LG 55LB5900 Totally Dead!
    Re: LG 55LB5900 Totally Dead!
    If you look at the application circuit:
    1) Try to locate the string of resistors connected to VH (pin 1) to see what resistance they are.
    2) Check the resistance between VCC (pin 10) and GND to see what it is.
    • jason123
      • Oct 2015
      • 1068
      Ok, so Pin 1 has 4 resistors and 1 Diode in series. Values of resistors are right on (30.k +2.2k+2.2k+2.2k) and diodes tests ok.
      Pin 10 does not seem to be connected to anything. resistance between Pin 10 and Pin 12 (GND) is 10 Ohm
        Are you sure you count the pin 10 VCC pin correctly? The resistance between VCC pin and GND should not 10 Ohms, it should be in the K Ohms range. There should be filter cap between VCC pin and GND pin also.
        The trace on VCC pin may have routed under the IC, this will require you to trace out the board, it is part of reverse engineering that is required when there is no schematic available, but at lest you now have the spec sheet of the IC showing how each pin is used.
        • jason123
          • Oct 2015
          • 1068
          So this is a 1 layer pcb it looks like The VCC is routed underneath the IC and comes out down at the bottom (between pins 8 and 9).. indeed, there is a 10 ohm resistor in series with a diode that goes through a cap to pin 14. pin 10 also goes to couple of diodes and caps.. I'll try to draw the circuit and upload.
            Since you removed glue and able to see the traces better, can you please zoom out more so I can see more traces? It will also help to get high res pictures of the whole bottom side of the board.
            • jason123
              • Oct 2015
              • 1068
              I will shortly.. I'm trying to remove more of the glue so pictures can look clearer. And yes, I should have thanked you for finding this part. I looked for a while with no luck.
                Check the resistance between the two legs of the lytics cap C112, it is the starup/running cap for the SMPS IC.
                • jason123
                  • Oct 2015
                  • 1068
                  So, C112 is measuring 10.1 Ohm, in-circuit with a regular DMM. ESR is 7.12 Ohm (high) and Capacitance 97.2 uF (100 uF value - so close enough).
                  I'm sorry, I measured the P10 and P14 resistance and it's 720 kOhm. I must have had the wrong pins before.
                  Took the cap out of circuit and it measures 11.3 Ohm.
                    At this point you either have internal short in the IC or shorted cap (not the C112, but the SMD ceramic cap that is also connected between VCC pin and GND.
                    Check the resistance of the CAP that is right next to the ZD102 (not installed), also check C108 resistance. Also check the resistance of Zener diode ZD103 (it is connected in parallel with C112).
                    https://www.badcaps.net/forum/attach...7&d=1531506842
                    BTW, your board layout is not the same the one I post from shopjimmy.
                    We are getting close to find the cause of the problem.
                    • jason123
                      • Oct 2015
                      • 1068
                      So once i removed the cap c112, the resistance across pads is up to 746k ohm. Just curious why you don't think the c112 is the culprit?
                      • jason123
                        • Oct 2015
                        • 1068
                        C near ZD102 IS 3.6Meg
                        C108 849kOhm
                        ZD103 is 746k
                          I hardly see newer lytics cap shorted out, in the old days they do have shorting out problem. So if you check the resistance of the cap right now it shows about 10 Ohms?
                          • jason123
                            • Oct 2015
                            • 1068
                            Yes.. it's a 100uf 50V. The only one that's 50v is a 470uf laying around... should I try it?
                            • jason123
                              • Oct 2015
                              • 1068
                              Ok i am getting 3.5v on connector as labeled! Good sign? Hopefully i didnt cause more damage with such large cap. I think it was the C112 or premature?
                              • jason123
                                • Oct 2015
                                • 1068
                                budm... you're awesome.. thank you. One final stupid question... the glue stuff has the hot glue consistency... can i use hot glue?
                                  I would get closer value cap to the original, when you go up in capacitance, you will get more inrush current.
                                  That stuff is not really glue, more likely to be conformal coating or electronics grade silicone.
