Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
Panasonic Th-42A400z led tv
    Re: Panasonic Th-42A400z led tv
    You can test the LED strip without disassemble the screen, you have two sets of LED strings, that is why you have 4 wires, so you will remove the LED connector from the LED driver board and then test each pair with the LED tester. The Tester has Volt meter that will show the total Vf (forward Voltage) of the LED string, so you just have to compare the two readings.
    Example of using LED tester to find out the condition of the LED string, as you can see, his reading was only 130V so he has some shorted out LEDs. The screen did light up for second but it went into shut down due to shorted LEDs.
    https://www.badcaps.net/forum/showthread.php?t=70274
    • lambchopsnz
      • Jul 2016
      • 63
      • New Zealand
      Hi guys im back, I got myself an led tester and plugged it into both sets of leds but the voltage stayed at 326v on both of them which is what it sits on when just the power is plugged into the tester. So im not sure what this means next..does this mean they are good or bad or bad test..any suggestions appreciated.
      thanks.
        So you disconnect the LED connector from the power supply board and correctly connected the LED tester Red and Black probe to the correct LED + and LED - of the LED's connector?
        • lambchopsnz
          • Jul 2016
          • 63
          • New Zealand
          Yes i used the diagram from the test manual from earlier in this post to determine which were the right pairs of wires so i figured it was the 2 outside orange and black and 2 inside red and brown i did try red black and orange brown also but same result.
          • lambchopsnz
            • Jul 2016
            • 63
            • New Zealand
            ok looks like i had the wrong wire pairs so i managed to test the 2 correct pairs of wires in the dark and could see the glow through the back panel the first pair reads 43.9v and the second pair 65.5v is this likely to be bad leds...
            • lambchopsnz
              • Jul 2016
              • 63
              • New Zealand
              #26
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                #27
                Pages 67 & 68 may be of help to you.
                • lambchopsnz
                  • Jul 2016
                  • 63
                  • New Zealand
                  #28
                  Hi yeah i did try following the test diagrams and my voltage tests point to a faulty LD board but trying to source one of these isnt proving the easiest well i found the boards but i dont want to pay around $70 shipping. I have another tv exact same model working so i might try the board from that before i pull the screen apart or order a board..i just have to wait for the missus to go away so she dosent have a fit lol.
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    #29
                    Tread carefully. Nothing worse than annoying the wife
                    • lambchopsnz
                      • Jul 2016
                      • 63
                      • New Zealand
                      #30
                      Yes or ending up with 2tvs that dont go lol
                      • aanan
                        • Dec 2010
                        • 222
                        • India
                        #31
                        Littel help
                        • lambchopsnz
                          • Jul 2016
                          • 63
                          • New Zealand
                          #32
                          ok so today i tried the boards from my dead tv in the good tv and they all work so im left with it being the panel..Im guessing the 2 boards at the bottom of the panel are attached and not replaceable? Is this whats meant by the panel. I did test the led in the good tv and have the same reading as the bad one which rules out the leds right?
                          well if no other options i guess i have a few spare boards..
                          • lambchopsnz
                            • Jul 2016
                            • 63
                            • New Zealand
                            #33
                            Ok so i have found these 2 boards are available but the question is are they replaceable?
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              #34
                              what are you trying too find on your tv the led strips? if so you need to remove the lcd panel and the various sheets under the lcd but keep these dust free and in order this video may help
                              https://www.youtube.com/watch?v=5rwLDxKgZIA&t=12s
                              • Tynan Dill
                                by Tynan Dill
                                Assuming...
                                11-22-2024, 01:46 PM
                              • m1ch43lzm
                                by m1ch43lzm
                                05-12-2025, 08:37 PM
                                After all of...
                                07-13-2024, 08:14 PM
                              • canadaboy25
                                Panasonic TC-P54VT25 No image. A or D board?
                                by canadaboy25
                                I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                01-17-2021, 01:06 AM
                              • howardc64
                                by howardc64
                                07-24-2025, 05:17 PM
