read these before attempting any troubleshooting on your own. Contained in these "Stickys" are basic information that will help you learn how to troubleshoot safely and excellent information from highly knowledgeable and professional electronics technicians who put those there to help you know how to get started.
          Be patient, people in here have lives they live outside of the forum but are truly dedicated to helping people with good information when they can. Troubleshooting through a forum isn't the fastest way to go, but if you have never troubleshot a TV this is the place to glean good information from helpful, patient people. Trust me, they had to be patient when I showed up!
          When troubleshooting with a meter, BE PRECISE, FOCUS on the job in front of you and BE CAREFUL! There is 400V plus inside the TV and that will kill you. Another thing you can trust me on....imprecise or sloppy motions while measuring voltages will lead to the destruction of other components. I have stories.............
          • JessJ
            • Jul 2018
            • 17
            Here are pictures of the back and the boards.
            https://ibb.co/nNnGYd
            https://ibb.co/hgcN6y
            https://ibb.co/e9c0td
            https://ibb.co/maJODd
              Read this thread to see how to check the Voltages at the LED connector and also how to check and see if the backlights will come on or not.
              https://www.badcaps.net/forum/showthread.php?t=63972
              • JessJ
                • Jul 2018
                • 17
                Bud I read through it. I don't know what a T-con board is etc. I am more mechanical savvy than electrical boards. Where should I start?
                • JessJ
                  • Jul 2018
                  • 17
                  bump?
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4297
                    • Italy - Milan
                    Jess, your description of the fault is imprecise, post a picture of the defect, or if the image is completely black from a distance of 1m or in a dark room then continue to troubleshoot backlight.
                    • Andrew F. Ali
                      • Jan 2014
                      • 2450
                      • Trinidad & Tobago
                      This is a definite backlight issue. The difficulty here is really handling the thin glass screen They break easily if handled badly. You would need vacuum cups to pick up the fragile glass screen.
                      • JessJ
                        • Jul 2018
                        • 17
                        • JessJ
                          • Jul 2018
                          • 17
                          • budwich
                            • Jul 2015
                            • 3097
                            these pictures don't align with your first post about "dark picture" as these clearly show the menu along with "picture static" (no input). Please explain. Further, based on the distortion along the top left side of the menu, it would appear that you have a panel problem but it is difficult to say for sure without a proper input signal and explanation.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4297
                              • Italy - Milan
                              if you have a big box full of things put it behind the tv as a stand and do some better pictures, anyway it seems to me the common panel fault that is fixable with piece of adhesive tape, second detach one at a time the lvds ribbons that outputs from the tcon and see with which one the half picture is perfect.
                              • JessJ
                                • Jul 2018
                                • 17
                                Ok I will get those. Budwich, The way I described the issue was the way it was when I got the TV. After taking the back panel off, tipping it up and starting it, this is what it looked like. Totally different I agree. I will get my wife to hold it up for better pics.
                                • budwich
                                  • Jul 2015
                                  • 3097
                                  :-( no problem.... but that does sound good. As suggested, likely a panel issue but potentially it can be save by a couple of "techiniques"... but it really depends on you providing good pictures of the display with a good knowable picture (test signal).
                                  • JessJ
                                    • Jul 2018
                                    • 17
                                    Ok sorry for the wait guys. Family stuff so my tv got put on a side burner
                                    Here are the pics of it. I had it hooked to a VCR to get some video pics. I did not have a video playing but you can see what its doing.
                                    • JessJ
                                      • Jul 2018
                                      • 17
                                      Bump
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4297
                                        • Italy - Milan
                                        The last pictures are too small, how do you have published them?
                                        • scubacamper
                                          Sharp Aquos LC-70C6400U Half Screen Dark
                                          by scubacamper
                                          I found another post on this site the other day which has been very helpful in troubleshooting this issue I am having with my tv. The left half of the screen is dark, and the other half is VERY slow to generate it's image - and it only generates part of its image at that.
                                          Based on this yt video, I have narrowed it down to an issue (short?) on the left side of the display, somewhere in the system of ribbon cables.
                                          when I remove the bezel and the rear cover, I can get the image to display correctly by manipulating the ribbon cables on the left side which connects the left lower display...
                                          05-03-2025, 12:19 PM
                                        • Chrissygizmo
                                          by Chrissygizmo
                                          02-10-2025, 12:33 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • EazyBone
                                          Sharp LC-65Q620U White Screen
                                          by EazyBone
                                          Another TV topic!!
                                          I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                                          The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                                          Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                                          08-21-2024, 12:56 PM
                                        • Mad_Science
                                          Sharp TFT-LCD Model No. LQ050Q5DR01 gray screen
                                          by Mad_Science
                                          I have a older eddy current tester made by Olympus that uses interchangeable TFT-LCD screens. I have two devices that each take the same removable screens. One is an Olympus NORTEC 200D+ and the other is an Olympus SONIC 1200M EMI. I have searched the internet high and low for service manuals for these units with no luck. Both these units were used extensively by the US military for NDT on airplanes. The detachable screen plugs into the base unit via a weird non standard VGA connector. Buttons on the removable display are used to power the units on. When the power button is pressed the unit makes...
                                          03-01-2024, 05:05 PM
