Samsung PN50A510P3FXZA Plasma No Picture
  • R_J
    • Jun 2012
    • 9624
    Re: Samsung PN50A510P3FXZA Plasma No Picture
    A lot of the plasma power supplies require a load on the Vs. Oh well onward and upward... So it looks like you are not getting the VS_ON from the control board. Do you have any led's lit on the control board?
    • kevinm34232
      • May 2012
      • 1884
      Yes there is an LED that lights up solid on the logic board. And I ordered a new one yesterday after not getting VS_ON since it was only around $20 just to eliminate that. Anything else to check before it arrives? There is no obvious short on the VS line.
      Is it possible the logic board is the fault?
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        #63
        The green LED should be flashing indication a healthy supply and all is good with the Logic Bd. A steady lED means there is a problem with the Logic Bd
        • kevinm34232
          • May 2012
          • 1884
          So I was wrong after plugging everything back in and doing the logic board forced operation, the LED on the logic board is flashing, not solid. I'm still waiting for the new logic board to try it anyway.
          Do we know if TV will operate with buffer boards removed and/or ribbons to the panel?
          • R_J
            • Jun 2012
            • 9624
            You should have no problem removing the buffers for a test, see if Vs comes up with them disconnected
            • kevinm34232
              • May 2012
              • 1884
              That did not help, nor did I find anything shorted or open on the Y-Main, I'm hoping it's just the logic board not turning on VS.
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                #67
                I will tend to agree with you there.
                • kevinm34232
                  • May 2012
                  • 1884
                  New logic board fixed TV.
                  FYI On this working logic board, flashing green LEDs on both left and right sides. The old board was just one flashing green LED in the center.
                  Thanks for all the help RJ and Andrew.
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    #69
                    HOORAY!!!...Glad you got it going. If I remember correctly you suspected that the Logic Bd. was the problem.
                      09-07-2024, 05:50 AM
                    • TR103
                      by TR103
                      - it keeps rebooting
                      01-22-2025, 04:12 PM
                    • JJAAMM
                      by JJAAMM
                      Problem
                      07-06-2023, 06:01 AM
                    • Mgiffune
                      by Mgiffune
                      06-09-2024, 10:28 AM
                    • Dodgethis
                      Samsung QN75Q6DRA, No Picture, Has BL, and Sound
                      by Dodgethis
                      Hello all,
                      This is my first post, but long term lurker on the form learning as much as possible about these TV's. I was given this TV as due to a power outage of constant On/off of power to TV. The TV originally would just click on and off (Typical Reboot Cycle). I opened the back of the TV, and troubleshooted by taking the 96 pin LVDS off one at a time to see if I had a picture on either side. I finally fixed the reboot cycle by finding the error on the left side of the screen off connector CN 1301, and the TV would stay on. Further troubleshooting led me to the driver boards where...
                      09-11-2024, 07:39 AM
