Bright leds LG tv
  • Newbie123
    • Oct 2015
    • 58
    Bright leds LG tv
    Hi all having a problem after fixing some led strips with new leds and putting the diffusers back on when reassembling the tv they can be seen through the screen.Is there anyway of getting around this?,i think its because of the tape i use to stick the led strips back on being so thick therefore bringing the leds closer to the screen?
  • Diah
    • Feb 2013
    • 6593
    Re: Bright leds LG tv
    the first reflection plate ( the hard one) its wrong . if its Direct LED then the smooth surface should be on the top. id its edge LED then look on the plate at end of the side opposite to LED side it should be covered with white type.
    • Newbie123
      • Oct 2015
      • 58
      Im sure i put the sheets back in the right order,its only the leds that i have stuck the reflectors back on that i can see through the screen?.The original leds that i did not glue the reflectors back on to cannot be seen...
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        is the phosphor area of your replacement leds (yellow stuff) round or square?
        i found that the ones with a square dont spread into the tir lens correctly and you get hotspots.
        • attainteddragon
          • Apr 2013
          • 764
          • australia
          picture please.
          have you placed double sided tape across entire sections of led strips, and how many sections?
          WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
          • vinceroger69
            • Mar 2012
            • 6714
            have you got a link for the replacements leds you have used and yes pictures of the led strips used in your tv so we can see and advise you better
            • SLK001
              • May 2014
              • 264
              When you attached the lenses back, you didn't properly center them over the LEDs. This is a hard lesson that I also had to learn. Now, I use 5 minute epoxy for glue, and viewing from directly above, center the lenses until I can see the LED clearly underneath. When you tear back down to the backlights, look at the bad versus the good LEDs to see what I mean
              • mmartell
                • Oct 2013
                • 3189
                Originally posted by slk001
                when you attached the lenses back, you didn't properly center them over the leds. This is a hard lesson that i also had to learn. Now, i use 5 minute epoxy for glue, and viewing from directly above, center the lenses until i can see the led clearly underneath. When you tear back down to the backlights, look at the bad versus the good leds to see what i mean
                +1
                • Newbie123
                  • Oct 2015
                  • 58
                  What tape do people use to fix the strips back to the television,btw thanks for everybodys input.
                  • Newbie123
                    • Oct 2015
                    • 58
                    double sided tape on the 3 strips that i have problems with,the strip that i did not remove you cannot see the leds through the screen..
                    • attainteddragon
                      • Apr 2013
                      • 764
                      • australia
                      still waiting for that pic.
                      wanting to see if it looks like a spacing issue or an alignment of the lenses.
                      • Newbie123
                        • Oct 2015
                        • 58
                        this is what the lens are like,the tv is assembled atm i will be taking it apart again next week prob,thanks.Ive ordered some different double sided tape that is ultra thin im going to try that when i take it apart,i still think its the thickness of the tape i was using..
                        • zomi
                          • Nov 2011
                          • 512
                          its going to be the lens not being seated properly
                          best to use a glue epoxy that lets you move it around
                          and do while you have power to the leds and that way u can put the diffuser down to check alignment.
                          • gabiz_ro
                            • Mar 2011
                            • 171
                            • Romania
                            That lens are more hard to fix on right position.
                            I found in my contry online shop who sell some pen with gel adhesive with UV cure.
                            Put some gel on support pins,center lens,attach first plastic layer and see if is OK.
                            If not try to re adjust lens.When result is OK light with provided UV led that lens for few (or more) seconds.
                            • Newbie123
                              • Oct 2015
                              • 58
                              Hi thanks for all your comments i have the uv pen and will try that but i believe that its a spacing issue with the thickness of tape im using,can people tell me what tape they use to fix the led strips back on to the tv please and where they buy it from?,many thanks.
                              • diif
                                • Feb 2014
                                • 6978
                                • England
                                I use thermal double sided tape from Aliexpress. 10mm or 12mm, comes in blue rolls.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  Thanks diif ive just ordered some of this its a good price from aliexpress
                                  https://www.aliexpress.com/item/10mm...ceBeautifyAB=0
                                  • Andrew F. Ali
                                    • Jan 2014
                                    • 2450
                                    • Trinidad & Tobago
                                    Some LG LED TVs use 6V LEDs. If you replace the originals wit the common 3V LEDs you will get the hot spots issue.
