LG 47SL80 Horizontal "Dashes"......
  • Michale32086
    • Nov 2011
    • 1453
    Re: LG 47SL80 Horizontal "Dashes"......
    Nope.. Unfortunately, no scope.. Have a multimeter though.. And I ain't afraid to use it!!
    • budwich
      • Jul 2015
      • 3097
      play with the folds in the LVDS and see if that changes anything with respect to the lines. what does the back side of the tcon board look like around the screw mount holes?
      • Michale32086
        • Nov 2011
        • 1453
        Got side tracked on this one.. Hope to get back on it soon...
        • rstrube
          ViewSonic Pf815 (branded as P225f) Horizontal Deflection Issues - Running out of Ideas
          by rstrube
          Note: apologies I initially posted this request for help in the wrong forum! I am reposting it here and will take down the original posting.
          Hi Everyone,
          I've been working on repairing this beautiful CRT monitor off and on for the past several months and I'm really at a loss for what might be causing the problem.
          Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video)....
          Today, 01:37 PM
        • rstrube
          by rstrube
          Hi Everyone,
          Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video). The monitor itself is branded as a P225f, but it turns out that it's actually a Pf815 that has an Add-On smallish PCB that expands it to support...
          Today, 12:19 PM
        • jason123
          Hisense 65R6E3 double-image / horizontal strips - TCON?
          by jason123
          Hello all. 3 years back, with your help, I replaced the LEDs on this TV. It's been working great. Yesterday, I turned it on (garage TV), and it has blurred horiz / vert lines as you see in photos. Definitely no physical hit or damage. Top 1/6th of the screen is perfect. Could it be main / TCON board? No tabs to cut on this model. Thank you...
          07-19-2025, 08:07 AM
        • x_orange90_x
          TCL 50S535 bad tcon or panel issue?
          by x_orange90_x
          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
          03-29-2025, 11:02 PM
        • Hakuu
          by Hakuu
          Hi There,
          More Details
          TV Model - LG OLED77G1PUA
          07-12-2023, 02:37 PM
