Diode Identification
  • boomtheroom
    • Apr 2018
    • 28
    • new zealand
    Trying to attempt to repair my sc board TNPA5335 BG
    found a bad diode at d618 but cant determine its values..can anyone help please?
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Diode Identification
    If you can post it in focus, it would help to identify it.
    Edit
    Is this a continuation of your other thread and if so would have been better to have stayed on that thread.?????
    If it is then from your previous thread it's marked C08N25 and a search on the internet bring them up.
    There's also some information on this Mosfet in the following thread
    • boomtheroom
      • Apr 2018
      • 28
      • new zealand
      Edit
      its the one in the bottom left with d618 marked next to it
      • R_J
        • 9515
        It could be a RF101L4S, Panasonic pt# B0ECKP000055, but I might be wrong
        • boomtheroom
          • Apr 2018
          • 28
          • new zealand
          anything from here do as a replacement?
          https://www.jaycar.co.nz/active-comp...vance&show=All
          • tvtimmy
            • Mar 2015
            • 1160
            • usa
            Is Q600 still blown apart? You will get all sorts of bad readings with bad parts still on the board.
            • boomtheroom
              • Apr 2018
              • 28
              • new zealand
              yep it sure is.. but d618 is the only diode showing a short
              • jetadm123
                • 2169
                Just remove D618 and check it out of circuit.
                • boomtheroom
                  • Apr 2018
                  • 28
                  • new zealand
                  will do!
                  • tvtimmy
                    • Mar 2015
                    • 1160
                    • usa
                    It could be reading bad because of the bad Q600 is still on the board.
                    • Moreno83
                      • Jun 2014
                      • 2008
                      • The Netherlands
                      I use Fairchild ES1G as a substitute however that one always reads short on the board. After the fake parts usually the 2/3 diodes top right on the board fail ( close to the white prong connector ).
                      • boomtheroom
                        • Apr 2018
                        • 28
                        • new zealand
                        Any idea of an alternative for the 2 chips?
                        Can't get them from monitor9 so need alternatives
                        Chers
