Insignia NS-32lcd washed out colors
  • nomoresonys
    • 12075
    • U.S.
    Re: Insignia NS-32lcd washed out colors
    This should be a match too, they are both from the same seller: https://www.ebay.com/itm/Akai-LCT328...kAAOSwkvdacOZZ
    • nomoresonys
      • 12075
      • U.S.
      There's a lot there to choose from, I just listed the cheapest first, just be sure you match Part Number: 35-D003848
      or
      Substitute Part: 35-D004737
      • nosaj
        • Dec 2014
        • 44
        ok it's on the way thanks so much for your help
        • nomoresonys
          • 12075
          • U.S.
          No problem, hope it solves the issue.
          • nosaj
            • Dec 2014
            • 44
            Putting it back together . The flat cable 8pin goes from the power supply to the invertor board about 15in maybe one end the plastic crumbled off so it's bare conductors I would like to find a replacement because I really don't want to put it back like that.
            Any suggestions where I might find one?
            Thanks,
            Jason
            • nomoresonys
              • 12075
              • U.S.
              #26
              https://www.ebay.com/itm/INSIGNIA-NS...AAAOSwu2VZZQSU
              • Fallen Wolf
                =3
                • Mar 2008
                • 7
                #27
                Originally posted by nosaj
                Putting it back together.
                It's been quite some time, did the new t-con board fix your issue?
                I'm having the same issue with the same model of display/t-con board being used, so I just ordered a new t-con board from China (searched for "V320B1-L01-C" on fleabay and found one for less than $10 including shipping, so I guess it's worth a try).
                I'll try to remember to post an update when my replacement t-con board arrives (might take 1-2 months tho due to shipping from China...).
                • nomoresonys
                  • 12075
                  • U.S.
                  #28
                  Ok, feedback is always appreciated, all I can do is assume that either the tcon or lvds cable fixed nosaj's tv, no feedback from him/her on that.
                  • nosaj
                    • Dec 2014
                    • 44
                    I was not able to fix it as other connector cables the plastic had endured some heat and the plastic crumbled on the connectors leaving the pins . I did not feel comfortable just putting the pins on there with no insulation between them and wasn't able to get another set of cables . so I tore it down for parts an diseminated them.
                    nosaj
                    • nomoresonys
                      • 12075
                      • U.S.
                      #30
                      Ok, sorry to hear, thanks for report.
                      • Fallen Wolf
                        =3
                        • Mar 2008
                        • 7
                        #31
                        Update: My replacement t-con board arrived today, but unfortunately it didn't fix my issue (same fault as before using HDMI).
                        Seems like I misdiagnosed my TV here as other analog video inputs aren't looking as bad as HDMI (I only checked HDMI cause that's what I have readily available as a signal source).
                        Lesson learned for me: Don't jump to conclusions and also test other signal sources as well.
                        I guess this is where I call it quits with trying to fix this TV here.
                        • nomoresonys
                          • 12075
                          • U.S.
                          #32
                          Ok, so if hdmi is the only problem and your hdmi cable is confirmed good, probably only need a mainboard.
                          • cajoeg
                            Insignia NS-LCD019-09 issue: Power light turns blue for 3 seconds, the flashes red before going solid read again
                            by cajoeg
                            Hello, I'm new to the group and to trying to repair a LCD TV. During the past few years, I've been collecting/repairing/restoring vintage personal computers (Commodore, Apple II, Atari, TRS-80, Texas Instruments, and Timex Sinclair). This has been my retirement hobby. Now I've gotten interested in trying to repair a LCD TV that I have and used regularly when working on vintage computers.
                            The LCD I'm working on is a Insignia NS-LCD019. I've downloaded the service manual that I could find, but it must be a different revision since not too many items in the service manual match the TV...
                            02-10-2025, 04:01 PM
                          • silikon77
                            Philips 70PUS7855/12 bad colors when applying the tape fix on teh T-con board
                            by silikon77
                            Hi!
                            Got an 70 inch Philips tv model 70pus7855/12 from scraps and I decidet to give it a go. I'm an enthusiast but no porfessional in the electronics.
                            Found some advices watching youtube nad came up with this:
                            It came with no picture, after diagnosing it I found out that the right side of the T.con board was faulty.
                            I taped down the clock signals and I got a picture but the left side of the panel has less pronounced colours. Only the right 3rd side of the panel has good colors.
                            See attached picture.
                            I tried a few combinations to block individual clock...
                            01-02-2025, 02:26 PM
                          • mecha1166
                            Un70nu6900 taped lvds, how to fix washed out 1/2 picture?
                            by mecha1166
                            I am getting these 70 inch Samsungs daily. Dead set light comes on goes off, dark screen. Tried taping the problem lvds cable pins 13 to ? pin, used about 9 mm scotch tape. Picture comes on, no distortion lines, looks good, but 1/2 of screen is washed out. Problem seems to always be the last little strip on the bottom. Has anyone found what is actually the problem? Possibly one of three diodes there? I have a pic but it is washed out on 1/2. Anyony had success in fully restoring the picture? Thanks.
                            07-03-2024, 05:03 PM
                          • captainKKK
                            Samsung LN37A550P3FXZA - washed out colors
                            by captainKKK
                            I have referenced https://www.badcaps.net/forum/showthread.php?t=35193.
                            I seem to have the washed out pictures on my Samsung LN37A550P3FXZA. And have tested my T-con board voltages. My problem is that the board does not give the numbered sequence so I can easily tell if they are increasing/decreasing in order. So I number them myself as in my attached pictures and the voltages are:
                            Samsung LN37A550P3FXZA T-con voltages:
                            (text formatting this forum not good for tables - see attached picture)
                            |Test | no antenna | with antenna
                            |point...
                            05-24-2019, 10:01 AM
                          • rddube
                            Viewsonic vx2235wm colors washed out after power board recapping
                            by rddube
                            I am experiencing a weird problem with my monitor in that after changing faulty caps on the power board (pictured) because my monitor was turning off , i reassembled and it power up but this time with the colors washed out when in Windows. I posted a picture of the actual monitor and the same image on my LG monitor for comparison purposes
                            When opening up the menu, colors are fine it is only when entering into Windows.
                            I read other posts and someone suggested to take the Voltage readings on the TCon board, here they are with monitor turned...
                            12-18-2017, 10:04 PM
