Samsung UN50H6201 panel problem, half screen
  • fluxthat
    • Jun 2018
    • 8
    I have a Samsung UN50H6201 that stopped working for no obvious reason. There is backlight but no picture. I replaced the power and tcon boards since it cost me less than $20. (Please spare me your lecture on "throwing parts".)
    The replacement tcon board the three lights came on, as normal. When I looked at the screen it was operable but there were many lines in it near the center. A minute later the VREF light on the tcon board then went out and it went back to backlight and black and no picture. So I obviously blew something on the tcon board but I can't figure out what.
    One thing I did figure out is that if I have right LCD ribbon disconnected and left connected that half the screen works (no lines) and the other half turns white, and the VREF light on the tcon board comes back on. OTOH if I have left LCD ribbon disconnected and right connected it is backlight and black and no picture on either side.
    I read another post in here last night about a similar issue and the response was a brief "panel problem". Does anyone have more information about common problems in that area or how I might diagnose or repair the board going into the LCD (that is, the board that takes the LCD ribbon, I don't know its name). It doesn't look like something I can just order.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Samsung UN50H6201 panel problem, half screen
    Bad Panel
      Bad panel, start looking for shorted capacitors oN the Tab bonding board.
      • fluxthat
        • Jun 2018
        • 8
        Ok. I've checked the board twice for shorted capacitors and can't find any. Do you have any other ideas?
        • budwich
          • Jul 2015
          • 3097
          post a picture of the full screen when you get the "half working screen" situation. That will indicate more about the panel problem.
          • nomoresonys
            • 12276
            • U.S.
            A panel problem can take out/destroy every tcon you put in.
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              The Tab Bonding Bd. or the Source Bd. is the long board/s at the edge of the Panel. There are ceramic capacitors that fail by shorting and blank out the picture information to the screen but since the screen is being powered it shows as white.
                Which did you check? The tab bonding boards?
                • fluxthat
                  • Jun 2018
                  • 8
                  I checked the boards that the ribbons from the tcon goes into. There are two boards, one for each side of the screen. They are hidden under the bezel. They have the ribbons going into the LCD. In the pic I posted they would be at the very bottom.
                  I don't suppose anyone has the service manual for this model? I will take a picture of the boards and the screen and post it when I have a chance. Thanks for all the suggestions so far.
                  • fluxthat
                    • Jun 2018
                    • 8
                    I haven't had time to work on the TV this summer. I'm thinking about listing it for free to see if someone wants it. Just to confirm I did check the tab bonding boards for capacitor shorts but didn't find any. I took pictures of the TV which are attached.
                    They show when only the ribbon for the tab bonding board on the right side of the screen (left in the pictures) is connected. (Otherwise the TV is all black and the VREF light on the T-Con does not come on.) Note also I was testing a different main board (UN50J) when I took this pic so the picture is flipped but it otherwise the same with the UN50H main board.
                    If I flex the tv at the bottom (the top in the pics) like from side to side a little the white bars will disappear while that side of the screen will slowly fade to black on its own and then after a second come back to white with the bars. Do you think this is worth any more time?
                    • budwich
                      • Jul 2015
                      • 3097
                      IF there are tabs along the side, then it might be possible to save the set by removing those as they potentially have a problem with them based on your "cable removal test".
                      IF there are no side tabs, you might still get "lucky" using the "tape cutoff method" which uses a bit of tape on the tcon connector to block some of the pins that are driving that side of the screen.
                      • fluxthat
                        • Jun 2018
                        • 8
                        Can you show me what you mean by side tabs and tape cutoff method. I googled it but did not see anything relevant. On my TV there is basically a cable from the main to the t-con, two from the t-con to individual driver / tab boards and a bunch from the tab boards to the panel. All the tabs (and by that I'm assuming you mean the actual bonds of the ribbons to the panel) run along the bottom.
                        • neilc6
                          • Nov 2015
                          • 1550
                          https://www.badcaps.net/forum/showthread.php?t=50646
                          • keats11
                            • Nov 2012
                            • 88
                            I had a similar TV (model UN50H6203), uses the same Tcon board (and hence the same panel). Same issue, no video with backlight on power on. In my case the right half of the screen had the fault. I took the tcon out and looked at the multiple traces that run to the panel on the Tcon board. All of them have a reisistor in series before they hit the pins on the connector to the flat cable. I removed the first resistor corresponding to the corner of the TV (In this case right corner) and installed it. Vola, TV fired up with a picture and played for over an hour without any problem before I shut it off. The only minor issue is that if you look carefully on some scenes, the right top of the TV shows faint horizontal lines. I have attached a picture of the TV as soon as it worked, although you cannot see the lines in this picture.
                            • fluxthat
                              • Jun 2018
                              • 8
                              Cool thanks! I still have the TV and I will try that this spring.
                              • nwcs
                                • Dec 2015
                                • 311
                                • usa
                                Keats11 may I ask how you determined which resistor to remove? I tested every resistor and they all have the same value except one towards the middle that is lower.
                                • neilc6
                                  • Nov 2015
                                  • 1550
                                  Check the thread I posted #13. There is a problem in the panel and the workaround is to either block pins on the ribbon cable, cut the tab bond (youtube link in that thread) or in this case remove resistors on the tcon board. Blocking pins on the ribbon is at least reversible.
                                  • DoctorCueNC
                                    • Apr 2019
                                    Hi, just picked up a tv with this issue for free and thought of troubleshooting it. Is there a YouTube video or post that shows how to perform the tape block method?
                                    • neilc6
                                      • Nov 2015
                                      • 1550
                                      Disconnect the ribbon cables from the tcon to the panel one at a time to determine which side is bad. You need to flip the lock up to remove the cable. Power tv off between attempts. You should get a good picture on one side. On the side that is bad, block the metal contacts of the ribbon on the outside edge with scotch tape or shipping tape. I would start with blocking 2-3 pins and increase if it doesnt work. Again power off the tv between attempts.
                                      • DoctorCueNC
                                        • Apr 2019
                                        Thanks!
                                        • Chrissygizmo
                                          by Chrissygizmo
                                          02-10-2025, 12:33 AM
                                        • kca
                                          by kca
                                          Hello all ~
                                          08-31-2025, 06:38 AM
                                        • Tom C
                                          Samsung QN55Q70AAFXZA Half Screen Dim
                                          by Tom C
                                          I’m working on a Samsung tv for my son. When I brought it home the left side of the screen was dim, right side ok. I’ve replaced the LED edge strips, main board and now the power board. The only difference is that the dim side has switched from left to right. Is there something else I should be looking at? I’ve also replaced the ground tape (Faraday tape?) from the LCD screen to the chassis. I probably have a week left on returning the parts.
                                          Any suggestions would be appreciated.
                                          thanks.
                                          09-19-2024, 07:22 PM
                                        • Daren87
                                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                          by Daren87
                                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                          08-13-2023, 03:25 PM
                                        • Chrissygizmo
                                          samsung galaxy ao2s very temperamental after screen replaced
                                          by Chrissygizmo
                                          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                          Ive eventually managed to get it on and working but it's very temperamental...
                                          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                          05-26-2024, 12:05 AM
