Panasonic TC-P50G10. 6 blinks to 7 blinks.
  • MRC25
    • May 2018
    • 17
    Re: Panasonic TC-P50G10. 6 blinks to 7 blinks.
    Should I test the diodes?
    • tn245
      • Oct 2013
      • 530
      What about +15V (TP82) ?
      • tn245
        • Oct 2013
        • 530
        Measure voltage on either side of diode D480 on start up. Looking for where the SOS7 signal is coming from.
        • MRC25
          • May 2018
          • 17
          Getting 15v there.
          That thing is super small. Hard to get a reading but it gave me 3 for a split second and then went straight to 0.
          Weird new symptom. Before when I started it up it would click, SOS7 twice then turnoff. Now it just stays on and does the SOS7 over and over. Not sure if that has any meaning.
          • tn245
            • Oct 2013
            • 530
            Need separate readings for anode and cathode of D480 (black probe on chassis ground).
            No idea about that. Usually it just repeats as it sounds like it's doing now.
            • MRC25
              • May 2018
              • 17
              Anode .3
              Cathode .2
              • tn245
                • Oct 2013
                • 530
                You might need to set your multimeter on peak/max hold mode to catch the SOS event. You should get 4 to 5V briefly on the cathode if you're getting SOS7. This would also show up at test point TPSOS7 obviously. If you're not getting voltage there just before the error trips then possibly the A board is misdiagnosing.
                • MRC25
                  • May 2018
                  • 17
                  Retested the Cathode and TPSOS7. Got 5v on both.
                  • tn245
                    • Oct 2013
                    • 530
                    So the anode?
                    • m1ch43lzm
                      by m1ch43lzm
                      05-12-2025, 08:37 PM
                      by sam_sam_sam
                      After all of...
                      07-13-2024, 08:14 PM
                    • canadaboy25
                      Panasonic TC-P54VT25 No image. A or D board?
                      by canadaboy25
                      I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                      The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                      I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                      01-17-2021, 01:06 AM
                    • Biruslapio
                      Panasonic P50VT20B Plasma 12 Blinks, Power Supply or A-Board?
                      by Biruslapio
                      Hello, I've had this TV for 3 years, 2 years ago it stopped working signaling 12 Blinks, SOUND_SOS according to the service manual.
                      It has no VSUS or VDAT, and P15V has 1.0V instead, the same 15V goes to A board. F15V is ok and other main voltage rails.
                      It seems the power supply is defective, since unplugging D20 ribbon cable that goes from D-board to SC-board makes the behavior change, the TV stays on, there's no image nor VSUS, but 15V reads 2.4V, high enough to not trip the SOS 12 blinks, so it stays on, fans do not spin but I left it 2 hours, green led lit up...
                      02-16-2021, 09:44 PM
