General CCFL inverter question
  • angelos
    • Dec 2012
    • 571
    • South Africa
    Good evening.
    If a ccfl lamp lights up for 2 seconds and only the one side of the lamp lights up and then it shuts down. Sometimes it works fine.
    Is it a lack of high voltage? Lamps tested with HV tester and they are all ok.
    There is a plug from tcon to inverter with sync info. If this info is missing can there be this same issue?
    I checked the ballast transformers and didnt notice any large resistance difference.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: General CCFL inverter question
    That symptom has nothing to do with sync info but could either be not enough high voltage or bad CCFL.
      Those CCFL tester does not have any protection circuit to detect if the lamp is drawing too much current or not, so worn out lamp will draw more current but it will still light up with tester.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Originally posted by budm
        those ccfl tester does not have any protection circuit to detect if the lamp is drawing too much current or not, so worn out lamp will draw more current but it will still light up with tester.
        +10
        • angelos
          • Dec 2012
          • 571
          • South Africa
          Is there anything i can do to prove its a lamp or lack of high voltage? I dont have those kinds of lamps and getting them takes 3 months....
          • mmartell
            • Oct 2013
            • 3189
            If you're talking about one suspect lamp swap it with a lamp in another location and see if the problem moves.
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              The Inverter is working since you are getting Hi-voltage out from the transformers which are working. Do as mmartell suggests and then have patience and wait for the new lamps.
              • angelos
                • Dec 2012
                • 571
                • South Africa
                If all the lamps do not illuminate fully how do i determine which ones to swap out with which? All the lamps illuminate 1/3 of the way before shutting off. I have some lamps which i must just check the length? Does diameter make a difference???
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  How many lamps does this TV carry? To fully test the Inverter you could use those house spiral fluorescent lamps and remove the screwed lamp socket part to remain with the spiral and the 2 thin sires an connect them to the Inverter outputs. You can use the 13-20W size depending on the TV screen size. I have 4 of them to test Inverters, but opt to convert the CCFL backlights to LED backlights if the lamps are the fault and repair/replace Inverters if I can get them if the CCFLS are good.
                  • angelos
                    • Dec 2012
                    • 571
                    • South Africa
                    Hi Guys, I have feedback on those lamps. I replaced 10 out of the 14 lamps with new and the problem persisted. Then i started swapping out the old lamps on the last 4 with no luck. I did however notice that the top two lamps if they are removed the lamps illuminate properly so i thought the fault lay on that rail. I replaced the HV transformer with another and still no luck. The problem persists. Please check the photos's.
                    • dick_barton
                      • Aug 2015
                      • 6642
                      • Wales
                      You may have a capacitor fault between the HV transformer and lamp connector.
                      • R_J
                        • 9535
                        Likely a problem with the inverter for those top ccfl's, when the top lamps are driven they load down the whole inverter circuit.
                        • angelos
                          • Dec 2012
                          • 571
                          • South Africa
                          There are no capacitors between the HV transformers and the lamps. I will check again just to make sure. I must say though that once the tv's backlights switch off and the tv is running without back lights if you give a it a good knock then suddenly all the lights come on and the set works fine for a while. Weird since i thought that if the backlight inverter trips it locks in that state until you power cycle the tv. This might be a dry joint somewhere. I knocked on all the smd components but that never made it work but suddenly then if you smack it it comes to life. This is really weird.
                          I discovered this symptom today!!!!!!!!!
                          • R_J
                            • 9535
                            You could try posting some pictures of the inverter board etc, maybe someone will recognize the board. maybe list the inverter board numbers also
                              Originally posted by r_j
                              you could try posting some pictures of the inverter board etc, maybe someone will recognize the board. Maybe list the inverter board numbers also
                              +10
                              • mmartell
                                • Oct 2013
                                • 3189
                                Oh I have a new guess. That looks like it could be the infamous SSL-14xxx inverter. If someone removed that inverter improperly before it got to you then it's fate was sealed.
                                Remove each tube and check each connector for signs of carbon/burn/blackness. That metal should be shiny and smooth.
                                Like the one on the left, not the right...
                                • angelos
                                  • Dec 2012
                                  • 571
                                  • South Africa
                                  I will check and get back to you with photo's. Had been sick... Thanks.
                                  • angelos
                                    • Dec 2012
                                    • 571
                                    • South Africa
                                    Hi Guys,
                                    I got the pictures. You will see that the inverter board is number SSI_400_14A01 in the pictures i uploaded. I removed the HV connection to look for a carbon path or carbonised contacts and did not notice any. I did however see that these contacts are not shiny but rather have changed color due to getting hot.
                                    I took oscilloscope readings on the transistors driving the HV transformers primary winding once when the inverter runs correctly and once when it comes up with that half lit tripping story.
                                    What is evident is that the duty cycle when running correct is about 50% but when its about to fail its almost 95% "on".
                                    Is this a clue to whats happening?
                                    Photo's to follow
                                    • angelos
                                      • Dec 2012
                                      • 571
                                      • South Africa
                                      These are the pictures
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        Reeceyburger had a long thread on this inverter. He said it's full of dry joints so you may as well check that out. Maybe search for the thread for all the ins and outs.
                                        • ttmi100x
                                          HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                                          by ttmi100x
                                          Greetings everyone,
                                          I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                                          The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                                          Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                                          Upon closer inspection...
                                          07-31-2024, 06:36 PM
                                        • mikey5791
                                          Help on Samsung Syncmaster T220 dead ccfl lamp
                                          by mikey5791
                                          This monitor previously is my main working monitor which i have been using for 8~9 years. Yesterday, when i switched on my pc from fresh to power on, the monitor is just black no display. I started dismantle to look inside the monitor power board but nothing looks suspicious or burnt. So i took my external ccfl inverter to try to power the monitor ccfl lamps which consisted of 2 lamps on upper part and 2 lamps on the lower part.
                                          Found out the upper ccfl lamp which is supposed to connect to cn304 on the power board did not light up. Then i installed a used working...
                                          10-18-2020, 03:17 AM
                                        • vestaviascott
                                          Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
                                          by vestaviascott
                                          Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
                                          Here's what happens:
                                          1) Power on
                                          2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
                                          3) Blue status light flashes for appx 4 minutes...
                                          07-29-2020, 06:08 AM
                                        • Gentian
                                          APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                          by Gentian
                                          I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                          It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                          03-06-2023, 07:07 AM
                                        • valvashon
                                          Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                          by valvashon
                                          For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                          History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                          01-04-2024, 01:44 PM
