Sony TV 24-ex-430 LCD Scratched
  • Chaks
    • Sep 2015
    • 115
    • India
    I bought a used Sony LCD/LED TV which is working perfectly but it has a 3mm sharp scratch on the screen/panel (see images in the link).
    Can anyone tell me if the scratch is only superficial and it has not damaged the underlying pixels.
    Is there a chance that the scratch will spread over time and become bigger than it is now. I plan to install a screen guard to the TV and before that just want to make sure that the scratch was not that deep enough to have caused any damage to the LCD display.
    Assuming the worst case that the scratch has cut through the underlying pixels in its path ... will the damage to the lcd screen be limited to the pixels that are damaged or it may start spreading and become worse during normal usage.
    https://drive.google.com/open?id=1_5...dkx8cXR-Ae4nay
    Many thanks for your time.
  • R_J
    • Jun 2012
    • 9624
    Re: Sony TV 24-ex-430 LCD Scratched
    The lcd panels are glass but there is a plastic film covering them, It is likely just the plastic film that is damaged, if it went through into the class there would be a very large crack in the glass. Just leave it alone as it can't be repaired
    • Chaks
      • Sep 2015
      • 115
      • India
      Is there any chance that the scratch would expand during normal use.Does it make the lcd screen brittle in that area and any slight tension on the lcd screen will result in a crack in future. What i mean by slight tension is occasional touching of lcd screen by finger tips/nails.
      Can this scratch develop into a crack ? Are the LCD screens so fragile that a scratch would eventually develop into a crack during normal usage. Do i need to worry about the scratch that is 3-4mm on a 24inch lcd/led tv.?
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        No. This scratch will not and has not weaken the LCD glass at that point. If it is bearable/tolerable while watching movies etc then just leave it alone. try to polish or buff it out will make a bigger spot on the screen.
        • Chaks
          • Sep 2015
          • 115
          • India
          thanks a lot for the replies. finally got rid of my worries about the extent of damage the scratch would cause on the LCD glass. I am just going to put a screen guard on the lcd so that such scratches do not occur again.
          • Ryan.man
            by Ryan.man
            02-04-2025, 12:23 PM
          • reformatt
            by reformatt
            07-31-2025, 08:37 PM
          • Chrissygizmo
            Sony KD-55XG9505 lines on screen problem
            by Chrissygizmo
            Hello again everyone,
            This is my latest mission, to try getting this Sony tv back to normal working order…
            I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
            02-19-2025, 11:31 AM
          • smic717394
            by smic717394
            07-25-2024, 10:16 AM
          • Adam Russ
            Black screen on Sony 65x90ch (65x900h from Costco)
            by Adam Russ
            Weird issue with this tv. Was streaming to the from a computer when it stopped working and the screen went black. Ever since then there has been. o image. Just a black screen. The audio works and yhe backlights do come on when it's powered on, it's just a black image. It presented like a backlight issue. So I finally got around to getting new backlights and a backlight tester. All of them test the same as the good backlights with the same voltages. There are no blinking lights. Just the white led at startup and when buttons on the remote are pressed signaling it's receiving from the remote....
            09-15-2024, 05:46 PM