                                  I am glad that it is just bad cap not the IC, what you have learnt from this thread is worth a lot more than $39. Glad to see you got it working.
                                  • jason123
                                    • Oct 2015
                                    • 1068
                                    Thanks to you my friend. Much appreciated
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      #38
                                      Glad you have managed too get the tv working there has been some good fault finding tips in this thread im sure it will help a lot of people out
                                      • jason123
                                        • Oct 2015
                                        • 1068
                                        Me too! thanks vinceroger69
                                        • sputnikoff
                                          • Feb 2016
                                          • 203
                                          • canada
                                          #40
                                          I was attempting to rule out lamp issues as I have replaced all with new and I shorted 18 pin cable, vcc 3.5 and pwr on and drv on,board cap voltage goes to 395 vdc . At this point I think issue is with main board module eax65391003.As lamps come on with 3.5 vdc signal and drv on shorted.
                                          • Mike Russell
                                            Lenovo 14ALC6 - NMD521 - No power, totally dead.
                                            by Mike Russell
                                            Machine won't power on, no power led, no fan spin, completely dead.
                                            Checked PQ5400 - AONS32314 and pins 5,6,7,8 are 20v (AC adaptor voltage) but pins 1, 2, 3, 4 are 0v.
                                            Following Gate Pin 4 to PU5400 - BQ24780SRUYR.
                                            VCC 20v
                                            ACDET 2.8v
                                            ACDRV 0v (goes to pin 4 gate of AONS32314).
                                            ACOK 0v
                                            REGN 6v
                                            According to datasheet, conditions are correct for ACOK to be high but it is not.
                                            Tracing ACOK it's connected to ACIN which is connected to a pin GPB0 of IT8227 but also shown as connected to +3VL via a 100k resistor...
                                            12-25-2024, 08:31 AM
                                          • phantomEVO
                                            [HELP] 2 Imac 820-2641 TOTALLY DEAD: NO LED/1 LED
                                            by phantomEVO
                                            hi to all! please help with 2 imac 21,5 dead...
                                            i already changed u7700 in both without luck
                                            u7700 pin 17, 18, 5, 4, 24, 12
                                            have those voltages in both imac..
                                            12v, 5v, 5v, 5v, 0,3v, 3,9v
                                            i have 3V3_S5 (L7710) in one imac (one led) but no 5v on L7750
                                            NO SHORT ON L7750
                                            i have not 3V3_S5 (L7710) in the other (no led)
                                            PLEASE HELP I'M GOING CRAZY!!
                                            01-25-2024, 01:46 PM
                                          • phantomEVO
                                            [help]820-00165 TOTALLY DEAD! NO LED LIGHT CHARGER
                                            by phantomEVO
                                            've found in diode mode a super low value on pp3v42_g3h...removing l7095 and l7090, i've injected voltage on the line and found that u5000 become hot (3v 0,0100 amp)
                                            replaced u5000 with a brand new one now i have
                                            PPBUS_G3H=8.18
                                            3V42_G3H=3.42
                                            3V3_S5 3,3
                                            no voltage for PP3V3_SUS (no shorts
                                            on u8020 i have 0v on P3V3SUS_EN no shorts
                                            0v on R1464 no shorts
                                            SMC_ADAPTER_EN, 0v
                                            PM_BATLOW_L, 3,3
                                            PCH_DSWVRMEN, 0v
                                            PM_DSW_PWRGD 0,9v​...
                                            02-26-2024, 10:08 AM
                                          • pixellegolas
                                            Lenovo yoga 3 pro, totally dead
                                            by pixellegolas
                                            Hi!
                                            I have this laptop and first let's go through what happened
                                            Went totally dead, no reaction
                                            I thought it was the adapter so I bought a new one = nothing happened
                                            Opened up the laptop and adjusted the battery cable = Started working
                                            Worked a couple of days and then went totally dead again
                                            Now nothing works
                                            I have opened the laptop, removed basically all removable components. It does not start without the battery or harddrive or anything disconnected.
                                            Testing with voltmeter I can see 5.3V basically...
                                            09-05-2020, 11:16 AM
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
