Question about rectifier diode numbers and identification
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    Can someone please tell me how to identify a rectifier diode using the numbers printed on it? I'm having a hell of a time and just frustrating the p out of myself
    They call me......."threadkiller"
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Question about rectifier diode numbers and identification
    Usually there's no rhyme or reason for any particular number; you could just post it and/or a picture of it, and see if someone could find something about it.
    • DXseekerMO
      • Feb 2018
      • 1119
      • US
      Here's the pic, looks like I need glasses worse than I thought.
      I thought the number was W215G, instead its W2156
      I found this on Digikey, but they call it a Schottky diode. It looks like mine is marked as a rectifier diode?
      https://www.digikey.com/products/en/...ys/286?k=w2156
      • R_J
        • 9553
        It is a dual schottky, common cathode diode. They use a shottkey as a "rectifier" because it has a lower forward voltage drop and are very fast switching. due to the high frequency of smps's
        • DXseekerMO
          • Feb 2018
          • 1119
          • US
          Thanks guys, looks like I found the right one then, I appreciate it!
          • R_J
            • 9553
            What is wrong with it? Just so you know they do check different than a silicone diode, in diode mode on a meter they read around .2xx where as silicone is .6xx
            and if you are measuring a short accross the outside leads you are likely measuring across the transformer winding
            • DXseekerMO
              • Feb 2018
              • 1119
              • US
              I shorted the center and left pins together while powered up