                                    • Newbie123
                                      • Oct 2015
                                      • 58
                                      Thanks andrew i def used the right voltage leds to replace the faulty ones in my tv,i too have ordered the thermal tape suggested,i was wondering whether anybody else has tried using the vestel type of diffusers instead as i dont seem to have this problem with the vestel tvs when i fix them i dont get any bright spots..
                                      The bright spots i have are on all the leds that i have glued the difusers back on and not just the ones i replaced.Thanks for your input though Andrew,all useful information.
                                      • Newbie123
                                        • Oct 2015
                                        • 58
                                        So has anybody used the vestel diffusers instead of the lg ones which seem to be hard to get in to the right position?
                                        • lmcancu
                                          RCA RLDED 4331B: 43 inch LED TV: Backlight issue
                                          by lmcancu
                                          Hi I am having an issue with the LED backlight of this TV. I can see the picture with a flash light, so I determined it was a backlight issue.
                                          Initially, after opening it I found 2 shorted and 1 open LED on 2 strips (total of 4). I removed the LEDs and shorted the pads together to verify if the backlight would work.
                                          Testing it, I found the backlight turned on and I measured 54V when TV was in standby (off), and 100v when TV was turned on. The 4 strips each contain 9 LEDs, so 36 in all minus 3.
                                          Instead of putting it back together I decided to replace...
                                          04-01-2023, 01:11 PM
                                        • edugimeno
                                          About replacing individual LEDS on BL strips
                                          by edugimeno
                                          Hi There!
                                          Having fixed 5-6 TV sets by replacing full LED strips, and having watched other people fix that by replacing just one LED in the strip, my question now is what should I consider before doing so.
                                          At this time I have some old strips removed from TV's with all but one LED working. Are there different voltage/current LED on different strips? Are 99% of them just the same and interchangeable?
                                          How do you find which specific model is needed for each strip? When I check if a LED is OK by attaching the multimeter leads to the individual led pads on the strips I...
                                          11-07-2022, 11:12 AM
                                        • THE GTC
                                          Insignia NS-37D20SNA14 intermittent LEDs
                                          by THE GTC
                                          So I use this TV daily as a second monitor for my PC or my Playstation - at one point a few months back I tried to fix the problem - but in the process, I figured out something that works so I haven't posted this for awhile. It is an annoying trick to have to do though, so I decided to post about it to see if anyone could spot what's wrong. It baffles me because it works on it's own half the time.
                                          When I first got this TV, I was told it wouldn't turn on, and of course I did the flashlight test, and the image was there. Also, the red LED on the front indicated that it had power (it...
                                          11-03-2020, 02:40 AM
                                        • x_orange90_x
                                          Backlight Reflector Modification
                                          by x_orange90_x
                                          I am writing this because I came looking for the same information but couldn't find anything. There are certain model tvs that will have 2 or more different backlight strip configurations and there is often no way to tell exactly what you have without disassembling the panel. Twice now I have run into this issue and ended up ordering the wrong sets BOTH times. The previous TV I reordered the correct ones and went on my way. The second one I had no patience for returns or reorders, let alone peeling the brand new strips back out and risk damaging them.
                                          The number of LEDs per pair is...
                                          03-12-2024, 08:32 AM
                                        • Yanleb
                                          Vizio M70-D3 4K with dark spots backlight issue
                                          by Yanleb
                                          I have a Vizio M70-D3 4K with a dark spots backlight issue. It is using the Y8387248A backlight driver board.
                                          On this model each of the 64 transistor powers 2 LEDs. Using my TKDMR TD3H backlight tester I've determined that the backlight LED strips were the issue, and the backlight driver board was just fine. Some LED pairs required 5.9 volt at 155mA, some required 9.5 volt and some were completely open.
                                          I've removed the LCD panel and once the LED strips were exposed I've tested them again by connecting my LED tester directly on the test pads. To my surprise all, I've...
                                          03-22-2022, 01:06 AM
