LG 47SL80 Horizontal "Dashes"......
  • Michale32086
    • Nov 2011
    • 1453
    Horizontal Dashes in an LG LCD TV
    Main board or Tcon???
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LG 47SL80 Horizontal "Dashes"......
    Try cleaning and reseating the LVDS cable at both ends and the FFC on the T-CON Bd. to the Source/Panel Bds. Looking again at your 2nd pic, is the image showing whitish on the screen?
    • Michale32086
      • Nov 2011
      • 1453
      Nope.. That's just the glare...
      This appears to be an LCD and has a pair of ... crap brain fart... can't remember their name... Diverter boards??.... INVERTER!!!
      It has inverter boards.. Maybe they are the problem???
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Are they flashing or are they stationary? Actually I've never encountered anything like this before.
        • Michale32086
          • Nov 2011
          • 1453
          They seem to be moving all over the screen...
          I'll get a better pic when I get to the shop...
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Have you tried just running the test pattern as shown in the attachment. It would eliminate the panel and Tcon as the fault.
            • Michale32086
              • Nov 2011
              • 1453
              Thanx for that.. I'll give it a shot..
              Everything looks clear except jumpering the 12v from the fuse to the SMPS board??
              What's the SMPS Board??
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                SMPS: Switched Mode Power Supply.
                So that would be your PSU or Power Bd.
                • Michale32086
                  • Nov 2011
                  • 1453
                  OK Thanx.. I mis-read it..
                  Gimme a few to set this up..
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    If you have an external power supply you can use that to power the Tcon
                    • budwich
                      • Jul 2015
                      • 3097
                      close check the LVDS cable between the main board and tcon... both in terms of the cable itself (ie. any bends, etc) and the connectors / pins. Those look like "transmission errors".
                      • Michale32086
                        • Nov 2011
                        • 1453
                        OK My TCON is a bit different than the one in the picture..
                        I have found corresponding connections for the LVDS connection, but I can't find any 3.3v VCC...
                        I have found a VIN, a VDO and a VA1....
                        • R_J
                          • 9624
                          That sure looks like high voltage arcing causing the lines, does this tv use an inverter and ccfl lamps? If it does I would check the high voltage inverter connections (or capacitors) or it could be a cracked ccfl.
                          You should be able to here it, like a sizziling sound.
                          Post a picture of the rear of the tv and if it does have inverters there are likely two, master and slave post pictures of them also
                          They could look like these
                          • Michale32086
                            • Nov 2011
                            • 1453
                            Yea, it does use the CCFL lamps. It's got an inverter on either side..
                            In answer to a previous question.. Some of the horizontal lines are stationary and some are flashing up and down..
                            • Michale32086
                              • Nov 2011
                              • 1453
                              Yep, that's exactly what they have...
                              I don't hear any sizzling or arc'ing when the TV is on..
                              • diif
                                • Feb 2014
                                • 6978
                                • England
                                Looks like it could be a BGA issue, any change to the lines of you heat the main IC on the mainboard ?
                                • R_J
                                  • 9624
                                  You can try disconnecting the power going to the inverter,(try one then the other) the backlight will not stay on but you may be able to use a flashlight to see if the lines are still in the image
                                  • Michale32086
                                    • Nov 2011
                                    • 1453
                                    Good idea..
                                    Lines are still present with the inverters unplugged...
                                    • Michale32086
                                      • Nov 2011
                                      • 1453
                                      I did do a rudementary reflow, not concentrating on the BGA, which I assume is the chip outlined in the pic??
                                      • R_J
                                        • 9624
                                        Originally posted by Michale32086
                                        Good idea..
                                        well that eliminates that idea. By chance do you have a scope? I might suspect a noisy ldo/bad cap like the ones near the power supply plug above ic1 in the picture
                                        • rstrube
                                          ViewSonic Pf815 (branded as P225f) Horizontal Deflection Issues - Running out of Ideas
                                          by rstrube
                                          Note: apologies I initially posted this request for help in the wrong forum! I am reposting it here and will take down the original posting.
                                          Hi Everyone,
                                          I've been working on repairing this beautiful CRT monitor off and on for the past several months and I'm really at a loss for what might be causing the problem.
                                          Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video)....
                                          Today, 01:37 PM
                                        • rstrube
                                          by rstrube
                                          Hi Everyone,
                                          Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video). The monitor itself is branded as a P225f, but it turns out that it's actually a Pf815 that has an Add-On smallish PCB that expands it to support...
                                          Today, 12:19 PM
                                        • jason123
                                          Hisense 65R6E3 double-image / horizontal strips - TCON?
                                          by jason123
                                          Hello all. 3 years back, with your help, I replaced the LEDs on this TV. It's been working great. Yesterday, I turned it on (garage TV), and it has blurred horiz / vert lines as you see in photos. Definitely no physical hit or damage. Top 1/6th of the screen is perfect. Could it be main / TCON board? No tabs to cut on this model. Thank you...
                                          07-19-2025, 08:07 AM
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
                                        • Hakuu
                                          by Hakuu
                                          Hi There,
                                          More Details
                                          TV Model - LG OLED77G1PUA
                                          07-12-2023, 02:37 PM
