Samsung PN50A510P3FXZA Plasma No Picture
  • kevinm34232
    • May 2012
    • 1884
    Re: Samsung PN50A510P3FXZA Plasma No Picture
    Good point. Not sure if it's used but it has 0V on it. I am doing the logic board forced operation so everything should be ON.
    It's interesting that it would come up to 8.5V from 0 though if VS wasn't being signaled to turn on..?
    The PS_ON is turned on by going low on that pin, and is high in standby.
    • awyatt2
      • Feb 2012
      • 407
      • america
      ingles and rite aid drugs both carry the battery for the peak, sold as wireless entry battery. last ones I bought were around 5.00 for two in a pack.
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        No picture means no VS and or VA voltages. PSU not working. Trace the VS circuit and see if any diodes or e-caps are not functioning. Also no VS means no VY and VSC on the Y-Main Bd. How feasible is it for you to get another PSU?
        • kevinm34232
          • May 2012
          • 1884
          A new PSU is on it's way. I have been unable to find issue. I saw some evidence of tampering on the the primary side from previous owner so who knows what was done.
          Is there a point feasible location where I can check VS before it gets to the test pins, not sure of how everything works by the big transistors and transformer.
          • R_J
            • 9628
            The Vs secondary is quite simple, pins 13 & 17 of the transformer connect to DS805 & DS803 dual diodes which connect to CS813 capacitor, DS805 is common anode, DS803 is common cathode. There is also a thin trace from the positive to Rs821 and RS822 for feedback control and over and under voltage sense.
            • kevinm34232
              • May 2012
              • 1884
              So is it possible there is a problem on primary side? Any advice on what to check first?
              • R_J
                • 9628
                The primary does seem to be working, slightly, if it was dead you would not get the 8 volts you do get on the secondary now.
                There is a diode labled DS804 near the error board, whats the voltage on it? There is a video that has this board and the led on the error board is flashing, so I think... the steady led could be normal.
                What ic's did you replace in the Vs circuit??
                • Andrew F. Ali
                  • Jan 2014
                  • 2450
                  • Trinidad & Tobago
                  #28
                  Great that you could find a replacement PSU. That will fix your TV. A
                  • kevinm34232
                    • May 2012
                    • 1884
                    5V on DS804.
                    I replaced the ones included in the shopjimmy kit:
                    Integrated Circuits 6 UB801, UQ802, 805, US801, UX801, 804
                    Resistors 2 RS807, RX807
                    Transistors 4 QS801, 802, QX801, 802
                    Fuses 3 FB801, FE801, FS803
                    For some reason did not come with UX805 or those diodes DS803/805 but they appear to be good.
                    • R_J
                      • 9628
                      That 5volts supplies the feedback ov/uv circuit so thats good
                      Ok so after changing those parts did anything change from the original problem? Any chance of getting
                      Any chance of getting a picture of the bottom side VS primary and secondary?
                      • kevinm34232
                        • May 2012
                        • 1884
                        Nothing changed that I know, I don't know exactly what VS was before I just knew it didn't come up.
                        Here some pics, let me know if you need closeups in any area. You see some solder work on a lot of areas where I reflowed potential problem areas and pads that came up off the board.
                        Also you will notice CP809, one of the big primary caps, was circled and unsoldered when I opened up the TV. The pads get damaged easy on this board and I had scrape away some of the board to get to the traces in some areas to fix..
                        I don't know why, and I'm pretty sure I checked early on and have 395V there..
                        • R_J
                          • 9628
                          Are you sure the center pin of DS805 is connected to the CS813, it does'nt look like it is in the picture
                          • kevinm34232
                            • May 2012
                            • 1884
                            Yes it's got a good connection that's just the lighting..
                            • kevinm34232
                              • May 2012
                              • 1884
                              Above US801 in the 2nd pic there are 4 transistors (?) (QS803>806), I can't be sure but it looked like maybe the solder had been changed on those.. Nothing is shorted I just know what someone did before..
                              I hope to be able to use the new board to figure out what's wrong on this one.
                              Where is the first point I should have the +-200V for VS? Anything I can check on the primary side of that circuit?
                              • R_J
                                • 9628
                                The secondary could not be simpler. What you could check is the voltage across the optocoupler, pins 1 & 2 (they are on the secondary) then check the voltage across pins 3&4.
                                If you want you should be able to compare the voltages on UX801 and US801, see if there is a pin that is different, remember this is using hot ground
                                The transistors are part of the drive circuit for the fets, the drive output A & B come from the ic, go through the 2 transistors and drive the gate drive transformer.
                                Usually if there is a problem with the drive circuit it blows the fets.
                                • kevinm34232
                                  • May 2012
                                  • 1884
                                  This ICS801, if you're talking about voltage across each both pins on the secondary side, and then both on the primary side, it seems it's 0V on both.
                                  • R_J
                                    • 9628
                                    Well thats not right, I wonder if the opto is bad, check the resistance between 1 & 2 and then 3 & 4, you can compair the readings to icx801
                                    • R_J
                                      • 9628
                                      From some other information I found on the alarm board is (I believe) a steady green led means standby voltage is there and ok. if that led was blinking, it would blink the error.
                                      Another thing to try would be unplug cn802 and using a 1k resistor jump 5 volt standby (I believe it is JP131, check it to be sure) to Vs_on and see if that turns on the Vs.
                                      • kevinm34232
                                        • May 2012
                                        • 1884
                                        New Development
                                        Got another PS board. Same exact issue, 8.5V on VS.
                                        Fantastic.
                                        Will check VS_ON next...
                                        • kevinm34232
                                          • May 2012
                                          • 1884
                                          I'm not sure what VS_ON is supposed to do it's between 0 and 1V whether on or off. Is it possible logic board is problem?
                                            09-07-2024, 05:50 AM
                                          • TR103
                                            by TR103
                                            - it keeps rebooting
                                            01-22-2025, 04:12 PM
                                          • JJAAMM
                                            by JJAAMM
                                            Problem
                                            07-06-2023, 06:01 AM
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • Dodgethis
                                            Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                                            by Dodgethis
                                            Hello all,
                                            This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                                            09-11-2024, 07:39 AM
