[help]820-00165 TOTALLY DEAD! NO LED LIGHT CHARGER
  • phantomEVO
    • Mar 2013
    • 509
    've found in diode mode a super low value on pp3v42_g3h...removing l7095 and l7090, i've injected voltage on the line and found that u5000 become hot (3v 0,0100 amp)
    replaced u5000 with a brand new one now i have
    PPBUS_G3H=8.18
    3V42_G3H=3.42
    3V3_S5 3,3
    no voltage for PP3V3_SUS (no shorts
    on u8020 i have 0v on P3V3SUS_EN no shorts
    0v on R1464 no shorts
    SMC_ADAPTER_EN, 0v
    PM_BATLOW_L, 3,3
    PCH_DSWVRMEN, 0v
    PM_DSW_PWRGD 0,9v​
  • mon2
    • 14726
    What is the voltage to ground of ALL_SYS_PWRGD ? Is it pulsing ?
    reference:
    820-00165-A - PM_SLP_S4_L missing | Rossmanngroup Forums
    • phantomEVO
      • Mar 2013
      • 509
      No voltage at all on this line
      should i program smc? how? it is new
      • phantomEVO
        • Mar 2013
        • 509
        i don't know what to do...
        • reformatt
          • Feb 2020
          • 1535
          PPBUS_G3H=8.18 --> should be 8.6V if SMC is running
          You can only use SMC's from donor boards. If it's blank and never been programmed that will not work. You can use a SMC from 820-3437 board and reprogram it for a 820-00165 board using Muerto's SMC flashing tool. Board will still boot, just have issues with audio IIRC until you use the tool.
          • phantomEVO
            • Mar 2013
            • 509
            I’ve found Line ppvrtc_g3h shorted… even removint u1900 i have the short.
            is it game over?
            https://www.dropbox.com/scl/fi/fwulr...co4lr9nwf&dl=0
            • phantomEVO
              • Mar 2013
              • 509
              ok what do you think of last video?
              • reformatt
                • Feb 2020
                • 1535
                Shorted PCH by the looks. Put it in your donor pile.
                • phantomEVO
                  • Mar 2013
                  • 509
                  ok
